Old 24th October 2010, 22:06   #9941  |  Link
MB2
Any ideas on this one?? Original audio LPCM, was hoping to have it Dolby Digital, but wouldnt even extract.
Thanks!
[21:45:08] BD Rebuilder v0.34.09 (beta)
- Source: SEVEN_SAMURAI_DISC1
- Input BD size: 46.03 GB
- Approximate total content: [03:27:04.495]
- Target BD size: 23.00 GB
- Windows Version: 6.1 [7600]
- Quality: Highest (Very Slow), Two Pass
- Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[21:45:09] PHASE ONE, Encoding
- [21:45:09] Extracting A/V streams [VID_00274]
- Error in attempt to extract audio/subs.
- AV frame too large (64000 bytes). Increase AV buffer.
[21:53:26] - Failed to retrieve audio, aborted
MB2 is offline   Reply With Quote
Old 25th October 2010, 00:13   #9942  |  Link
setarip_old
setarip_old's Avatar
@mhvf
Hi!
I'd suggest you post the entire log...
Old 25th October 2010, 02:16   #9943  |  Link
Originally Posted by mhvf View Post
Hi, I've tried to backup young victoria (region A - brazil), but the highlight in menu doesn`t appear, in other words, cannot select anything in movie menu, then try to press "OK" but nothing happens.
It seems the whole content is ok, beacuse I can watch trailers. Is not my player, I`ve one of LG and other is panasonic BD-60
Some help please?
I think I know what might cause that... It's rare... I'm working on a fix. Have you modified the minimum size parameters? That can aggravate it.
Old 25th October 2010, 02:33   #9944  |  Link
mhvf
The minimum size I've not modified (Is this change in the hidden menu options?), I'veonly adjusted the maximum blu ray size to 24000, and the common menu options (like vbr, cbr, don't convert to ac3). Thanks for answering
As soon as I get home, I'll try to post the log...
mhvf is offline   Reply With Quote
Old 25th October 2010, 08:18   #9945  |  Link
SoniG
SoniG's Avatar
Pes packet len too large issue
Hi jdobbs, I got lately the 'Pes packet len too large ( >100Mb)' issue on a rebuild of Pinocchio BD. I read on the thread it should be an issue due to a bad rip. In Pinocchio I think the issue come from a .sup stream that have a size of 197MB, far more than standard sup files that rarely surpass 30MB. In this BD, a sup stream is used to display Disney custom paintings on the movie to fill around his original 1.33 ratio. That is this faulty stream that generates the muxing issue certainly due to his excessive size. I just removed the corresponding subtitle stream on BD Rebuilder and the Backup passed.
SoniG is offline   Reply With Quote
Old 25th October 2010, 15:09   #9946  |  Link
Capsbackup
This sounds like a disc that has IGS menu type, which unfortunately tsMuxeR does not support.
What you could try, if you are doing a BD-25 backup, is to set MIN_M2TS_SIZE=600, or change 600 to a value larger than the largest menu .m2ts.( See the HIDDENOPTS text file within BD-RB zip file).
Old 25th October 2010, 17:12   #9947  |  Link
scifiste
Failed video encode Ghostwriter
Using latest beta had failed video encode with GhostWriter blu ray.
Log below:-
[19:25:56] BD Rebuilder v0.35.01 (beta)
  - Source:  THE_GHOSTWRITER
  - Input BD size: 28.24 GB
  - Approximate total content: [02:07:58.087]
  - Target BD size: 22.66 GB
  - Windows Version: 6.0 [6002]
  - MOVIE-ONLY mode enabled
[19:25:56] PHASE ONE, Encoding
 - [19:25:56] Extracting A/V streams [VID_00029]
 - [19:43:00] Reencoding: VID_00029 (1 of 2)
 - [19:43:00] Collecting video information
   - Rate/Length: 23.976fps, 184,080 frames
   - Bitrate: 20,403 Kbs
 - [19:43:00] Reencoding: VID_00029, Pass 1 of 1
  - Encode failed.  Retrying.
  - Reached retry limit.  Aborting.
  - BD-Rebuilder v0.35.01 (beta)
  - AVISYNTH Version: 2.5.7.0, Ok
  - HAALI Splitter:  Ok
  - FFDSHOW: 3326, Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[19:43:01] - Failed video encode, aborted
Tried uninstalling, deleting folders then reinstalling but still does not work.
Last cmd file is attached
File Type: txt LASTCMD.TXT (446 Bytes, 14 views)
scifiste is offline   Reply With Quote
Old 26th October 2010, 00:16   #9948  |  Link
spinn
Once again, running into errors with the Glee series...fails to build structure. Any ideas jdobbs?
[Options]
MODE=0
ENCODE_QUALITY=1
ONEPASS_ENCODING=1
AUTO_QUALITY=0
AUDIO_TO_KEEP=chi;eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=45000
TARGET_SIZE=8032
PRIORITY_CLASS=0
[Paths]
SOURCE_PATH=C:\USERS\JEFF\VIDEOS\BD\GLEE_S1_D3\
WORKING_PATH=E:\BD\
[15:38:45] BD Rebuilder v0.35.01 (beta)
- Source: GLEE_S1_D3
- Input BD size: 45.53 GB
- Approximate total content: [04:28:31.845]
- Target BD size: 7.84 GB
- Quality: Better (Faster), CRF
[15:38:45] PHASE ONE, Encoding
- [15:38:45] Extracting A/V streams [VID_00019]
- [15:38:46] Reencoding: VID_00019 (1 of 10)
- [15:38:46] Collecting video information
- Source Video: MPEG-2, 1920x1080
- Rate/Length: 23.976fps, 240 frames
- [15:38:46] Reencoding: VID_00019, Pass 1 of 1
- [15:38:50] Video Encode complete
- [15:38:50] Reencoding audio tracks (if req'd)
- [15:38:51] Multiplexing M2TS
- [15:38:51] Extracting A/V streams [VID_00127]
- [15:38:52] Reencoding: VID_00127 (2 of 10)
- [15:38:52] Collecting video information
- Rate/Length: 23.976fps, 365 frames
- [15:38:52] Reencoding: VID_00127, Pass 1 of 1
- [15:38:58] Video Encode complete
- [15:38:58] Reencoding audio tracks (if req'd)
- [15:38:58] Multiplexing M2TS
- [15:38:59] Extracting A/V streams [VID_00062]
- [15:39:02] Reencoding: VID_00062 (3 of 10)
- [15:39:02] Collecting video information
- Rate/Length: 23.976fps, 699 frames
- [15:39:02] Reencoding: VID_00062, Pass 1 of 1
- [15:39:13] Video Encode complete
- [15:39:13] Reencoding audio tracks (if req'd)
- [15:39:13] Multiplexing M2TS
[15:39:15] - Failed to build structure, aborted
spinn is offline   Reply With Quote
Old 26th October 2010, 03:09   #9949  |  Link
john920
Grindhouse audio issues
tried to backup the new grindhouse blu-ray it failed on the last video during audio extraction
[19:27:44] BD Rebuilder v0.35.01 (beta)
- Source: GRINDHOUSE_BD_D1
- Input BD size: 41.72 GB
- Approximate total content: [03:12:12.229]
- Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[19:27:47] PHASE ONE, Encoding
- [19:27:47] Extracting A/V streams [VID_00002]
- [19:27:51] Reencoding: VID_00002 (1 of 3)
- [19:27:51] Collecting video information
- Rate/Length: 23.976fps, 1,404 frames
- [19:27:51] Reencoding: VID_00002, Pass 1 of 1
- [19:28:22] Video Encode complete
- [19:28:22] Reencoding audio tracks (if req'd)
- [19:28:22] Multiplexing M2TS
- [19:28:24] Extracting A/V streams [VID_00004]
- [19:38:57] Reencoding: VID_00004 (2 of 3)
- [19:38:57] Collecting video information
- Rate/Length: 23.976fps, 131,119 frames
- Bitrate: 14,818 Kbs
- [19:38:57] Reencoding: VID_00004, Pass 1 of 2
- [20:47:20] Reencoding: VID_00004, Pass 2 of 2
- [01:22:27] Video Encode complete
- [01:22:28] Reencoding audio tracks (if req'd)
- [01:22:28] Multiplexing M2TS
- [01:27:35] Extracting A/V streams [VID_00009]
- Extracting video streams [VID_00009]
- Extracting audio streams [VID_00009]
- Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: E:\GRINDHOUSE_BD_D1\BDMV\STREAM\00009.m2ts
[01:42:23] - Failed to retrieve audio, aborted
after the fail I uninstalled, restarted and reinstalled ffdshow, Matroska Splitter and AVISYNTH tried again and got this result:
[20:31:12] BD Rebuilder v0.35.01 (beta)
- Resuming from previously started job.
[20:31:13] PHASE ONE, Encoding
- [20:31:13] Extracting A/V streams [VID_00009]
[20:45:46] - Failed to retrieve audio, aborted
john920 is offline   Reply With Quote
Old 26th October 2010, 14:26   #9950  |  Link
Dirk Diggler
Try deleting your WORKFILES folder and restart the job from scratch
Dirk Diggler is offline   Reply With Quote
Old 26th October 2010, 20:22   #9951  |  Link
scifiste
Overzealous firewall/malware protection
To answer my own post it was nothing to do with BD Rebuilder.
It worked perfectly when i ran in safe mode, so i suspect an overzealous firewall/malware program is to blame.
I use Comodo which has recently updated to new version so i will investigate the options.
Old 26th October 2010, 22:58   #9952  |  Link
Ch3vr0n
It is comodo's heuristic scanner thats causing the issues. Its been diagnosed in a thread somewhere but can't find it. Uninstall comodo and your problem will be fixed.
Old 27th October 2010, 19:41   #9953  |  Link
stage_man
ps3 problem
I am having an issue with getting a dvd-9 full backup to play on my ps3. It's playing on my samsung bd-c5900 with no issue, but in the ps3 it is showing as a data disc and can only click through the folders. I have made movie only dvd-9's and full backups to bd-25 with no problems. Any ideas?
stage_man is offline   Reply With Quote
Old 27th October 2010, 22:14   #9954  |  Link
SoniG
SoniG's Avatar
Jdobbs : I've just rebuilt the PIXAR Shorts Vol.1 and I have another .mpls issue. This BD have original IN time at 10:00:000 instead of habitual 00:00:11.650, the rebuilded mpls have the OUT TIME set with 00:00:11.650 more than the original. It makes playing shorts 11s longer than its original and the original m2ts real duration and could cause issues on some players.
Old 28th October 2010, 20:38   #9955  |  Link
RCF
Hello jdobbs,
Is it possible to back up my 3D Blu-ray movies (Alice in Wonderland 3D and Avatar 3D) to a BD25? BD Rebuilder tells me that the destination is too small.
Thanks,
RCF
RCF is offline   Reply With Quote
Old 28th October 2010, 21:38   #9956  |  Link
Ch3vr0n
3D blu-rays cannot currently be processed by BDRB due to the complex nature of 3D discs. Only a 1:1 backup is possible
Old 28th October 2010, 22:09   #9957  |  Link
omegaman7
omegaman7's Avatar
So then the modern 3-d blu rays are different. Different than Coraline, and predecessors? Which suggests the 3-d and video data are separate entities?
Old 29th October 2010, 01:37   #9958  |  Link
Ch3vr0n
Yes and no, the current modern 3d discs do not use the anaglyph technology. They use 1 video stream, however the stream gets duplicated and shifted a little for the right eye. Resulting in 1 stream for each eye. The exact mechanics that tell a player how to play the 3d discs is in the java engine and related bd file structures. If you were to rip a 3d disc to folder structure you'd end up with a folder of approx 90GB (if it was a full sized BD50), kinda similar how structural protection acts on DVD's. The only way you currently can back up a 3d disc is rip it to ISO (as this keeps the file structure intact), and then burn it to a blank matching in size.
Old 29th October 2010, 05:29   #9959  |  Link
omegaman7
omegaman7's Avatar
Ahhh, yep yep. Thanks for that
Old 29th October 2010, 16:18   #9960  |  Link
buerste3
Windows 64 bit!!
Hey guys.
I`m from germany, sorry for my english
I will use windows 7 / 64 bit version.
Can anyone tell me, what program version i need for avisynth, haali media splitter and ffdshow, that bd rebuilder works fine??
Links are great
buerste3 is offline   Reply With Quote
