Old 13th May 2011, 08:36   #201  |  Link
JoeH
Lagarith generally compresses a little more, but UT is much, much, much faster than Lagarith, both at encoding and especially at decoding.
JoeH is offline   Reply With Quote
Old 13th May 2011, 13:48   #202  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Originally Posted by 3ds View Post
OK, than should Ut generally better compress than Lagarith?
No.
UT uses Huffman coding for entropy encoding algorithm similar huffyuv.
On the other hand, Lagarith uses RangeCoder.
RangeCoder does better (but slower) compression than Huffman.
(This is the same as the difference between zip and 7zip.)
Umezawa was talking that RangeCoder is scheduled to be introduced into UT on his blogpost before.
however, no one(included Umezawa) knows when it comes.
my repositories
Chikuzen is offline   Reply With Quote
Old 9th June 2011, 02:26   #203  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
I'm having trouble using the latest version of UTVideo. I upgraded from v7.1 (first post of this thread) to v9.0 from the author's website. However, I can't find the new version listed in VirtualDub, nor can I successfully connect any pins to it in GraphStudio. I see that sometime in v8.x the VfW frontend was moved to a separate DLL, so perhaps that has something to do with this. Regardless, I have been forced to continue using the old v7.1 release. Any help on this issue would be appreciated.
Stephen R. Savage is offline   Reply With Quote
Old 9th June 2011, 04:11   #204  |  Link
Boolsheet
Yep, the vcm driver entry point moved from utvideo.dll to utv_vcm.dll with one of the updates.
You could search the registry if there's something still pointing to utvideo.dll. Here's where it is usually located:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Drivers32 (for 32-bit applications on win64)
I don't use the installer myself so I can't say if this is an error and the installer forgets to delete/change the old entries.
My nightmares are horrifying, they're all interlaced!
Boolsheet is offline   Reply With Quote
Old 28th June 2011, 21:31   #205  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
version 9.0.1
read me / installer (32bit)(64bit) / source
Bug fixes:
- DMO decoder returns inconsistent formats when enumerates output formats.
Mr_Khyron is offline   Reply With Quote
Old 4th August 2011, 15:39   #206  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Version 9.0.3 available
Version 9.0.3
Bug fixes
ULY2: DMO encoder does not accept the format that is suggested by itself when the input format is not RGB24/32.
ULY0: DMO encoder does not accept the format that is suggested by itself when the input format is not RGB24/32.
Others
DMO encoders and decoders now does not check some part of input/ouput formats.
my repositories
Old 9th August 2011, 10:12   #207  |  Link
smok3
brontosaurusrex
smok3's Avatar
q1: on 64bit win7 i would install 32 and 64 bit version to get in/out workflow between 32bit virtualdub/avisynth and 64bit premiere 5.5, or .... ?
q2: would there be a massive difference between 32bit version versus 64bit version with virtualdub 32/64?
certain other member
smok3 is offline   Reply With Quote
Old 9th August 2011, 14:38   #208  |  Link
patrick_
q1: yes
patrick_ is offline   Reply With Quote
Old 27th August 2011, 18:38   #209  |  Link
smok3
brontosaurusrex
smok3's Avatar
q3: is there a mac version?
Old 4th September 2011, 13:10   #210  |  Link
mp3dom
Version 8.5.0 is the latest that I am able to use. All other new versions simply doesn't appear in VDub (and After Effects, for example) as available codecs (for both x86 and x64). I've checked that path and it points to the exact dll (utv_vcm.dll). Also the dll is physically present. The decoder strangely works with WMP and GraphEdit. Any suggestion?
mp3dom is offline   Reply With Quote
Old 4th September 2011, 22:21   #211  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Any suggestion?
Yes — unpack the .msi file with "Universal Extractor", copy the DLLs to an 8.3-named folder (e.g., "UTVID903"), rename 'utv_vcm.dll' to 'utvid903.dll', create the file "utvid903.INF"
; UT Video Codec Suite 9.0.3
[Version]
Signature="$CHICAGO$"
Class=Media
[DefaultInstall]
CopyFiles=utvideo.Files.Inf,utvideo.Files.Dll
AddReg=utvideo.AddReg
UpdateInis=utvideo.UpdateIni
MediaType=SOFTWARE
[DefaultUnInstall]
DelFiles=utvideo.Files.Inf,utvideo.Files.Dll,utvideo.Files.Pnf
DelReg=utvideo.AddReg
UpdateInis=utvideo.UpdateIni.Del
[SourceDisksNames]
1="UT Video Lossless Codec 9.0.3","",1
[SourceDisksFiles]
utvid903.inf=1
utvid903.dll=1
utvideo.dll=1
[DestinationDirs]
utvideo.Files.Inf=17    ; windows\inf
utvideo.Files.Dll=11    ; windows\system
[utvideo.Files.Inf]
utvid903.inf
[utvideo.Files.Dll]
utvid903.dll
utvideo.dll
[utvideo.Files.Pnf]
utvid903.pnf
[utvideo.UpdateIni]
system.ini, drivers32,,"VIDC.ULRA=utvid903.dll"
system.ini, drivers32,,"VIDC.ULRG=utvid903.dll"
system.ini, drivers32,,"VIDC.ULY0=utvid903.dll"
system.ini, drivers32,,"VIDC.ULY2=utvid903.dll"
[utvideo.UpdateIni.Del]
[utvideo.AddReg]
HKLM,Software\Microsoft\Windows NT\CurrentVersion\Drivers32,VIDC.ULRA,,"utvid903.dll"
HKLM,Software\Microsoft\Windows NT\CurrentVersion\Drivers32,VIDC.ULRG,,"utvid903.dll"
HKLM,Software\Microsoft\Windows NT\CurrentVersion\Drivers32,VIDC.ULY0,,"utvid903.dll"
HKLM,Software\Microsoft\Windows NT\CurrentVersion\Drivers32,VIDC.ULY2,,"utvid903.dll"
HKLM,Software\Microsoft\Windows\CurrentVersion\Uninstall\utvideo
HKLM,Software\Microsoft\Windows\CurrentVersion\Uninstall\utvideo,DisplayName,,"UT Video Codec Suite 9.0.3 (Remove Only)"
HKLM,Software\Microsoft\Windows\CurrentVersion\Uninstall\utvideo,UninstallString,,"rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 %17%\utvid903.inf"
For a Win32 machine, just right-click, install, enjoy
Old 7th September 2011, 01:50   #212  |  Link
Boolsheet
If you haven't seen it yet, JoeH had similar problems. Here's the post where he describes how he could fix it.
You can also extract msi packages with:
msiexec /a c:\utvideo-9.0.3-x86.msi /qb TARGETDIR=c:\utvideo_9.0.3\
Old 9th September 2011, 14:15   #213  |  Link
mempf
UT 8.5 and Newer crashes Adobe CS5.5
Hey, great work with the UT codec. However I am sad to report there seems to be a problem when Adobe CS5.5 Products like Media Encoder and Premiere.
When version 8.5 or newer is installed I often get random crashes at specific points in the video when using files as input into CS5.5. When using version 8.4 I have no problems what so ever.
Other players and encoders have no problem at all processing the exact same video and no crash occurs at the place it crashes in CS5.5. Even if I get a crash with 8.5 or newer I can uninstall it, reinstall version 8.4 and the crash will be gone. Update to version 8.5 or newer and the crash happens at the exact same place again.
Other people seem to have the same issue. http://forums.adobe.com/message/3839496 and http://forums.adobe.com/thread/885188 seem to document the issue as it occurs for me. For these people both the Lagarith codec and UT crashes in similar ways, I too have found this to be the case. Also with Lagarith reverting to an earlier version seems to fix the problems.
As mentioned rolling back to version 8.4 seems to resolve the problem at the cost of all improvements since 8.4. The most up to date UT codec version 9.0.3 seems to also crash CS5.5 in the exact same way so the problem is still ongoing.
These crashes only occur when when UT is the input format. Output format doesn't matter.
I'd be happy to provide any other information that may be needed to help debug this problem.
Thanks for making such a great codec and I hope this helps make it even better.
mempf is offline   Reply With Quote
Old 10th September 2011, 15:57   #214  |  Link
mp3dom
Thanks, resolved. It was a registry key referring to the old utvideo.dll Changing to utv_vcm.dll fixed the issue for both x86 and x64.
Old 10th September 2011, 16:00   #215  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
@mempf
a request from author to you .
please upload a small sample clip that cause crash with CS5.5.
my repositories
Old 10th September 2011, 22:53   #216  |  Link
mempf
Originally Posted by Chikuzen View Post
@mempf
I will try however, the nature of the problem is such that this is near impossible to do.
If I use just the section of a video that crashes, often the crash will be gone. The problem seems to occur most often with long big files.
This said I will try my best to create a clip which has the problem but is also short. This may take a while.
UPDATE:
I have had no luck in isolating a clip which causes the problem/crash. Every time I cut a section of the video which will cause a crash out, it will no longer cause a crash. I guess the length of the file and what comes after the problem spot is important. I will keep trying but I do not expect success. The other problem is that only video files of around 100GB seem to cause the crashes. This makes it very difficult/impossible to send a sample of the video.
Reproducing the problem shouldn't be harder than converting a long (like hour long) HD video to UT and then trying to have Adobe CS5.5 process or playback that file. I apologize for being unable to suggest anything else to replicate at this time.
Old 11th September 2011, 14:07   #217  |  Link
Midzuki
Unavailable
Midzuki's Avatar
As a suggestion to the author of the codec: use IExpress instead of the pesky MSI installer. Below is a sample SED file for the version 8.5.2 of UT Video:
[Version]
Class=IEXPRESS
SEDVersion=3
[Options]
PackagePurpose=InstallApp
ShowInstallProgramWindow=0
HideExtractAnimation=0
UseLongFileName=0
InsideCompressed=0
CAB_FixedSize=0
CAB_ResvCodeSigning=0
RebootMode=N
InstallPrompt=%InstallPrompt%
DisplayLicense=%DisplayLicense%
FinishMessage=%FinishMessage%
TargetName=%TargetName%
FriendlyName=%FriendlyName%
AppLaunched=%AppLaunched%
PostInstallCmd=%PostInstallCmd%
AdminQuietInstCmd=%AdminQuietInstCmd%
UserQuietInstCmd=%UserQuietInstCmd%
SourceFiles=SourceFiles
[Strings]
InstallPrompt=
DisplayLicense=
FinishMessage=UT Lossless Video Codec 8.5.2 has been installed successfully.
TargetName=C:\INSTALLS.DIR\UTVID852\utvideo-8.5.2-setup.exe
FriendlyName=UT Lossless Video Codec 8.5.2
AppLaunched=utvid852.inf
PostInstallCmd=<None>
AdminQuietInstCmd=
UserQuietInstCmd=
FILE0="utvcm852.dll"
FILE1="utvideo.dll"
FILE2="utvid852.inf"
[SourceFiles]
SourceFiles0=C:\INSTALLS.DIR\UTVID852\
[SourceFiles0]
%FILE0%=
%FILE1%=
%FILE2%=
Old 11th September 2011, 18:12   #218  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Version 10.0.1
Bug fixes:
(Windows) If "Save configuration globally by codec itself" in "Global Configuration" is checked, codec crashes at initialization.
Others:
(Mac) Changed base SDK from 10.6 to 10.5
10.0.0
New features:
Add QuickTime components for Mac OS X. Decoding to RGB24/ARGB32 are supported. Very slow.
Others:
Input/output format checking is more accurate.
Old 12th September 2011, 06:42   #219  |  Link
Boolsheet
Aw, version 10.0.0 runs into a pure virtual call for me.
It calls GetTinyName in the constructors of CULY0Codec and CUL00Codec.
0027e450 5b36354e utv_core!_purecall+0x25 [f:\dd\vctools\crt_bld\self_x86\crt\src\purevirt.c @ 54]
0027e4cc 5b363190 utv_core!CUL00Codec::LoadConfig+0x7e [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_core\ul00codec.cpp @ 88]
0027e530 5b367b78 utv_core!CUL00Codec::CUL00Codec+0x70 [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_core\ul00codec.cpp @ 17]
0027e58c 5b367d87 utv_core!CULY0Codec::CULY0Codec+0x18 [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_core\uly0codec.cpp @ 37]
0027e5fc 5b358ae8 utv_core!CULY0Codec::CreateInstance+0x47 [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_core\uly0codec.cpp @ 46]
*** WARNING: Unable to verify checksum for C:\Windows\SysWOW64\utv_vcm.dll
0027e768 5b41998b utv_core!CCodec::CreateInstance+0x88 [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_core\codec.cpp @ 67]
0027e978 5b419dd3 utv_vcm!CVCMCodec::CVCMCodec+0x9b [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_vcm\vcmcodec.cpp @ 18]
0027ea94 5b4194ea utv_vcm!CVCMCodec::Open+0xd3 [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_vcm\vcmcodec.cpp @ 51]
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Windows\SysWOW64\MSVFW32.dll -
0027eb94 5c7d18f6 utv_vcm!DriverProc+0x14a [e:\utvideo-10.0.0-src\utvideo-10.0.0\utv_vcm\driverproc.cpp @ 27]
WARNING: Stack unwind information not available. Following frames may be wrong.
0027ebb8 5c7d3abe MSVFW32!ICSendMessage+0x31
*** WARNING: Unable to verify checksum for C:\Windows\SysWOW64\AviSynth.dll
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Windows\SysWOW64\AviSynth.dll -
0027ee40 100a58d9 MSVFW32!ICOpen+0xe9
0027ee58 100a5dc5 AviSynth!DllCanUnloadNow+0x8ff49
0027ef24 774e125a AviSynth!DllCanUnloadNow+0x90435
Does it work for other people?
Edit: Version 10.0.1 was released and fixed the issue.
Old 24th September 2011, 01:29   #220  |  Link
SirLagsalot
The Lagarith crash was caused by a 1-byte overrun when reading the compressed data. Adobe apparently allocates EXACTLY the minimum size necessary for the compressed frame, so read overruns will cause crashes if the overrun happens to cross a page boundary. Since the UT crash seems to be similar, I would look for potential read overruns in the decoder.
SirLagsalot is offline   Reply With Quote
