4th May 2020, 07:55 | #59441 | Link | |
Set your display to 23 Hz (it's the windows name for 23.976).
Charky "Rule #1 : If it works, don't change anything." |
4th May 2020, 08:32 | #59442 | Link |
At default 23 Hz you will still get a repeated frame every ~4.5 minutes. You have to create a custom resolution to get it right. Using CRU, I set it at 23.975 Hz, which gives me 23.97585 Hz. This produces a frame drop every ~56.5 minutes, which is the best I can get.
I have been using ReClock for years, but recently I kept seeing random frame drops which did not register on the madVR OSD. I decided to test the custom resolution with bitstreaming, which will be useful when I upgrade my audio setup (waiting for HDMI 2.1). So far I am pretty happy with the change. |
4th May 2020, 08:54 | #59443 | Link | |
4th May 2020, 09:19 | #59444 | Link | |
Gaming-PC: AMD 7700X | RTX 4070 Ti | ASUS ROG Strix X670E-E Gaming WIFI | G-Skill RGB 32GB, DDR5-6000 | Corsair HX1200 | Lian Li Air Mini | |
4th May 2020, 09:25 | #59445 | Link |
These beta versions are supposed to be unpacked on top of the last release version - files which didn't change are not included.
4th May 2020, 14:43 | #59447 | Link | |
8gb is enough, as long as it's dual channel. Run 8bit 444 RGB Full, don'tuse 12bit on the jvc. Run the 3D lut for SDR lut, select source colorspace dci-p3 or rec2020. Before calibration, check that the gamma mode/setting from measurement that it's in is Close to flat 2.2gamma @ 6500k.
Ghetto | 2500k 5Ghz |
4th May 2020, 16:59 | #59448 | Link | |||
Thanks! Quote:
Any reason NOT to use 12bit with the RS520? From reviews I read it actually does 12 bit even if due to other things it ends up being 10bits. Just curious as to why this recommendation. Ok I am going to try the 3D Lut to see what I get. I did watch Star Wards yesterday and it was looking stunning, so much better than when I was using the projector HDR mode. Thanks so much! |
4th May 2020, 17:12 | #59449 | Link |
4th May 2020, 20:10 | #59458 | Link | |
If not, I can just roll with what I have as it is with the Nvidia control panel custom resolution that get some close to 23.976 |
4th May 2020, 20:28 | #59459 | Link |
This is what you need to do in CRU, it is very simple. Make sure you export the original EDID first, in case you mess something up.
You can basically delete everything in "Detailed resolutions" and add the ones you need. You should only have two or three in there (but even the third one might not work sometimes). Most of common resolutions are stored in the extension blocks, so you will not lose anything by doing this. Resolutions you add here will appear as PC resolutions in the nvidia control panel. 23.975 works best in my case, it could be different in yours. Experiment. 12-bit works with this method, unlike custom resolution in the nvidia control panel. |
4th May 2020, 20:41 | #59460 | Link | |
I will try that and report back. Thank you so much! |
