24th January 2022, 02:07 | #62681 | Link |
Why when I use http://madshi.net/madVRhdrMeasure145.zip it has HDR without enabling AMD/OS TV HDR?? but it uses 8bit. and 0.92.17 works fine with HDR detect and 10bit? using Potplayer
24th January 2022, 14:43 | #62682 | Link |
MPC-HC Developer
Can you elaborate? It is good time to voice concerns. But looking at it, it's going really well and madshi has clear plan to consolidate and agree on proper settings. Let's hope he will have enough spare time to keep at it
24th January 2022, 16:23 | #62683 | Link |
I think I missed that some trade quality options were set for HDR. With them unchecked, it actually looks really good (now build 146). The difference between targeting for BT.709 and pure power display gamma curve is btw. very distinct ("display already calibrated" via clamping/calibrating with novideo_srgb).
24th January 2022, 18:44 | #62684 | Link |
would also be cool to have madvr integrate vulkan rendering ...surely should give big boost in performance
btw still havent figured out how to have BT2020 primaries be autoforced on playback start ...besides using a hotkey ...which sucks |
25th January 2022, 00:21 | #62685 | Link |
look up profiles.
vulkan is not plain faster than DX9. it's different madVR uses mostly shader and these don't benefit massively from vulkan which uses a completely different shader language so everything has to be rewritten for most likely small gains at best. there are reasons to do that for feature like dx12 or at least 11 but this is a lot of work. |
25th January 2022, 21:34 | #62687 | Link |
Iīm running with serious trouble with dolby atmos passthrough using madvr and mpc-hc/mpc-be. If I donīt seek (forward or backward) the audio runs smoothly for about 10min, but whenever I seek the movie it starts skipping and stuttering. Iīve tried almost everything, even a windows 10 and 11 (normal and lite versions) fresh installs. Iīve tried lav audio and mpc audio (mpc-be). The video runs smoothly no drop/rep/glich. It works fine with other audio sources (Dolby Digital+, DTS-HD). It looks like its loosing sync. Anyone can help me ? Do you think itīs something related to hdmi cable quality ? Thanks.
26th January 2022, 04:32 | #62688 | Link | |
https://github.com/Nevcairiel/LAVFilters/releases |
26th January 2022, 17:24 | #62690 | Link | |
Did u have the same issues ? Iīve already tried both latest stable and nightly lav builds. No luck. |
28th January 2022, 05:07 | #62693 | Link |
Have changed over to new HDMI cables and have MadVr145 going. I have unticked every performance saving option and now I'm getting lots of audio drop outs on this file.
General Unique ID : 147447891194989394090149118539767442042 (0x6EED6E4EBC7380B57C68AF58A0AB6A7A) Complete name : D:\TV Series Keepers\Yellowstone (2018)\Season 4\Yellowstone (2018) - S04E10 - Grass on the Streets and Weeds on the Rooftops WEBDL-1080p.mkv Format : Matroska Format version : Version 4 File size : 5.10 GiB Duration : 1 h 16 min Overall bit rate : 9 582 kb/s Writing application : mkvmerge v58.0.0 ('Supper's Ready') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 16 min Bit rate mode : Constant Bit rate : 9 197 kb/s Nominal bit rate : 10 000 kb/s Width : 1 920 pixels Height : 960 pixels Display aspect ratio : 2.000 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.208 Stream size : 4.89 GiB (96%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 1 h 16 min Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 209 MiB (4%) Language : English Service kind : Complete Main Default : Yes Forced : No Using latest NVidia on a 1060GTX. Latest MPC-HC and latest LAV. Keep in mind that the audio drop out occurs in KODI too which uses it's own internal pathways. |
28th January 2022, 15:38 | #62694 | Link |
Iīve finally found out the solution to my case. I think itīs related to the "hdmi arc cycle". In my setup the vga hdmi out is connected to the LG OLED TV and then the HDMI ARC of the TV to the AVR. I think itīs causing the delay. My solution was to use a secondary connection from my vga to the AVR (direct connection), set the resolution to 720p and use it as an extended display. After that I set the default audio to the AVR connection (secondary). Now the audio problems are totally gone.
28th January 2022, 16:03 | #62695 | Link |
the ARC port will only come into play and affect audio coming from your TV, it should not affect audio coming from your HTPC, i'm also using an LG OLED TV from 2015 and I have no issues with ATMOS.
28th January 2022, 19:58 | #62697 | Link | |
VGA HDMI 1-> LG OLED C1 -> AVR (VIA ARC) My solution: VGA HDMI 1 -> LG OLED C1 (AUDIO DISABLED) VGA HDMI 2 -> AVR (EXTENDED AND AUDIO DEFAULT) I know thereīs a route 3 (VGA -> AVR -> TV) but my AVR is not dolby vision compatible. |
29th January 2022, 00:52 | #62698 | Link |
Hi, I dont think that is right, I have mine setup as follows.
ARC port on TV is connected to ARC port on receiver, then receiver input is connected to pc.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions Last edited by mclingo; 30th January 2022 at 00:12. |
