4th November 2019, 10:37 | #721 | Link | |
Because its actually smart and fully adapts to the input signal, I've never had to change the range config in the screen, and if I change in the control panel from full to limited the visual look doesn't change because it auto-adapts. HDMI has all the image properties in metadata, unfortunately the majority of TVs quite simply ignore it and expect some default mode.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th November 2019 at 10:39. |
4th November 2019, 10:47 | #722 | Link |
not saying your screen doesn't but the only ways for a screen to change a setting in the nvidia control panel is by pretending to be a new different screen or by HDMI content type which is again not properly supported. there is a very good reason not to do that.
auto level support is not that rare but not the point what nvidia choices to send. |
4th November 2019, 16:27 | #723 | Link | |
TV :LG OLED 65CX ; PC: CPU: Ryzen 9 3950X @43.25GHz ; GPU: Gigabyte GeForceŽ RTX 3080 GAMING OC 10G ;Memory: Corsair Vengeance RGB (2X16GB) DDR4 3600MHz, ; |
4th November 2019, 17:30 | #724 | Link |
I heard G-Sync shouldn't be used with madVR. It is designed for gaming, but brings trouble with madVR or general video playing, isn't it?
Should I leave the elevated level info on the two drivers or should I remove it, or maybe add only when using 12 bit if I understood it correctly. |
4th November 2019, 18:43 | #725 | Link | |||
edit: Found a new post: https://www.avsforum.com/forum/40-ol...l#post58773938 So Nvidia officially confirmed the black level bug and 441.12 is still affected, but it seems like it only affects LG OLEDs. Last edited by cremor; 4th November 2019 at 18:56. |
7th November 2019, 15:26 | #727 | Link | |
Core i7 6900K @ 4.3GHz Geforce GTX 2080 Ti 32GB RAM Windows 10 Pro |
9th November 2019, 14:48 | #729 | Link |
Hi!
Do you know if there an issue with the recent nvidia drivers when playing a HDR video with "Compromise on HDR tome & gamut mapping accuracy" unchecked? I was previously using Nvidia Driver 430.53 for my GTX 1070 and everything was fine when I played a HDR file (mpc-be with madvr "Compromise on HDR tome & gamut mapping accuracy" unchecked | SDR monitor) I have updated the drivers to 436.48, and now when I play a HDR file the image is nearly completely dark. If I check "Compromise on HDR tome & gamut mapping accuracy" the image is watchable again. But of course I'd prefer not compromise on HDR tome & gamut mapping accuracy. madvr version is the latest one available on avsforum. Thanks in advance. |
9th November 2019, 15:20 | #730 | Link | |
I use the latest nVidia driver and there is no issue with that option. Just disable all measurements files in the configuration section at the end of MadVR settings. They are not supported with the latest test builds. If you don't use measurements files, then it might be something else, but it's not the driver.
9th November 2019, 17:53 | #732 | Link | |
I didn't get the news about the measurements files. Change occurs so fast with MadVR beta in the "other forum" so it is very easy to miss relevant info. Regards |
10th November 2019, 20:09 | #733 | Link |
I wonder if the recent issues with the Nvidia drivers are what I'm experiencing too. I'm unable to watch any HDR content using RGB at all. No matter what I do, the black levels wash out. Instead, I have to switch to ycbr 4:4:4, 12-bit, limited to maintain correct black levels, which I'm sure is less than ideal.
I think this all happened after a Windows update, but I'm not entirely sure. Unfortunately, on my Vizio PQ65, I'm only able to change color space manually, and not video levels. Sucks when you have everything setup just right, and some crap Windows update ruins things. If any of you have any suggestions, as to how I can better work around this issue, please let me know. I saw someone mentioned having to choose "PC" resolutions instead of the UHD stuff, but that category of resolutions doesn't show up in NVCP. |
11th November 2019, 01:37 | #734 | Link |
"Color Space" in the Vizio picture menu should be set to "RGB." That is all I know. I don't know if that setting currently exists on the newest Vizio models, though.
11th November 2019, 11:52 | #736 | Link |
This is with the Nvidia control panel set to output RGB 0-255?
Maybe the display now has some type of levels adjustment?
15th November 2019, 10:36 | #739 | Link |
AMD got a new driver too: https://www.amd.com/en/support/kb/re...ad-win-19-11-2
the changes are minimal at best. i will test DXVA2 stuff later. edit: DXVA2 levels are broken deint is still broken i don't test dxva2 native decode anymore until they fix the very obvious stuff. Last edited by huhn; 15th November 2019 at 13:51. |
15th November 2019, 18:50 | #740 | Link | |
The other players should comply to AMD, according to AMD.
