14th May 2013, 02:29 | #81 | Link | ||
契約者
The point is that after I saved gradient in webp with max quality, cause of subsampling or some other thing it looks bad compared to jpeg. This is exactly my thoughts too: Quote:
14th May 2013, 11:55 | #82 | Link | |
So you'd expect it to do better on typical web icon type images rather than photos (and it does: http://extrememoderate.wordpress.com/2011/11/28/a-web-centric-image-compression-benchmark/). This is a fairly direct consequence of WebP in general being designed around making web images smaller and faster. If you've got a photorealistic image then the fastest, most efficient way to deliver it in a webpage is using lossy compression. Last edited by dapperdan; 14th May 2013 at 11:56. Reason: link URL |
14th May 2013, 18:52 | #85 | Link |
SuperVirus
Hummm, I use Opera 11.64, and it supports only "normal" WebP. Lossless and lossy-with-alpha-channel get replaced with a placeholder : - / And no, "full WebP support" is not a good reason for switching to Chrome/Chromium. |
14th May 2013, 20:27 | #88 | Link | |
HEVC promises to be a very good still image format, particularly at high resolutions. Getting support for arbitrary bit depths and channels would be great for all these formats, of course, so they could be used for RAW Bayer pattern and that sort of thing. I wish JPEG XR had taken off... |
14th May 2013, 23:06 | #90 | Link |
Here's what I know about VP9 coding tools.
64x64 "superblocks". Each divisible vertically, horzontally or quad. Quad divisions are recursive, so you can have any shape NxM, where N and M are 2^(2..6), and never more than 1 power apart (e.g. 4x4, 16x32, 8x4, 64x64 ... etc). 128x128 support is on the table, but undecided. 4 supported transforms: 4x4, 8x8, 16x16, 32x32. Yes this is the same as HEVC. 10 intra modes at any square size. 6 of these are directional. 1/8th pel motion comp, 8-tap filters. 3 filters (normal, blur, sharpen), selectable per prediction unit or frame. 3 ref pics per pic, but up to 8 pics to hold on to. Discrete sine transform for intra blocks. A second loop filter (analogous to SAO in HEVC) is under experimentation. Bitstreams are still "data paritioned" like vp8, which is a pain for HW designs. Entropy coding is similar to vp8. Support for tiles, like HEVC, for parallel decode. Mandated above 2k resolution. Support for lossless coding, as well as 4:4:4 with alpha. The picture is still single-loop decodable to make HW implementations simpler. |
15th May 2013, 03:26 | #91 | Link |
http://www.androidauthority.com/webm...outube-209088/ (Let's try to keep this thread WebM-wise and not another H.26x one.)
16th May 2013, 08:52 | #93 | Link |
User of free A/V tools
Awesome comparison! (Not!) If only they published what settings were used for H.264: Profile, Level, CABAC/CAVLC, ref-frames, B-frames, frame resolution, rate etc. etc.
Otherwise it's plain marketing rubbish, nothing more. |
16th May 2013, 09:11 | #94 | Link |
It was a quick video show in a keynote, of course its marketing. There is no time in such an event for technical details.
16th May 2013, 09:16 | #95 | Link |
契約者
They won't benefit from showing something like this Looks like On2 guys taught them how to do the marketing.
16th May 2013, 09:49 | #96 | Link |
The had a VP9-focused session directly after the keynote:
https://developers.google.com/events/io/sessions/325741299 But it's not one of the sessions being broadcast/recorded. I assume they'll post the slides though. edit: a news story based on the presentation http://news.cnet.com/8301-1023_3-57584706-93/google-urges-fast-adoption-of-vp9-video-compression/ Best bits: They claim VP9 saves ~50% bandwith compared with H.264 and is ~1% worse than H.265 There's a VP9 test channel: http://www.youtube.com/user/WebMVP9/videos And apparently you can turn on VP9 in Chrome today to view them. Last edited by dapperdan; 16th May 2013 at 10:01. |
16th May 2013, 13:28 | #98 | Link | |
The Crazy Idahoan
Ummm... wow, that is pretty terrible quality. Grass is just one giant blob. Everything is VERY blocky, reminds me of the old xVid days. It is just really, well, terrible. IDK, maybe the source video was this bad, but man, if they were trying to sell VP9 this video does them no favors. |
16th May 2013, 13:42 | #99 | Link | |
I just tried converting Dark Shikari's avatar to WebP with XnView. Here is the result: This is original: And that was converted with the best quality setting which suppose to be lossless. I also tried converting with WebP plugin for Photoshop. It produced the same result with slightly smaller filesize. Last edited by mk.2; 16th May 2013 at 14:03. |
google, ngov, vp8, vp9, vpx, webm |
