18th January 2018, 13:55 | #15401 | Link |
why???
18th January 2018, 15:21 | #15402 | Link |
Hello Atak,
I recently installed the updated version of Ripbot264. Ever since, when I'm trying to encode, I get an error popup that says: ffmpeg.exe has stopped working Thoughts on how to correct this? Everything I look up online says it's an issue with firefox, but it only happens when I'm encoding. Thanks |
18th January 2018, 16:11 | #15404 | Link | |
ByteShare
At wait point exactly are you getting the FFMPEG error? For me in DE mode, turning the server off, closing the error and starting it again usually works, but on the most recent version there is a method that should be doing this automatically. |
18th January 2018, 16:24 | #15405 | Link | |
18th January 2018, 17:48 | #15406 | Link | |
18th January 2018, 21:14 | #15409 | Link | |
ByteShare
Assuming you mean an FFMPEG error on the PC with the Encoding Client on it (manage the encoding servers)? You said it happens on the encoding server to, do you mean just in the encoding log or an actual FFMPEG error popping up? |
19th January 2018, 05:15 | #15411 | Link | |
I should get it automatically, if enabled, and you're connected to the "net" !!! |
19th January 2018, 23:36 | #15416 | Link |
Is it possible to control the among of thread on each server using DE ?
I use 3 machines to encode some UHD disc. Ryzen 7 (8 core, 16 threads) and an old Intel Core I7-4770k (4 core, 8 threads) and a Core I7-6700HQ (4 core, 8 threads). The problem is that MDegrain dosnt like hyperthreading. I tried to encode a chunck manually using 8 or 16 threads on my Ryzen 7. 8 threads (video=Prefetch(video,8)) gave me 3fps, but with 16 threads video=Prefetch(video,16) it gave me half fps. I can limit the number of threads to 8 when using MDegrain filter. But I would like to limit it to 4 threads on my Core I7-4770k and my I7-6700HQ. The temperary aproach is to set limit at 4 threads and then use 2 servers on my Ryzen. But it would be nice if I could specfify it on a server level, then I could mix more servers with differnt cores and still get the best out of them. Update: Not sure its MDegrain. I think its MT part that dosnt run better when using the hyperthreads, looks like it runs faster with just using the among of threads that matches the core. Maybe too much waiting time between threads when using 16 threads. Update2: Maybe just an option to only use real cores and not hyperthreading for the MT part of AVS script. It did run better and faster on all my machines with just limiting the number og threads to the actual number of cores on the cpu. Last edited by GZZ; 20th January 2018 at 10:11. |
20th January 2018, 00:59 | #15417 | Link | |
So -- is there a location to pick up the latest version? |
20th January 2018, 07:58 | #15418 | Link | |
I got java 8 Update 151 installed, I think its the 32bit version, even though I run 64bit windows. I downloaded it from java.com and works out of the box with ripbots. |
20th January 2018, 15:33 | #15419 | Link | |
MDegrain2 + Prefetch(16) MDegrain2 + Prefetch(8)
20th January 2018, 19:12 | #15420 | Link |
Still working on "Java not installed" error on my Windows 10 64-bit system (running as Standard User)...
• My RipBot264 version is v1.22.0.7 • I can't find where to download the latest version, which is listed as having a fix for this. • "Update" won't fetch the latest version because the program never gets to the point where I can enable that. • I think Java 32-bit is installed on my PC, based on the following evidence from the registry, folders found, and command prompt output (except for one folder not found): ===================== REGISTRY Computer\HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment has CurrentVersion = 1.8 Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\JavaSoft\Java Runtime Environment has CurrentVersion = 1.8 ===================== FOLDERS found with Java components: C:\Program Files\Java\jre1.8.0_151 C:\Program Files (x86)\Java\jre1.8.0_152 BUT THIS FOLDER NOT FOUND: C:\Windows\SysWOW64\java.exe ===================== COMMAND PROMPT: Microsoft Windows [Version 10.0.16299.192] (c) 2017 Microsoft Corporation. All rights reserved. C:\Users\[my user name]>java -XshowSettings:all VM settings: Max. Heap Size (Estimated): 247.50M Ergonomics Machine Class: client Using VM: Java HotSpot(TM) Client VM Property settings: awt.toolkit = sun.awt.windows.WToolkit file.encoding = Cp1252 file.encoding.pkg = sun.io file.separator = \ java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment java.awt.printerjob = sun.awt.windows.WPrinterJob java.class.path = . java.class.version = 52.0 java.endorsed.dirs = C:\Program Files (x86)\Java\jre1.8.0_152\lib\endorsed java.ext.dirs = C:\Program Files (x86)\Java\jre1.8.0_152\lib\ext C:\WINDOWS\Sun\Java\lib\ext java.home = C:\Program Files (x86)\Java\jre1.8.0_152 java.io.tmpdir = C:\Users\[MyUserName]\AppData\Local\Temp\ java.library.path = C:\ProgramData\Oracle\Java\javapath C:\WINDOWS\Sun\Java\bin C:\WINDOWS\system32 C:\WINDOWS C:\ProgramData\Oracle\Java\javapath C:\Windows\system32 C:\Windows C:\Windows\System32\Wbem C:\Windows\System32\WindowsPowerShell\v1.0\ C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common C:\WINDOWS\system32 C:\WINDOWS C:\WINDOWS\System32\Wbem C:\WINDOWS\System32\WindowsPowerShell\v1.0\ C:\Program Files\Process Lasso\ C:\Users\[MyUserName]\AppData\Local\Microsoft\WindowsApps . java.runtime.name = Java(TM) SE Runtime Environment java.runtime.version = 1.8.0_152-b16 java.specification.name = Java Platform API Specification java.specification.vendor = Oracle Corporation java.specification.version = 1.8 java.vendor = Oracle Corporation java.vendor.url = http://java.oracle.com/ java.vendor.url.bug = http://bugreport.sun.com/bugreport/ java.version = 1.8.0_152 java.vm.info = mixed mode, sharing java.vm.name = Java HotSpot(TM) Client VM java.vm.specification.name = Java Virtual Machine Specification java.vm.specification.vendor = Oracle Corporation java.vm.specification.version = 1.8 java.vm.vendor = Oracle Corporation java.vm.version = 25.152-b16 line.separator = \r \n os.arch = x86 os.name = Windows 10 os.version = 10.0 path.separator = ; sun.arch.data.model = 32 sun.boot.class.path = C:\Program Files (x86)\Java\jre1.8.0_152\lib\resources.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\rt.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\sunrsasign.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\jsse.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\jce.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\charsets.jar C:\Program Files (x86)\Java\jre1.8.0_152\lib\jfr.jar C:\Program Files (x86)\Java\jre1.8.0_152\classes sun.boot.library.path = C:\Program Files (x86)\Java\jre1.8.0_152\bin sun.cpu.endian = little sun.cpu.isalist = sun.desktop = windows sun.io.unicode.encoding = UnicodeLittle sun.java.launcher = SUN_STANDARD sun.jnu.encoding = Cp1252 sun.management.compiler = HotSpot Client Compiler sun.os.patch.level = sun.stderr.encoding = cp437 sun.stdout.encoding = cp437 user.country = US user.dir = C:\Users\[MyUserName] user.home = C:\Users\[MyUserName] user.language = en user.name = [MyUserName] user.script = user.timezone = user.variant = Locale settings: OMITTED FOR BREVITY |
