29th October 2016, 08:39 | #2521 | Link |
Some help needed. I tried on my laptop windows 10 home edition to place in the system32 and systemwow64 folders the avisynth dll from the avisynthplus latest build. Both folders I got error messages from 7zip by which I am trying to extract. I tried deleting the older version manually, ( it disappeared from view alright) but 7zip still finds it and asks me whether I should replace. After yes, it again gives error. Now I do not find the older avisynth.dll in the system32 folder even if I search for it, but 7zip always finds the old one. What should I do?
In the zip file there are devil.dll in folders named system. Are these to be placed in plugins folders? |
29th October 2016, 09:18 | #2522 | Link |
Your confusion sounds like those of 64 bit system files being shadowed from 32-bit applications.
If you use a 32-bit 7-zip, it can only access the SysWOW64 folder, which is camouflaged as system32 for all 32-bit applications. Are you sure you use a 64-bit 7-zip? There are file managers which do not depend as much on the result of Windows system calls, but prefer showing the disk content as it is stored. Also they support privilege escalation if required to overwrite UAC protected files. Being old enough to have used the Norton Commander long ago, I enjoy the Far manager v3.0 in 64 bit in these days. It supports many archive formats internally, like a sub-directory, including 7-zip. And in addition, the 7-zip "extra" pack even provides an always up-to-date Far plugin. |
29th October 2016, 10:11 | #2523 | Link | |
Because if horizontaly the pixel may not be "related" according the format, they are always verticaly. But i agree that for planar modes probably improvements are possible. Don't forget that a lot of planar mode has been added since the original, so the choice of vertical only at the time may not have been a so bad idea. The actual situation is a progressive evolution from the original situation, not a rewrite from scratch. |
29th October 2016, 14:30 | #2524 | Link | |
30th October 2016, 12:13 | #2526 | Link |
I assume that you mean dgdecode, dgindex doesn't use Avisynth. Why don't you just try it?
Groucho's Avisynth Stuff |
30th October 2016, 14:42 | #2527 | Link | |
30th October 2016, 18:27 | #2528 | Link |
30th October 2016, 19:11 | #2529 | Link |
Pajas Mentales...
Groucho2004. the installer install the plugins dlls in root of C:/
https://sl1pkn07.wtf/paste/view/0bc0fb36 |
30th October 2016, 19:21 | #2530 | Link |
I can't reproduce that. I tested on XP32 and XP64. All good.
30th October 2016, 21:09 | #2533 | Link | |
Groucho's Avisynth Stuff Last edited by Groucho2004; 30th October 2016 at 21:15. |
31st October 2016, 00:53 | #2534 | Link | ||
TDecimate() in MT is still out of commission though - results in "TDecimate: major internal error. Please report this to tritical ASAP!" or "TDecimate: internal error during prebuffering" error messages. I just tried going back to r2172 and seeing what happens, and it's weird: last time I tried to use TDecimate() with MT, it threw basically the same errors as it does now. But this time using r2172, it ends up throwing the "Only a single prefetcher is allowed per script" error even if TDecimate() is commented out and only TFM() is called (using DGDecodeIM as source filter, of course). Not sure what accounts for this, I thought maybe I switched TIVTC builds or something (between tritical's and groucho2004's) but that wasn't it. So perhaps this is still progress, of sorts, as at least TFM() runs without the 'single prefetcher' error in r2294. In any case, yeah, TDecimate() is still out for MT as of now. |
1st November 2016, 21:19 | #2535 | Link |
I was so annoyed on missing array type variables and function parameters in Avisynth, that I had to experiment a bit.
I don't know if it breaks anything but I had to try that. Treat it as my fun part of the work. If you say that nobody will use it, I leave it out. If it breaks plugin compatibility, I will also undo it. Still have to work on it. This is already working:
clip=clip.ConvertBits(16) black_yuv_16 = Array( 0,32768,32768) white_yuv_16 = Array(65535,32768,32768) aSelectColors = Array(Array("black", black_yuv_16), Array("white", white_yuv_16)) test_array2 = Array(99, 1.0, "this is a string") # mixed types test_array = test_array2 n = ArraySize(test_array) # 3 clip = clip.SubTitle("Array size = " + String(n) +\ " [0]=" + String(ArrayGet(test_array,0)) + \ " [1]=" + String(ArrayGet(test_array,1)) + \ " [2]=" + ArrayGet(test_array,2)) black=blankClip(clip, length=1, colors = ArrayGet(aSelectColors,"black")) # value lookup by name white=blankClip(clip, length=1, colors = aSelectColors.ArrayGet("white")) # value lookup by name, another syntax #white=blankClip(clip, length=1, colors = Array(65535,32768,32768)) # or direct array |
1st November 2016, 22:01 | #2536 | Link |
I sure hope that you can get the arrays working without problems, Avisynth+/Standard are in dire need of built-in arrays. Good Luck.
Edit: string memory garbage collection really needs some attention too. Would still though have to comply with current SaveString (or whatever its called), only new plugs could use some alternative function to alloc mem and give [EDIT: total] ownership to avisynth. Mobile.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd November 2016 at 01:55. |
2nd November 2016, 01:11 | #2538 | Link |
String memory is only released when avisynth closes down. Strings allocated in functions (local) survive until 'the end', I was personally shocked when I discovered how greedy avisynth is on string memory.
Mobile. Edit: scriptclip can be terribly wastefull.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd November 2016 at 01:46. |
2nd November 2016, 01:17 | #2539 | Link | |
Avisynth language lover
This would require introduction of a new type-identifier (eg 'array') to rank alongside 'clip', 'int', 'float', etc in the function definition. Overall, your idea seems like a good one, but careful thought (which I haven't yet had time for) is required to ensure that it doesn't break anything or introduce language inconsistencies of some kind. |
2nd November 2016, 01:49 | #2540 | Link |
Ooooow, pinterf and the big G, both considering type Array, you guys got me excited
