26th April 2020, 13:02 | #5521 | Link |
Cleaned up and removed some earlier scripts.
YLevels script in post #5519 Updated, Added Levels originating source code:- https://forum.doom9.org/showthread.p...75#post1909075 Update, use scalef only if BitsPerComponent > 8 [and also avs+]. Made final clamp to colorspace range optional, uncomment a line to use explicit clamp, Masktools clamps anyway so not necessary, suggest leave in-situ [commented out] as documentation. EDIT: Original Levels source code, and YLevels script do not include any dithering [was I think added to levels in avs 2.60 Std final]. [ Maybe something for RF to think about ]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th April 2020 at 13:45. |
26th April 2020, 15:23 | #5522 | Link | |
I will add these changes as soon as possible dithering in 2.60 Std? it mean using lsb or some hack, so it's unlikely, unless you made it dll here are the all functions https://github.com/realfinder/AVS-St...Levels_mt.avsi edit: 255 scalef can be replaced with range_max
See My Avisynth Stuff Last edited by real.finder; 26th April 2020 at 15:27. |
26th April 2020, 16:11 | #5523 | Link | |
Did not know if some clever stuff could be done for dithering using Expr (I aint really ever looked at Expr).
If you need asistance with the other Didee funcs, let me know [but not just now, bit busy]. EDIT: I had thought about splitting the string into several parts wick1, wick2 etc, so could provide line wrap for subtitle, and append parts for the actual functionality, maybe you add it.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th April 2020 at 16:17. |
26th April 2020, 18:02 | #5524 | Link | |
The only thing that can be done for now is add stacked hack for avs 2.6
See My Avisynth Stuff |
26th April 2020, 18:04 | #5525 | Link |
speaking of expr()
pinterf, seems you forget about this https://forum.doom9.org/showthread.p...22#post1899122
26th April 2020, 19:34 | #5526 | Link | |
26th April 2020, 21:10 | #5527 | Link | |
also I forgot to mention that it work in HBD if you want
26th April 2020, 21:15 | #5528 | Link | |
It has a more futureproof coding style with even more in-Expr optimizations. But I think it would offer not real speed benefit at the moment. And since sekrit-twc is thinking about replacing the whole engine let's wait what magic can he do. It won't be a one-week job. |
26th April 2020, 21:34 | #5530 | Link | |
ColorBars(width=640, height=480, pixel_type="yv12") SoftSharpen SoftSharpen need mode 27, I will test mode 25 later
See My Avisynth Stuff Last edited by real.finder; 26th April 2020 at 21:44. |
26th April 2020, 21:57 | #5531 | Link |
Prove it that it cannot be replaced. Just because someone has put there mode 27 twenty years ago (o.k I'm probably exaggerating, but I hope you understand what I am trying to say in general) Experiment with new, maybe the replacements are even better.
26th April 2020, 22:23 | #5532 | Link | ||
and isn't using 17 with mask (if it can be done) to get 26 then 26 with another mask to get 27 will make it slower?
26th April 2020, 23:04 | #5533 | Link |
Acid fr0g
I saw you just released RGTools 0.99.
In the release note, you specify support for SSE2, SSE4.1 and AVX2. I still have Sandy Bridge, that supports AVX but not AVX2. Can you include this specific optimization too into your releases? Thanks!
@turment on Telegram |
27th April 2020, 01:08 | #5535 | Link | |
it should work even on RISC-V right?
27th April 2020, 01:28 | #5536 | Link |
It'd need the correct CPU defines in config.h so it could build, but otherwise, maybe? The actual thing you're looking at there is the ability to build a plain C version (with the right toggle in avs/config.h so that it can build on ARM), with the Intel intrinsics disabled. So hypothetically, in the state it's in, if it can be built, it should be able to run so long as it's under an OS it can already handle. But it'll be slow until intrinsics/asm for those platforms get added. And probably due to the reliance on some of the cpuid stuff, Prefetch will segfault, so right now it's single threaded and no asm assist on non-x86.
27th April 2020, 03:09 | #5537 | Link |
Impressive, Raspberry Pi yum yum.
27th April 2020, 05:50 | #5538 | Link | |
AVX is not for integer data. |
27th April 2020, 08:15 | #5539 | Link |
Over 100 x64 plugins, and counting!!!
Hi everyone, I just want to say thanks to all responsible for the continued work on AviSynth+. There are now over 100+ 64-bit plugins available to use and still a handful missing.
http://avisynth.nl/index.php/Category:Plugins_x64 |
