Old 3rd November 2015, 13:02   #21  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 2.4.8 and ffx264 2.6.8
* Use a single var to set the audio filters, in preparation for possible future extensions
Old 4th November 2015, 00:05   #22  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.9 and ffx264 2.6.9
* Made audio resampling optional
Old 21st November 2015, 22:00   #23  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.0 and ffx264 2.7.0
* Don't use dB for the volume filter
Old 26th November 2015, 18:42   #24  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.1
* Default params performance improvements. ONLY USE THIS VERSION IF YOU HAVE THE LATEST libx265/ffmpeg
Old 18th December 2015, 22:20   #25  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.2 and ffx264 2.7.1
* Add back using dB for the volume filter
Old 19th December 2015, 14:16   #26  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.3 and ffx264 2.7.2
* Added support for audio normalization using the Dynamic Audio Normalizer filter
Old 29th March 2016, 20:18   #27  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.4
* Support setting the MPlayer options
* Minor tweaks to the default x265 encoding options
ffx264 2.7.3
Old 16th May 2016, 13:23   #28  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.5 and ffx264 2.7.4
* Only use side channels for DTS encoder which doesn't support anything else
Old 21st May 2016, 03:20   #29  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.6 and ffx264 2.7.5
* Add audio channel metadata
Old 27th May 2016, 17:52   #30  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.7 and ffx264 2.7.6
* Don't rm config file upon update. Just move it to .ffhevc.old / .ffx264.old
* Add audio bitrate metadata
Old 30th May 2016, 14:10   #31  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.8 and ffx264 2.7.7
* Support asking for container format if the CON variable is not set in the config file
* Warn and exit if user chooses MP4/M4V container and DTS audio
* Some minor code improvements
Old 7th June 2016, 20:09   #32  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.5.9 and ffx264 2.7.8
* Added support for cover art for the MKV container
Old 8th June 2016, 05:55   #33  |  Link
smok3
brontosaurusrex
smok3's Avatar
Thanks for sharing, this will come handy. (I've been doing something similar (but much simpler), mostly various transcoders as tools/helpers for my daily editing needs. Also trying to be more modular this time, to avoid long spaghetti code.)
smok3 is offline   Reply With Quote
Old 8th June 2016, 11:23   #34  |  Link
microchip8
microchip8's Avatar
ffx264/ffhevc are pretty simple and small. I will keep them that way and will no longer go the h264enc way. The latter got too complex and big for my taste. With ffx264/ffhevc I try to add just the "enough" for me, what I require to encode bluray remuxes
Old 9th June 2016, 03:28   #35  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.0 and ffx264 2.7.9
* Warn and exit if user provides an unsupported image format for cover art
* Added support for nosound option to disable audio encoding
* Updated the README file
Old 15th June 2016, 03:05   #36  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.1 and ffx264 2.8.0
* Added the MOV container to the list of containers that don't support DTS audio
* Made the audio volume filter optional
Old 29th June 2016, 15:09   #37  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.2
* Tuning to the default encoding options
Old 30th June 2016, 14:24   #38  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.3
* Added support for the built-in x265 presets
* Added a -h|--help option
* Tuning to the default encoding options v2
ChangeLog for ffx264 2.8.1
* Added support for the built-in x264 presets
Old 3rd July 2016, 00:57   #39  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.4
* recursion-skip -> rskip to the default encoding options
Old 3rd July 2016, 18:26   #40  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.5 and ffx264 2.8.2
* Placed the supported audio codecs in a menu
* Updated the audio codecs default bitrates
