14th March 2016, 09:59 | #23781 | Link | |
thank you very much i will go for Automatic Quality Settings. |
14th March 2016, 13:36 | #23782 | Link | |
I checked automatic option now , but it says fast encode means quality is less , i want high quality may be same or better than BD50 quality , can it get that with the setting i am using now high quality default but with both untick can i get 2 pass better quality Please help |
14th March 2016, 14:12 | #23783 | Link | |
You can select other settings and waste time and electricity. Just proceed with the Automatic Setting and tell us afterwards how the result looks. |
14th March 2016, 14:45 | #23784 | Link |
If you want to be careful, just check the "High Quality" option. Honestly, you won't likely see a difference in the output when compared to "Automatic" -- but if the time spent in encoding doesn't mean anything to you, it can give you a sense of security.
14th March 2016, 15:36 | #23785 | Link |
Hi jdobbs, good morning. I was wondering if there has been any changes since the end of February that would break the creation of AVCHD DVD+R DL disks. February was the last time I created a DVD+R DL disk and it works correctly, I don't know which BD_Rebuilder release I used for it, sorry. The folder BD_Rebuilder created (DD5.1 640k audio) plays fine on my PC using TMT5, even though PowerDVD14 chokes on the ones TMT5 will play, lol. It is only after you burn the AVCD DVD+R DL disk that playback is broken. The disk will play in my Oppo93, but not using some other players or TMT5. It just throws up the please insert a valid disk and try again message. At first I thought maybe the "Strict AVCHD for BD-5/9" setting was not checked so I did a new encode with both settings on and off and both of the burned disks were unplayable. As a last resort I used the AVCHD-Patcher and that fixed the playback issues.
Thanks for all your continued hard work with this most excellent program, this is the first problem I've encountered in a long time, except for some self inflicted ones, lol. Let me know if you need logs or anything. |
14th March 2016, 19:58 | #23787 | Link |
Encoding length
While testing the videos "Expendables 3" and "12 Years A Slave" i run into a problem with the encoding length.
If I use alternate reencoding to mp4 the result of the encoding is as expected. If I use reencoding to DVD-5 the encoding ends up in movies which encoding length is about 1 -1.5 hours longer than the movies itself are. If you play the reencoded movies the first half part is the movie and the second half part is just a blank screen and silence. These reencodings are independend of the encoders used (DGDecNV, LAF, ...). My encoding settings for testing are always the same: [Options] AUTO_BIAS=3 AUTO_TWOPASSONLY=1 HC_PROFILE=BEST MULTIPROCESS=1 FORCED_SUB_LANG=eng; AUDIO_TO_KEEP=eng;fra;fre;spa; SUBS_TO_KEEP=eng;fra;fre;spa; DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 AUDIO_DRC=0 DECODER=3 AVCHD=1 REMOVE_WORKFILES=1 OUTPUT_FOLDER=H:\Videos\BD-RB\Output VERSION=0.50.0.12 ENCODER=0 MODE=3 ENCODE_QUALITY=2 AUTO_QUALITY=1 SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 KEEP_HD_AUDIO=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 [Paths] WORKING_PATH=G:\VIDEOS\BD-RB\WORK\ DGIndexNV=D:\DGDecNV\DGIndexNV.exe DGDecNV=D:\DGDecNV\DGDecodeNV.dll Do I miss something? |
14th March 2016, 20:03 | #23788 | Link |
Blank black videos with multicoloured blocks
While testing the movie "Honig im Kopf" the result of encoding is a movie with a blank/black video with multicoloured blocks.
Encoding settings are the same as in the last post. Do I miss something? |
14th March 2016, 20:33 | #23789 | Link |
I have to believe you have something incorrectly installed. Uninstall everything and then install again following the instructions in the first post of this thread exactly. As a reference, I've done the US version of "12 Years a Slave" with no issues. Before you do, run INSPECT from the help menu and post the result.
15th March 2016, 00:00 | #23790 | Link |
Inspect result:
[03.14.16] Checking System Settings - BD-Rebuilder v0.50.12 - Windows Version: 6.2 [9200] - Working Path Free Space: 61,86GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [03.14.16] Systems Settings Check complete Actually I don't think that there is something incorrectly installed 'cause i have done dozens of tests with this setting. Its just these three movies I have problems with. |
15th March 2016, 00:20 | #23791 | Link |
Something's wrong -- because no one else is having this issue. Reinstalling is the most likely cure. Sometimes other software interferes with or intercepts some of the normal processing paths -- and reinstalling fixes it.
16th March 2016, 10:37 | #23792 | Link | |
16th March 2016, 12:35 | #23793 | Link |
Thanks for a great program!
Just a question: Is there an option to get "burned in" subs into mkv files? Could not find it in Hiddenopts file My mediaplayer can not find the subs in .mkv files made by BD Rebuilder. Last edited by Fogger; 16th March 2016 at 13:41. |
16th March 2016, 13:58 | #23794 | Link | ||
16th March 2016, 14:21 | #23795 | Link | |
17th March 2016, 17:19 | #23797 | Link |
BD Rebuilder v0.50.14
I have updated the first post of this thread with a link to a new version of BD-RB (v0.50.14). Changes for this release:
- Fixed an error in which HEVC encoding can fail on interlaced sources. - Dramatically reduced encoding time for AAC streams when keeping multiple languages by running reencodes concurrently. Especially useful in ARCHIVE HEVC/AAC mode. - Corrected an issue in which secondary video tracks could cause an error attempting to mux for HEVC archive backups. - Added two new hidden settings for overriding the quality setting in certain modes. See ALTERNATE_QUALITY and ARCHIVE_QUALITY in HIDDENOPTS.TXT. - Corrected an issue in which restoring a disc from an HEVC ARCHIVE backup could miss some HEVC M2TS files and fail to reencode them to AVC. - Updated the X264 command line to include an SEI indicating 3D (frame-packing 3) when creating SBS 3D output. This should assist in automatic recognition of SBS 3D on some players. - Updated avs2yuv.exe to version 0.24m3. - Updated the included versions of X265 to a newest stable release (1.9.4). - Other minor corrections and cosmetic fixes. |
17th March 2016, 18:17 | #23799 | Link |
Windows Software Installer Error
Updated my computer to Office 2016 Pro Plus today. All versions of BD Rebuilder now do not launch the following error code is received:
System Error &H80004023 (-2147467229). A Microsoft Software Installer error was encountered. Has anyone else encountered this, knows how to fix? |
