18th August 2018, 07:49 | #52085 | Link |
Aye? surely it's your other settings like chroma, postprocessing, quality for perfomance options holding you back here... Someone else with a 1080 comment on this, 60fps content perhaps?
18th August 2018, 08:33 | #52086 | Link |
I have GTX 1070. For my 1080p content I use NGU Anti-Alias (high) < Bicubic150 LL AR (my monitor is only 1440p) + Remove Compression Artifacts High. Content is only 24 fps though.
18th August 2018, 09:49 | #52087 | Link |
@ zaemon - I have a 1080 oc and have no problems with virtually any scaler for 4k material (with pre and post processing) for 23.976 material.
As ryrynz asked, if its 60fps, you will need to dial back on processing options. What are your settings? Are you using supersampling?
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 18th August 2018 at 10:12. |
18th August 2018, 11:46 | #52089 | Link |
Ah I see - learnt something new.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
18th August 2018, 12:00 | #52090 | Link |
It's a great upscaler though, if you can pick it (it's expensive performance wise) you really can't go wrong with it, It's my preferred scaler for any extra upscaling. Also it does a damn fine job as part of SSIM2D, but my lord is it expensive.
I only just manage to get away with using it on my 1060 6GB on Full HD content after NGU sharp has doubled it. I think by the time I have a 4K TV I'll have enough GPU power to do it justice. |
18th August 2018, 12:19 | #52091 | Link |
@ ryrynz - same here
NGU Sharp very high>Jinc when needed.
18th August 2018, 19:42 | #52095 | Link |
Indeed, the decoder on the 1050/1050Ti/1080Ti leaves very little to be desired. I don't expect AV1 to be ready quite yet, so it may see performance improvements but what new features would they add to a decoder?
19th August 2018, 19:36 | #52099 | Link |
No, madVR only supports the AMD and Nvidia APIs for HDR switching. I am not sure if Intel does not have one or if madVR simply does not support it.
madVR options explained |
