Old 20th February 2016, 01:48   #36261  |  Link
x7007
Madshi ? there is no possible way that CUVID will work with NNEDI3 with newest drivers ?
Should I use Chroma Upscaling NNEDI3 32 neurons + Activate SuperRes + Upscaling refinement + SuperRes refine the image only once after upscaling is complete.
x7007 is offline   Reply With Quote
Old 20th February 2016, 02:08   #36262  |  Link
Why you still using it?
Old 20th February 2016, 02:40   #36263  |  Link
x7007
I wonder why it wouldn't work, we might need it on the future. CUVID can decode things that DXVA2 can't, as LAV Filter allows.
Old 20th February 2016, 03:36   #36264  |  Link
that's not really correct.
adding something like DXVA mpeg4 ASP decoding is simply not worth the time. and you gain absolutely nothing by using DXVA2 for such codecs.
nvidia broke it and they don't seem to care at all. in theory DXVA2 can do everything important CUVID can do.
Old 20th February 2016, 03:41   #36265  |  Link
x7007
Understood. I just thought it can be easy to restore the support from one side at least or the "other" side.
Could you help me with the other question ? if we are on the subject on NNEDI3 , I just don't know if I need to enable SuperRes on both Chroma Upscaling and refinement.
Old 20th February 2016, 03:54   #36266  |  Link
i can only tell you want i do.
you should ask your own eyes. that's what matter.
nnedi3 on chroma is totally useless in my eyes.
Old 20th February 2016, 04:08   #36267  |  Link
Yeah anything over nnedi3 32 neurons is wasted performance AFAIC. It's a nice sharp chroma upscaler but it most situations you won't notice a difference.
Jinc AR and Reconstruction soft are my fave pics with SuperRES being a luxury if you can afford it.
Luma should be where you spend the majority of your available performance for the simple fact that those changes are a lot more tangible.
Old 20th February 2016, 04:49   #36268  |  Link
Asmodian
Originally Posted by XMonarchY View Post
I am also a bit perplexed about the whole Bicubic thing. Are you saying that all the Image Downscaling options (and perhaps others?) are just renamed version of Bicubic? Catmull-Rom = Bicubic50, SSIM = Bicubic125, Jinc/NNEDI3/others = some other Bicubic???
Only Catmull-Rom and Bicubic50 are equivalent. Every other scaling option is unique.
Catmull-Rom is a special call out for Bicubic50 because it is the sharp theoretically optimal option for bicubic. Similar theoretical sweet spots for bicubic are SoftCubic100 and Mitchell-Netravali, Mitchell-Netravali is bicubic with B=1/3 and C=1/3. In madVR b = softness and c = sharpness. The proposal was any set of values where B + 2 * C = 1, with 1/3 and 1/3 as a particularly good balance between artifacts and sharpness. I believe optimal meant minimizing aliasing and ringing with varying sharpness. However, this work didn't have madVR's, or any, anti-ringing filter.
madVR options explained
Old 20th February 2016, 05:36   #36269  |  Link
leandronb
Originally Posted by FDisk80 View Post
I have the same problem if I use MPC-BE with internal filters.
But if I use MPC-BE with LAV filters the problem goes away.
Just tested and it's the same problem also with the latest madVR version.
I am using LAV filters, ac3filter and madvr.
Updated madvr and mpc and after 3 episodes no problem, i will try with other episodes later.
Old 20th February 2016, 10:16   #36270  |  Link
adhara
Question:
Is CatmullRom still the best algorythm for downscalling stuff ?
Or should I move to Jinc for this ?
I'm outputting source video to 2160p with a 970GTX video card.
adhara is offline   Reply With Quote
Old 20th February 2016, 10:31   #36271  |  Link
Originally Posted by adhara View Post
Question:
There is no best, only what you prefer. Jinc AR is good, so is SSIM 1D & 2D and many of the sharper bicubic scalers (100-150).
Many have updated their downscaling preferences to those, depending on the content.
Old 20th February 2016, 11:31   #36272  |  Link
AngelGraves13
madshi, will you be extending the GPU queue to maybe 32 or 64 eventually? Same question for frames to present in advance.
I've noticed higher values produce smoother motion with smooth motion turned on. I'm guessing it has to do with how many frames are blended together.
AngelGraves13 is offline   Reply With Quote
Old 20th February 2016, 12:02   #36273  |  Link
Present in advance can't be increased, thats a limit of the Direct3D API.
And personally I seriously doubt that increasing the queues increases the smoothness, as long as the value is high enough for the algorithm to work. It won't blend infinitely many frames, just the exactly right amount.
Old 20th February 2016, 14:04   #36274  |  Link
James Freeman
Fellows I have to express my findings.
Super-xbr 150 does wonders to Chroma, it makes the very lossy 4:2:0 appear as though it is 4:4:4.
Reconstruction (sharp/placebo) does something very similar but a lot harder on the gpu than super-xbr.
Old 20th February 2016, 16:38   #36275  |  Link
hdboy
Originally Posted by mueslibrown View Post
I'm an avid madVR user but I was slightly bemused with all the effort to support 3D, now that it appears that Samsung and LG are about to pull the plug was it and is it really worth the effort for what appears to be a dead format in its current guise ...
I'm think LG may keep it alive a bit longer. Their passive 3D on OLED is getting rave reviews for being the best 3D ever.
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86
hdboy is offline   Reply With Quote
Old 20th February 2016, 16:52   #36276  |  Link
James Freeman
Yeah, it's quite ironic that Nev and Madshi implemented support for 3D right at the end of 3D life cycle in the TV industry (unexpectedly I assume).
Nevertheless it's awesome for whom loves full resolution frame-packed 3D and madVR together.
Old 20th February 2016, 17:46   #36277  |  Link
Unfortunately their OLEDs cost an arm and a leg. Wonder if their 2016 S-UHD screens are any cheaper and still good.
Old 20th February 2016, 20:08   #36278  |  Link
FDisk80
I'm calling it now. VR Movies! It's 3D and surround.
Just think about it. You can watch the same movie over and over and always find something new that you didn't see before because you just didn't turn your head to look at it before.
Nev and Madshi get to work
FDisk80 is offline   Reply With Quote
Old 20th February 2016, 20:36   #36279  |  Link
James Freeman
Try NNEDI3 256 on that...
Old 20th February 2016, 20:39   #36280  |  Link
FDisk80
Ha!
