4th May 2020, 00:28 | #1744 | Link |
Hello i have a couple of more questions:-
1)is there anyway to adjust memory cache for vapoursynth? i have error try increasing cache when only 50% memory is being used 2) when adding plugins using profiles do i separate multiple line code using ; ? where the 1st line is import code for the plugin or script as it is not included in stax 3) https://staxrip.readthedocs.io/gener...tml#finedehalo it says here that finedehalo2 is included but i couldn't find it anywhere? thanks |
4th May 2020, 05:41 | #1746 | Link |
i am having another problem and this the worst of them all. whenever i try to use vapoursynth scripts the filters get copied into audio avisynth script as a result the encoder also crashes. why does this happen?.As a result whenever i choose no audio while using vapoursynth then only is the video encoded. any help is appreciated
Edit: this is the error D:\StaxRip-x64-2.0.8.0-stable\Apps\Encoders\ffmpeg\ffmpeg.exe -i "G:\test_Audio02.JPN_DecodeFFAudioSource.avs" -y -hide_banner "G:\test_Audio02.JPN_convFFAudioSource.w64" clip = core.ffms2.Source(r"", cachefile=r"G:\.ffindex") #clip = core.std.AssumeFPS(clip, None, 25, 1) AudioDub(last,FFAudioSource("G:\test.dts", cachefile="G:\test_Audio02.JPN.ffindex")) clip = core.dfttest.DFTTest(clip, sigma=1) Audiochannels() >= 6 ? Down2(last) : last function Down2(clip a) { a = ConvertAudioToFloat(a) fl = GetChannel(a, 1) fr = GetChannel(a, 2) c = GetChannel(a, 3) lfe = GetChannel(a, 4) sl = GetChannel(a, 5) sr = GetChannel(a, 6) l_sl = MixAudio(fl, sl, 0.2929, 0.2929) c_lfe = MixAudio(lfe, c, 0.2071, 0.2071) r_sr = MixAudio(fr, sr, 0.2929, 0.2929) l = MixAudio(l_sl, c_lfe, 1.0, 1.0) r = MixAudio(r_sr, c_lfe, 1.0, 1.0) return MergeChannels(l, r) } [avisynth @ 000001d145ac3240] Script error: expected a , or ) (G:\test_Audio02.JPN_DecodeFFAudioSource.avs, line 3, column 28) G:\test_Audio02.JPN_DecodeFFAudioSource.avs: Unknown error occurred edit: this is the avisynth file being generated LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\AVS\DFTTest\dfttest.dll") LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\Dual\ffms2\ffms2.dll") LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\Dual\flash3kyuu_deband\flash3kyuu_deband.dll") clip = core.ffms2.Source(r"", cachefile=r"G:\.ffindex") #clip = core.std.AssumeFPS(clip, None, 25, 1) AudioDub(last,FFAudioSource("G:\test.dts", cachefile="G:\test.ffindex")) clip = core.dfttest.DFTTest(clip, sigma=1) clip = core.f3kdb.Deband(clip) Audiochannels() >= 6 ? Down2(last) : last function Down2(clip a) { a = ConvertAudioToFloat(a) fl = GetChannel(a, 1) fr = GetChannel(a, 2) c = GetChannel(a, 3) lfe = GetChannel(a, 4) sl = GetChannel(a, 5) sr = GetChannel(a, 6) l_sl = MixAudio(fl, sl, 0.2929, 0.2929) c_lfe = MixAudio(lfe, c, 0.2071, 0.2071) r_sr = MixAudio(fr, sr, 0.2929, 0.2929) l = MixAudio(l_sl, c_lfe, 1.0, 1.0) r = MixAudio(r_sr, c_lfe, 1.0, 1.0) return MergeChannels(l, r) } the highlighted part shouldnt be there right whenever i try to encode video only its fine Last edited by ACKR; 4th May 2020 at 06:15. |
4th May 2020, 12:56 | #1748 | Link | |
4th May 2020, 18:43 | #1749 | Link |
couple of issues I'm having with Staxrip2.0 :
if I use the default temp folder name and choose to delete temp files, then it gets deleted and that's all good. but if I specify a custom temp folder name then selecting to delete temp files has no effect, the temp folder remains with all the files inside it. the default temp folder name has issues with very long folder names (this is why I specify a custom temp folder name). if the folder name and the video name are over a certain length, then the default temp folder name can end up too long and Staxrip crashes. it also handles this very poorly as well - the app crashes, it opens a log file in notepad, it opens a browser to show a staxrip support page, it opens the problem folder in windows, as well as popping up multiple dialog boxes. it's quite punishing if this happens when you're on the machine, and suddenly all this stuff pops up at once. it also then stops processing the task queue until the error dialogs are clicked on. it would be good if this error could be handled more gracefully without opening half a dozen new windows, and if the task queue would also continue (so a machine rendering overnight doesn't sit idle for 8 hours). but also it would be good if the default temp folder did not cause this behaviour if the folder and file names involved happen to be too long. |
4th May 2020, 19:05 | #1750 | Link |
4th May 2020, 19:56 | #1752 | Link |
In the beta there is a setting which defines a character limit of 150 characters, if the path is longer it will show:
In theory Windows supports paths that are longer than 260 characters, in reality neither Windows, nor the .NET Framework or the used tools have full long path support. StaxRip has a setting that allows to increase the limit but it's not recommended changing this limit! It will almost certainly not work!
4th May 2020, 21:03 | #1753 | Link | |
Sent from my Pixel 3a using Tapatalk |
4th May 2020, 21:51 | #1754 | Link |
thanks Patman this works. which decoders can you use with vapoursynth?
also few other questions 1)is there anyway to adjust memory cache for vapoursynth? i have error try increasing cache when only 50% memory is being used 2) when adding plugins using profiles do i separate multiple line code using ; ? where the 1st line is import code for the plugin or script as it is not included in stax 3) https://staxrip.readthedocs.io/gener...tml#finedehalo it says here that finedehalo2 is included but i couldn't find it anywhere? |
4th May 2020, 23:03 | #1755 | Link | ||||
4th May 2020, 23:08 | #1756 | Link | |
LSMASHVideoSource = LSMASHVideoSource("%source_file%") #AssumeFPS(25)
5th May 2020, 02:27 | #1757 | Link | |
1) i know how set cache for one vapoursynth script but i wanted to know if there is a way to incorporate it into a profile so its included at top of .vpy scripts generated everytime 2)vapoursynth. To stax76 does that mean to incorporate something like this you just need line Adaptive grain = import kagefunc as kgf clip = kgf.adaptive_grain(clip) and the ; isn't needed? 3)code for finedehalo2 is different but i added it using profiles since its one line only. |
7th May 2020, 14:13 | #1758 | Link |
I noticed this today. When I batch encode several files. If later I go and open one project of one of those files and change settings and the name of the output, it always encodes to the old name and overwrites the old file [file]_new.
For example if in target I say [file]_new2 it always encodes to [file]_new. So this happens to projects that were created automatically with Batch Encoding. |
8th May 2020, 06:45 | #1760 | Link |
Wanted to report a bug.
https://i.imgur.com/qa77ORW.png Sometimes when I'm going through settings the window will get to large to see all the way to the top. There is no way to resize the window or drag it and move it around. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
