Old 11th August 2023, 00:54   #9241  |  Link
Tiny Mud
Quote from Zathor to me - I'm Humbled:
"Thank you very much for letting me know. The issue is that the wrong file is downloaded (the one for MeGUI x64 which does not include the x86 folder). I do not have currently access to the update servers and can therefore not change it."
Tiny Mud is offline   Reply With Quote
Old 12th August 2023, 02:28   #9242  |  Link
Tiny Mud
From Wundderba:
megui.org was moved to a different platform.
You can get a ftp account from Wilbert: https://forum.doom9.org/showthread.php?t=185020
Can't yet STILL love MeGUI for video encoding ;o)
Old 19th November 2023, 07:44   #9243  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Hello, I hope all's well for all . After many years and upgrading from x86 MeGUI to x64 MeGUI and from installed basic AviSynth to AviSynt+, I indexed a previously successfully encoded .m2v file with the default DGIndex and a what in the past had been a functional profile, only to have the resulting script crash MeGUI. A bit of effort later, I learned that the problem was the two "LoadPlugin" lines that DGIndex adds to the script. To wit, the red bits are the culprit:
# Set DAR in encoder to 6480 : 4739. The following line is for automatic signalling
global MeGUI_darx = 6480
global MeGUI_dary = 4739
LoadPlugin("FilePath\DGDecode.dll")
DGDecode_mpeg2source("FilePath.d2v", cpu=4, info=3)
LoadPlugin("FilePath\ColorMatrix.dll")
ColorMatrix(hints=true, threads=0)
If I delete the red bits from the script, then it runs perfectly. Please, is there any way to stop DGIndex from writing those lines? And doesn't the newest AviSynth auto load DGDecode.dll and ColorMatrix.dll anyway? Thanks for any clarity.
LouieChuckyMerry is offline   Reply With Quote
Old 20th November 2023, 09:02   #9244  |  Link
hello_hello
DGIndex isn't writing anything. It's MeGUI adding that stuff to the script because it loads it's bundled plugins from it's own plugins folder. Avisynth (even the portable version bundled with MeGUI) checks the registry each time it runs, and if it finds entries pointing to a plugins folder or folders, it automatically loads the plugins they contain. MeGUI is supposed to be "portable" so it doesn't create any registry entries for plugin auto-loading. The easiest way to enable plugin auto-loading is to install Avisynth+ and put the plugins you use in the Avisynth+\plugins64 or Avisynth+\plugins64+ folder. MeGUI will still add the same lines to the script to load it's bundled plugins, because it doesn't require you to have Avisynth installed.
If I remember correctly, the 64 bit version of DGDecode doesn't include a deblocking filter, so if you enable Mpeg2 Deblocking under Filters in the Script Creator, MeGUI will add the cpu argument to the mpeg2source filter and it'll cause an error.
Info=3 is added when color correction is enabled in the script creator under the filters tab. If it's causing a problem leave it disabled because color correction is only applied when it's needed and these days that'd be almost never. With color correction disabled, the colormatrix plugin won't be used.
I thought I'd give DGDecode a spin myself, because I haven't used it since I switched to 64 bit Avisynth+ earlier in the year. I'm running Avisynth in Linux with Wine and DGDecode caused both MeGUI and AvsPmod to crash, and that was without enabling Mpeg2 Deblocking or Color Correction. I tried again on Windows 11 and the same thing happened. Hopefully just disabling Mpeg2 Deblocking will fix your problem, but if MeGUI still crashes, try the previous version of DGDecode. I can enable color correction with DGDecode 2.0.0.7, so the version of ColorMatrix I'm using must be okay, but DGDecode 2.0.0.8 seem to cause MeGUI to crash no matter what.
https://www.videohelp.com/software/D...c/old-versions
You'll need to replace DGDecode.dll in the MeGUI\tools\dgindex folder, and also in the plugins64 folder for the installed version of Avisynth, if you have it installed and there's a copy of it in there. It's probably a good idea to make sure any plugins in the Avisynth+\plugins64 folder are the same versions as the plugins MeGUI loads from it's tools folder.
Old 20th November 2023, 15:44   #9245  |  Link
LouieChuckyMerry
hello_hello to the rescue again . And you finally made the move from XP to Linux, nice! I'm still running Windows 7 but someday... Anyway, as always thanks for your help. Unticking the "Mpeg2 Deblocking" and "Colour Correction" boxes does the job; do you know if there's a way to permanently have them unticked? Having to untick them for every episode of The Simpsons and Futurama would get rather tedious.
Edit: Seems I'm even dumber than I look. I was unticking the boxes while indexing a video file; going to "Tools/AVS Script Creator/Config/Extra Setup" makes it stick. Thanks again for your help hello_hello, it always appreciated .
Old 21st November 2023, 20:00   #9246  |  Link
benwaggoner
Is there a recommended alternative MPEG-2 deblocking solution that runs under Windows 10/11? And hopefully a better one; DGDecode was a miracle in its time dealing with high QP MPEG-2 content, but there are certainly algorithms that can do a better job of deblocking and deringing while preserving detail today. And we certainly have >>1000x more MIPS we can apply today versus when MeGUI came out in Doom9's early glory days. Way more cores, way better SIMD, and programmable GPU compute.
Ben Waggoner
My Compression Book
Old 22nd November 2023, 11:07   #9247  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
I usually use Avisynth filters like Deblock_QED and HQDeringMod for these tasks when dealing with poorly encoded DVDs.
http://avisynth.nl/index.php/Deblock_QED
http://avisynth.nl/index.php/HQDering_mod
Not sure if those satisfy your requirements though.
LeXXuz is offline   Reply With Quote
Old 22nd November 2023, 11:12   #9248  |  Link
LeXXuz
LeXXuz's Avatar
I'm trying to transcode some ogg/opus files to mp3 for my old car stereo and I get an error when opening these with either FFAudioSource or LWLibAudioSource:
[Error] [22.11.2023 11:00:24] An error occurred: Script error: There is no function named 'SSRC'.
I rarely encode audio files, so I really have no clue what MeGui is trying to tell me here and how to fix this.
Data of one of the source files:
[Information] General
-[Information] Format: Ogg
-[Information] FileSize: 4902434
-[Information] PlayTime: 00:04:54.428
[Information] Audio
-[Information] ID: 2669402980
-[Information] Format: Opus
-[Information] SamplingRate: 48000
-[Information] SamplingRateString: 48.0 kHz
-[Information] Channels: 2
-[Information] ChannelsString: 2 channels
-[Information] ChannelPositionsString2: 2/0/0
-[Information] Language: en
-[Information] LanguageString: English
Old 22nd November 2023, 15:03   #9249  |  Link
tebasuna51
tebasuna51's Avatar
1) Please attach the full log file (in your ...megui\logs folder)
2) The SSRC function is only called if you want change the samplerate, if you preserve the source samplerate SSRC can't be called.
3) The SSRC function is a internal function in AviSynth and can't show that message, if you are using AviSynth+ that function is in a external Shibatch.dll. Seems you have a wrong Avs+ install missing that .dll.
4) Making test I found a bug in last ffmpeg (6.1), ffms2_r1387 and L-SMASH-Works-r1156.0.0.0 opus decoder: opus files with samplerate 32 KHz or 44.1 KHz (maybe more) are decoded always to 48 KHz.
Using opusdec.exe from last opus-tools-0.2-opus-1.3 the samplerate is preserved ok.
Bug reported https://trac.ffmpeg.org/ticket/10680
Old 22nd November 2023, 17:07   #9250  |  Link
LeXXuz
LeXXuz's Avatar
Thanks tebasuna51, that did it. Changed it to 'Keep original samplerate' and now transcoding works.
Old 22nd November 2023, 19:55   #9251  |  Link
benwaggoner
I've not had to work with DVD sources professionally in a long time, thank goodness. It's more for when family has old home movies on DVD (typically bad MPEG-2) and that sort of thing.
Ben Waggoner
My Compression Book
Old 26th November 2023, 23:00   #9252  |  Link
LouieChuckyMerry
I hope everyone's well . For the the last week or so both my laptops with portable 64bit MeGUI, both fully updated from the developmental server, have been crashing whenever I try to downmix any audio with any of my previously-working-fine QAAC profiles. After much banging of head, I discovered that switching the "Preferred Decoder" in the "QAAC configuration dialog" from "FFAudioSource" to "LWLibavAudioSource" solved the issue. Is this something I should post somewhere else? Looking for guidance, thanks.
Old 27th November 2023, 04:29   #9253  |  Link
hello_hello
After updating 64 bit MeGUI I'm pretty sure I discovered it'd installed the 32 bit version of ffms2 instead of the 64 bit version. The file in MeGUI's update_cache folder is called ffms2-r1387-32.7z.
Try downloading it manually and replacing ffms2.dll in MeGUI's tools\ffms folder with the 64 bit version.
https://codeberg.org/StvG/ffms2/releases/tag/r1387
MeGUI seems to have developed an annoying habit of simply shutting down when an error is encountered, without displaying an error message to let you know what the problem might be. It only became obvious when I tried using ffms2 with AvsPmod and was able to see the Avisynth+ error message.
Having said that, if I open a file with FFAudioSource I now get an access violation error message. That's using Linux/Wine/AvsPmod with the current version of FFMS2, so maybe it's just a Wine issue. I haven't tried it on Windows yet. LWLibavAudioSource is okay though, and FFVideoSource works as expected.
Old 29th November 2023, 01:06   #9254  |  Link
LouieChuckyMerry
Exactly the problem; you've many tricks.
I agree with the annoyance of MeGUI crashing without an error message but understand, given that it's freeware and quite complex (I miss Zathor). Are you familiar with Groucho2004's AVSMeter? I added it to my "Send to" context menu; if a script is troublesome it always leads me in the direction of a solution.
My problem was strictly in the audio realm (Win 7); video indexing was fine (although I only use FFMS2 for VC-1 video).
Thanks again, hello_hello, for saving me physical effort and mental stress .
Old 29th November 2023, 14:32   #9255  |  Link
tebasuna51
tebasuna51's Avatar
Closed ticket like wontfix like a old one
Internally opus only support 8, 12, 16, 24 and 48 kHz, then other input is resampled and ffmpeg refuse any last resample after decode.
It is ok for me.
Old 27th December 2023, 22:44   #9256  |  Link
LouieChuckyMerry
As always I hope everyone's well . I'm not certain that this is necessarily an MeGUI issue but it seems a reasonable place to start. I've an older (Win 7 64-bit; Intel i7; 16GB RAM) laptop that I pretty much only use to downmix audio and encode video (MeGUI 64-bit, Developmental Server; AviSynth+ 3.7.2, r3661, 64-bit), although I'll occasionally go online to get a subtitle or read an article while waiting for a large file to finish copying or indexing. For ten-some years I've had no problems that weren't eventually explained as user error; however, a few months ago I started having issues with MeGUI simply stopping for no apparent reason while encoding video. That is, for years I could simply queue video(s), start the queue, then wait for the results, moving the mouse to kill the screensaver every once in a while to check the queue's progress. Unfortunately for these last several months, about every third time I start a queue I'll find that MeGUI is completely frozen or that the FPS has slowed to a number so low that the encode(s) will take years to finish (it could be the first video in a queue, the last video in a queue, or one somewhere in the middle of a queue; and, I might discover this frozen state the first time I interrupt the screensaver, the third time, the fifth...). Invariably I'll have to do a hard restart because I'm unable to open anything, not the Start Menu or the Task Manager or any program. It reminds me of a problem I had years ago with a browser suffering from a memory leak. I've checked things as well as I know how--Memtest86 shows no issues with the RAM; CrystalDiscInfo shows no issue with the SSD; Avast shows no viruses or malware after a scan; I've not made any changes to my dozen-or-so script presets--so I'm wondering if there's an MeGUI-Win 7 issue I'm unaware of. Upgrading my OS SSD from a 500GB Crucial to a 1TB Dataram occurred about the same time this problem arose; is it possible an SSD drive is too slow for multithreading? Any help is much appreciated.
_____________
EDIT: In case this helps someone I found a solution. After testing the hardware as best as I could and uninstalling-reinstalling various softwares, I decided to re-restore the Clonezilla image that I'd originally restored to the new SSD; however, the image proved to be corrupt (deemed unrestorable by Clonezilla) upon attempting this. I've no idea how I was able to restore the image in the first place if it was corrupt, but restoring an older, uncorrupt image seems to have fixed the problem. Happy New Year .
Old 14th January 2024, 23:11   #9257  |  Link
raymondjpg
This file or folder cannot be used in OneClick mode
I'm seeing this error quite regularly when processing the last video in a folder batch job, typically when running QAAC. It halts processing of the job, but goes away on left mouse click, which appears to resume processing without error.
Can anyone please tell me what is causing the error, and how to prevent it?
Last edited by raymondjpg; 15th January 2024 at 01:14. Reason: Duplicate post deleted
raymondjpg is offline   Reply With Quote
Old 26th January 2024, 22:18   #9258  |  Link
LouieChuckyMerry
Happy Friday! I'm wondering: is it possible to use MeGUI with UtVideo and, if so, how? Thanks for any help.
Old 27th January 2024, 12:07   #9259  |  Link
For reading AVI files encoded with an UtVideo codec, to convert them to a final format, surely.
For writing AVI files, would not make much sense. Ut codecs are lossless, you won't use them to approach a target bitrate/filesize. Simply using VirtualDub2 would be a lot easier.
Old 27th January 2024, 18:56   #9260  |  Link
LouieChuckyMerry
LigH: Thanks for your reply . I'm currently using MeGUI to index UHD Blu-rays then VirtualDub2-UtVideo to tonemap and downscale them then MeGUI-AVC to clean-sharpen-shrivel, and just wondered if I could streamline the process by using MeGUI exclusively. Not a big deal, just curious. Thanks again for your input, Prost!
megui
