7th May 2017, 23:04 | #5441 | Link |
>>Zathor
check "always use the included avisynth" in settings will bring a crash: wait for other person's test, I think it should not be the avisynth's ploblem because it crashes at oneclick profile creation step build 2631:works fine, it will output 640x480x4:3 mp4 at batch mode. advice: I think there should be a "disable/ignore input DAR" option here, Like if I have 2 avs, and one I want to output 1712*720 and another one 640x388, etc... Bugs in Extra IO: If I have two VOBS, file name like"VTS_01_PGC_02_1.VOB" and "VTS_01_PGC_03_1.VOB", and two cheapter files like "VTS_01_PGC_02 - Chapter Information - OGG.txt" and "VTS_01_PGC_03 - Chapter Information - OGG.txt". and I want to encode "VTS_01_PGC_03_1.VOB". the one click encoder will auto load the chapter file "VTS_01_PGC_02 - Chapter Information - OGG.txt" ,but not the "VTS_01_PGC_03 - Chapter Information - OGG.txt" . also there should be a "X" clear button so I could delete the chapter file. |
8th May 2017, 01:42 | #5442 | Link |
Today I realised what it is that bugs me the most about the double confirmation dialogue, aside from the fact there's two of them.
I'm not sure I've lined them up exactly, but it's close enough. Of course normally they're in the same position vertically on the screen as they appear one after the other. If you're not careful with cursor placement, after the second popup message replaces the first, clicking "No" can become clicking "Yes" or clicking "No" can become clicking "Cancel", so there's two confirmation dialogues with required reading (I was fine with one but my brain doesn't seem to have enough memory for retaining two) and cursor placement needs to move up to a conscious level where it can be adjusted to compensate for button drift. Maybe it's just me, but the second or two all that takes feels like hard work. |
8th May 2017, 02:00 | #5443 | Link |
sumirecccp's post reminded me of something.
The subtitle section in the script creator is equally stubborn when it comes to removing subtitles from scripts. There's no way to "clear" the subtitle field once they've been added, short of shutting down the script creator and starting again. I don't think any of the "x" buttons in OneClick or AudoEncode are Woking for me. They seem unable to clear anything. |
8th May 2017, 07:48 | #5444 | Link | |||
It is not so easy to change as both are needed for some uses cases and only in one specfic use case you see both. |
8th May 2017, 07:57 | #5445 | Link |
>>I do not have that problem at all with the included avisynth build and your profile.
ok,waiting. >>It should only autoload in the case it has been or will be created by MeGUI. You only have the VOB + TXT in the directory or the whole structure (+ IFOs...). only have VOB+txt in the directory, you can copy VTS_01_PGC_02_1.VOB I uploaded before and rename it with VTS_01_PGC_03_1.VOB and test for it. >>If you (incl. sumirecccp) tell me which X does not work or is missing I will check it. I mean a button like this: |
8th May 2017, 17:16 | #5446 | Link | |
EDIT: Extract both files into your MeGUI directory. It should still crash, but the log should show me more information. Last edited by Zathor; 8th May 2017 at 17:20. |
8th May 2017, 17:49 | #5447 | Link |
Dont know if this is one that HH is talking about, but, 2nd Dialog box in post 5521, little 'x' close dialog icon is disabled (greyed out).
8th May 2017, 18:59 | #5448 | Link |
>>zathor
Preliminary log file only. During closing of MeGUI the well formed log file will be written. -[Information] Versions --[Information] [2017/05/09 2:06:33] MeGUI: 2732 --[Information] [2017/05/09 2:06:33] Operating System: Windows 10 Enterprise x64 (10.0.0.15063) --[Information] [2017/05/09 2:06:33] .NET Framework: 4.0 (4.0.0.0) --[Information] [2017/05/09 2:06:33] .NET Framework: 4.7 (4.7.02046) -[Information] Update detection --[Information] [2017/05/09 2:06:33] Automatic update is disabled --[Information] [2017/05/09 2:06:33] Haali Media Splitter: 1.13.138.14 (14-04-2013) --[Information] [2017/05/09 2:06:33] Using cached update config and server: http://megui.tmebi.de/test/ --[Information] [2017/05/09 2:06:33] Haali DSS2: not installed --[Information] [2017/05/09 2:06:33] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) --[Information] [2017/05/09 2:06:33] MediaInfo: 0.7.95.0 (04-05-2017) --[Information] [2017/05/09 2:06:33] MediaInfoWrapper: 0.7.61.0 (06-01-2013) --[Information] [2017/05/09 2:06:33] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) --[Information] [2017/05/09 2:06:33] SevenZipSharp: 0.64.3890.29348 (02-01-2011) --[Information] [2017/05/09 2:06:33] 7z: 9.20 (18-11-2010) -[Information] [2017/05/09 2:06:33] Version: 1.0.2721.0 -[Information] [2017/05/09 2:06:33] Date: 29-04-2017 -[Information] [2017/05/09 2:06:33] Interface: 3 --[Information] AviSynth Wrapper --[Information] [2017/05/09 2:06:34] There is 1 package which can be updated: x265 -[Information] [2017/05/09 2:06:34] File Version: 2.6.0.5 -[Information] [2017/05/09 2:06:34] Date: 20-02-2015 -[Information] [2017/05/09 2:06:34] Name: Avisynth 2.6 -[Information] [2017/05/09 2:06:34] Version: AviSynth 2.60, build:Feb 20 2015 [03:16:45] -[Information] [2017/05/09 2:06:34] AviSynth+: false -[Information] [2017/05/09 2:06:34] MT: true -[Information] [2017/05/09 2:06:34] Status: inactive --[Information] AviSynth -[Information] [2017/05/09 2:06:34] File Version: 0.1 -[Information] [2017/05/09 2:06:34] Date: 16-03-2017 -[Information] [2017/05/09 2:06:34] Name: AviSynth+ 0.1 (r2455, MT, i386) -[Information] [2017/05/09 2:06:34] Version: AviSynth+ 0.1 (r2455, MT, i386) -[Information] [2017/05/09 2:06:34] AviSynth+: true -[Information] [2017/05/09 2:06:34] MT: true -[Information] [2017/05/09 2:06:34] Status: active --[Information] AviSynth portable -[Information] OneClick --[Information] [2017/05/09 2:06:43] MediaInfo ---[Information] [2017/05/09 2:06:43] File: F:\DVD_VOLUME\VIDEO_TS\VTS_01_PGC_02_1.VOB -[Information] Format: MPEG-PS -[Information] FormatString: MPEG-PS -[Information] FileSize: 36626432 -[Information] PlayTime: 00:00:51.718 ---[Information] General -[Information] ID: 224 -[Information] StreamOrder: -[Information] Width: 720 -[Information] Height: 480 -[Information] FrameCount: 1550 -[Information] FrameRate: 29.970 -[Information] FrameRateOriginal: -[Information] FrameRateMode: -[Information] ScanType: Interlaced -[Information] Codec: MPEG-2V -[Information] CodecString: MPEG-2 Video -[Information] Bits Depth: 8 -[Information] Format: MPEG Video -[Information] AspectRatio: 1.778 -[Information] AspectRatioString: 16:9 -[Information] Delay: 280.633 -[Information] Title: -[Information] Language: -[Information] LanguageString: -[Information] Default: -[Information] DefaultString: -[Information] Forced: -[Information] ForcedString: ---[Information] Video -[Information] ID: 189-128 -[Information] StreamOrder: 0 -[Information] Format: AC-3 -[Information] FormatProfile: -[Information] FormatSettingsSBR: -[Information] FormatSettingsPS: -[Information] SamplingRate: 48000 -[Information] SamplingRateString: 48.0 kHz -[Information] Channels: 2 -[Information] ChannelsString: 2 channels -[Information] ChannelPositionsString2: 2/0/0 -[Information] BitRateMode: CBR -[Information] Delay: 280.633 -[Information] Title: -[Information] Language: -[Information] LanguageString: -[Information] Default: -[Information] DefaultString: -[Information] Forced: -[Information] ForcedString: -[Information] [2017/05/09 2:06:46] The language information is not available for this track. The default MeGUI language has been selected. ---[Information] Audio --[Information] [2017/05/09 2:06:53] Video: F:\DVD_VOLUME\VIDEO_TS\VTS_01_PGC_02_1.VOB --[Information] [2017/05/09 2:06:53] Audio: F:\DVD_VOLUME\VIDEO_TS\VTS_01_PGC_02_1.VOB ([80] - AC-3 - 2 channels / 48.0 kHz / Japanese) -[Information] Log for job3 (idx, VTS_01_PGC_02_1.VOB -> VTS_01_PGC_02_1.d2v) --[Information] [2017/05/09 2:06:59] Started handling job --[Information] [2017/05/09 2:06:59] Preprocessing --[Information] [2017/05/09 2:06:59] Job command line: "E:\D\software\megui\tools\dgindex\dgindex.exe" -SD=< -AIF=<F:\DVD_VOLUME\VIDEO_TS\VTS_01_PGC_02_1.VOB< -OF=<F:\DVD_VOLUME\VIDEO_TS\iziwdfnu.2ow\VTS_01_PGC_02_1< -FO=0 -exit -hide -OM=2 --[Information] [2017/05/09 2:06:59] Process started --[Information] [2017/05/09 2:06:59] Standard output stream --[Information] [2017/05/09 2:06:59] Standard error stream --[Information] [2017/05/09 2:07:06] Running auto force film ---[Information] [2017/05/09 2:07:06] Film percentage: -1 --[Information] [2017/05/09 2:07:06] Postprocessing -[Information] [2017/05/09 2:07:06] Successfully deleted F:\DVD_VOLUME\VIDEO_TS\VTS_01_PGC_02_1.log ---[Information] [2017/05/09 2:07:06] Deleting intermediate files --[Information] [2017/05/09 2:07:06] Job completed -[Information] Log for job4 (oneclick, VTS_01_PGC_02_1.VOB -> ) --[Information] [2017/05/09 2:07:06] Started handling job --[Information] [2017/05/09 2:07:06] Preprocessing --[Information] [2017/05/09 2:07:06] Processing thread started --[Information] [2017/05/09 2:07:06] Desired size: --[Information] [2017/05/09 2:07:06] Split size: --[Information] [2017/05/09 2:07:06] DEBUG: 1 -[Information] AviSynth -[NoImage] LoadPlugin("E:\D\software\megui\tools\dgindex\DGDecode.dll") -[NoImage] DGDecode_Mpeg2Source("F:\DVD_VOLUME\VIDEO_TS\iziwdfnu.2ow\VTS_01_PGC_02_1.d2v") -[NoImage] 場所 System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) -[NoImage] 場所 System.Environment.get_StackTrace() -[NoImage] 場所 MeGUI.AviSynthClip.HandleAviSynthWrapperDLL(Boolean bUnload, String script) 場所 D:\MEGUI\MeGUI_debug\packages\tools\avscreator\AvisynthWrapper.cs:行 633 -[NoImage] 場所 MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) 場所 D:\MEGUI\MeGUI_debug\packages\tools\avscreator\AvisynthWrapper.cs:行 542 -[NoImage] 場所 MeGUI.AviSynthScriptEnvironment.ParseScript(String script, AviSynthColorspace forceColorspace) 場所 D:\MEGUI\MeGUI_debug\packages\tools\avscreator\AvisynthWrapper.cs:行 83 -[NoImage] 場所 MeGUI.AvsFile..ctor(String script, Boolean parse) 場所 D:\MEGUI\MeGUI_debug\packages\reader\avs\AvsReader.cs:行 92 -[NoImage] 場所 MeGUI.AvsFile.ParseScript(String scriptBody) 場所 D:\MEGUI\MeGUI_debug\packages\reader\avs\AvsReader.cs:行 84 -[NoImage] 場所 MeGUI.d2vFile..ctor(String fileName) 場所 D:\MEGUI\MeGUI_debug\packages\reader\d2v\d2vReader.cs:行 90 -[NoImage] 場所 MeGUI.OneClickPostProcessing.createAVSFile(String indexFile, String inputFile, Nullable`1 AR, Int32 desiredOutputWidth, LogItem _log, AviSynthSettings avsSettings, Boolean autoDeint, VideoCodecSettings settings, Boolean autoCrop, Boolean keepInputResolution, Boolean useChaptersMarks) 場所 D:\MEGUI\MeGUI_debug\packages\tools\oneclick\OneClickPostProcessing.cs:行 562 -[NoImage] 場所 MeGUI.OneClickPostProcessing.StartPostProcessing() 場所 D:\MEGUI\MeGUI_debug\packages\tools\oneclick\OneClickPostProcessing.cs:行 284 -[NoImage] 場所 System.Threading.ThreadHelper.ThreadStart_Context(Object state) -[NoImage] 場所 System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) -[NoImage] 場所 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) -[NoImage] 場所 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) -[NoImage] 場所 System.Threading.ThreadHelper.ThreadStart() --[Information] [2017/05/09 2:07:06] sessions open: 1, id: 600580 Last edited by sumirecccp; 8th May 2017 at 19:10. |
8th May 2017, 20:17 | #5450 | Link | |
2635 [MP4 Muxer] write always aspect ratio information to preserve anamorphic information. Bug #837 2634 [Profile] removed redundant second warning when changing a profile which should be saved to the scratchpad. Feature request #606 2633 [OneClick] added button to clear the working directory path and the chapters file [AVS Script Creator] added button to clear the subtitle file [Muxer] added button to clear the chapter file |
8th May 2017, 20:24 | #5451 | Link | |
Use for your tests this new version: http://megui.org/megui_debug.zip |
8th May 2017, 21:29 | #5452 | Link |
>>zathor
[Error] Log -[Information] Versions --[Information] [2017/05/09 4:21:41] MeGUI: 2732 --[Information] [2017/05/09 4:21:41] Operating System: Windows 10 Enterprise x64 (10.0.0.15063) --[Information] [2017/05/09 4:21:41] .NET Framework: 4.0 (4.0.0.0) --[Information] [2017/05/09 4:21:41] .NET Framework: 4.7 (4.7.02046) --[Information] [2017/05/09 4:21:41] Haali Media Splitter: 1.13.138.14 (14-04-2013) --[Information] [2017/05/09 4:21:41] Haali DSS2: not installed --[Information] [2017/05/09 4:21:41] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) --[Information] [2017/05/09 4:21:41] MediaInfo: 0.7.95.0 (04-05-2017) --[Information] [2017/05/09 4:21:41] MediaInfoWrapper: 0.7.61.0 (06-01-2013) --[Information] [2017/05/09 4:21:41] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) --[Information] [2017/05/09 4:21:41] SevenZipSharp: 0.64.3890.29348 (02-01-2011) --[Information] [2017/05/09 4:21:41] 7z: 9.20 (18-11-2010) --[Information] AviSynth Wrapper ---[Information] [2017/05/09 4:21:41] Version: 1.0.2721.0 ---[Information] [2017/05/09 4:21:41] Date: 29-04-2017 ---[Information] [2017/05/09 4:21:41] Interface: 3 --[Information] AviSynth ---[Information] [2017/05/09 4:21:41] File Version: 2.6.0.5 ---[Information] [2017/05/09 4:21:41] Date: 20-02-2015 ---[Information] [2017/05/09 4:21:41] Name: Avisynth 2.6 ---[Information] [2017/05/09 4:21:41] Version: AviSynth 2.60, build:Feb 20 2015 [03:16:45] ---[Information] [2017/05/09 4:21:41] AviSynth+: false ---[Information] [2017/05/09 4:21:41] MT: true ---[Information] [2017/05/09 4:21:41] Status: inactive --[Information] AviSynth portable ---[Information] [2017/05/09 4:21:41] File Version: 0.1 ---[Information] [2017/05/09 4:21:41] Date: 16-03-2017 ---[Information] [2017/05/09 4:21:41] Name: AviSynth+ 0.1 (r2455, MT, i386) ---[Information] [2017/05/09 4:21:41] Version: AviSynth+ 0.1 (r2455, MT, i386) ---[Information] [2017/05/09 4:21:41] AviSynth+: true ---[Information] [2017/05/09 4:21:41] MT: true ---[Information] [2017/05/09 4:21:41] Status: active -[Information] Update detection --[Information] [2017/05/09 4:21:41] Automatic update is disabled --[Information] [2017/05/09 4:21:41] Using cached update config and server: http://megui.tmebi.de/test/ --[Information] [2017/05/09 4:21:41] There is 1 package which can be updated: x265 -[Information] AviSynth --[Information] [2017/05/09 4:21:50] sessions open: 1, id: 234156 ---[NoImage] F:\DVD_VOLUME\VIDEO_TS\New AviSynth Script.avs ---[NoImage] 場所 System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) ---[NoImage] 場所 System.Environment.get_StackTrace() ---[NoImage] 場所 MeGUI.AviSynthClip.HandleAviSynthWrapperDLL(Boolean bUnload, String script) ---[NoImage] 場所 MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AviSynthScriptEnvironment.OpenScriptFile(String filePath, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AvsFile..ctor(String script, Boolean parse) ---[NoImage] 場所 MeGUI.AvsFile.OpenScriptFile(String fileName) ---[NoImage] 場所 MeGUI.MediaInfoFile.CorrectSourceInformation(MediaInfo& oInfo, String strFile, LogItem infoLog, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile.GetSourceInformation(String file, LogItem oLog, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile..ctor(String file, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile..ctor(String file) ---[NoImage] 場所 MeGUI.MainForm.openFile(String file, MediaInfoFile& iFile) ---[NoImage] 場所 MeGUI.VideoEncodingComponent.videoInput_FileSelected(FileBar sender, FileBarEventArgs args) ---[NoImage] 場所 MeGUI.FileBar.triggerEvent() ---[NoImage] 場所 MeGUI.FileBar.setFilename(String filename) ---[NoImage] 場所 MeGUI.core.util.DragDropUtil.<>c__DisplayClass2_0.<RegisterSingleFileDragDrop>b__1(Object sender, DragEventArgs e) ---[NoImage] 場所 System.Windows.Forms.Control.OnDragDrop(DragEventArgs drgevent) ---[NoImage] 場所 System.Windows.Forms.Control.System.Windows.Forms.IDropTarget.OnDragDrop(DragEventArgs drgEvent) ---[NoImage] 場所 System.Windows.Forms.DropTarget.System.Windows.Forms.UnsafeNativeMethods.IOleDropTarget.OleDrop(Object pDataObj, Int32 grfKeyState, POINTSTRUCT pt, Int32& pdwEffect) ---[NoImage] 場所 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) ---[NoImage] 場所 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.Run(Form mainForm) ---[NoImage] 場所 MeGUI.MainForm.Main(String[] args) --[Information] [2017/05/09 4:21:50] sessions open: 0, id: 234156, close: True ---[NoImage] 場所 System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) ---[NoImage] 場所 System.Environment.get_StackTrace() ---[NoImage] 場所 MeGUI.AviSynthClip.HandleAviSynthWrapperDLL(Boolean bUnload, String script) ---[NoImage] 場所 MeGUI.AviSynthClip.Dispose(Boolean disposing) ---[NoImage] 場所 MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AviSynthScriptEnvironment.OpenScriptFile(String filePath, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AvsFile..ctor(String script, Boolean parse) ---[NoImage] 場所 MeGUI.AvsFile.OpenScriptFile(String fileName) ---[NoImage] 場所 MeGUI.MediaInfoFile.CorrectSourceInformation(MediaInfo& oInfo, String strFile, LogItem infoLog, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile.GetSourceInformation(String file, LogItem oLog, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile..ctor(String file, Int32 iPGCNumber, Int32 iAngleNumber) ---[NoImage] 場所 MeGUI.MediaInfoFile..ctor(String file) ---[NoImage] 場所 MeGUI.MainForm.openFile(String file, MediaInfoFile& iFile) ---[NoImage] 場所 MeGUI.VideoEncodingComponent.videoInput_FileSelected(FileBar sender, FileBarEventArgs args) ---[NoImage] 場所 MeGUI.FileBar.triggerEvent() ---[NoImage] 場所 MeGUI.FileBar.setFilename(String filename) ---[NoImage] 場所 MeGUI.core.util.DragDropUtil.<>c__DisplayClass2_0.<RegisterSingleFileDragDrop>b__1(Object sender, DragEventArgs e) ---[NoImage] 場所 System.Windows.Forms.Control.OnDragDrop(DragEventArgs drgevent) ---[NoImage] 場所 System.Windows.Forms.Control.System.Windows.Forms.IDropTarget.OnDragDrop(DragEventArgs drgEvent) ---[NoImage] 場所 System.Windows.Forms.DropTarget.System.Windows.Forms.UnsafeNativeMethods.IOleDropTarget.OleDrop(Object pDataObj, Int32 grfKeyState, POINTSTRUCT pt, Int32& pdwEffect) ---[NoImage] 場所 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) ---[NoImage] 場所 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.Run(Form mainForm) ---[NoImage] 場所 MeGUI.MainForm.Main(String[] args) --[Information] [2017/05/09 4:21:50] sessions open: 1, id: 230854 ---[NoImage] F:\DVD_VOLUME\VIDEO_TS\New AviSynth Script.avs ---[NoImage] 場所 System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) ---[NoImage] 場所 System.Environment.get_StackTrace() ---[NoImage] 場所 MeGUI.AviSynthClip.HandleAviSynthWrapperDLL(Boolean bUnload, String script) ---[NoImage] 場所 MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AviSynthScriptEnvironment.OpenScriptFile(String filePath, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AvsFile..ctor(String script, Boolean parse) ---[NoImage] 場所 MeGUI.AvsFile.OpenScriptFile(String fileName) ---[NoImage] 場所 MeGUI.MainForm.openFile(String file, MediaInfoFile& iFile) ---[NoImage] 場所 MeGUI.VideoEncodingComponent.videoInput_FileSelected(FileBar sender, FileBarEventArgs args) ---[NoImage] 場所 MeGUI.FileBar.triggerEvent() ---[NoImage] 場所 MeGUI.FileBar.setFilename(String filename) ---[NoImage] 場所 MeGUI.core.util.DragDropUtil.<>c__DisplayClass2_0.<RegisterSingleFileDragDrop>b__1(Object sender, DragEventArgs e) ---[NoImage] 場所 System.Windows.Forms.Control.OnDragDrop(DragEventArgs drgevent) ---[NoImage] 場所 System.Windows.Forms.Control.System.Windows.Forms.IDropTarget.OnDragDrop(DragEventArgs drgEvent) ---[NoImage] 場所 System.Windows.Forms.DropTarget.System.Windows.Forms.UnsafeNativeMethods.IOleDropTarget.OleDrop(Object pDataObj, Int32 grfKeyState, POINTSTRUCT pt, Int32& pdwEffect) ---[NoImage] 場所 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) ---[NoImage] 場所 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.Run(Form mainForm) ---[NoImage] 場所 MeGUI.MainForm.Main(String[] args) --[Information] [2017/05/09 4:21:51] sessions open: 0, id: 230854, close: True ---[NoImage] 場所 System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) ---[NoImage] 場所 System.Environment.get_StackTrace() ---[NoImage] 場所 MeGUI.AviSynthClip.HandleAviSynthWrapperDLL(Boolean bUnload, String script) ---[NoImage] 場所 MeGUI.AviSynthClip.Dispose(Boolean disposing) ---[NoImage] 場所 MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AviSynthScriptEnvironment.OpenScriptFile(String filePath, AviSynthColorspace forceColorspace) ---[NoImage] 場所 MeGUI.AvsFile..ctor(String script, Boolean parse) ---[NoImage] 場所 MeGUI.AvsFile.OpenScriptFile(String fileName) ---[NoImage] 場所 MeGUI.MainForm.openFile(String file, MediaInfoFile& iFile) ---[NoImage] 場所 MeGUI.VideoEncodingComponent.videoInput_FileSelected(FileBar sender, FileBarEventArgs args) ---[NoImage] 場所 MeGUI.FileBar.triggerEvent() ---[NoImage] 場所 MeGUI.FileBar.setFilename(String filename) ---[NoImage] 場所 MeGUI.core.util.DragDropUtil.<>c__DisplayClass2_0.<RegisterSingleFileDragDrop>b__1(Object sender, DragEventArgs e) ---[NoImage] 場所 System.Windows.Forms.Control.OnDragDrop(DragEventArgs drgevent) ---[NoImage] 場所 System.Windows.Forms.Control.System.Windows.Forms.IDropTarget.OnDragDrop(DragEventArgs drgEvent) ---[NoImage] 場所 System.Windows.Forms.DropTarget.System.Windows.Forms.UnsafeNativeMethods.IOleDropTarget.OleDrop(Object pDataObj, Int32 grfKeyState, POINTSTRUCT pt, Int32& pdwEffect) ---[NoImage] 場所 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) ---[NoImage] 場所 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) ---[NoImage] 場所 System.Windows.Forms.Application.Run(Form mainForm) ---[NoImage] 場所 MeGUI.MainForm.Main(String[] args) -[Error] MediaInfo --[Error] [2017/05/09 4:21:50] Error parsing media file F:\DVD_VOLUME\VIDEO_TS\New AviSynth Script.avs ---[NoImage] System exception - Access Violation ---[NoImage] (F:\DVD_VOLUME\VIDEO_TS\New AviSynth Script.avs, line 1) |
9th May 2017, 20:16 | #5456 | Link | |
Are these ones supposed to do something? They don't seem to clear anything for me. Same in AutoEncode. I think the X button in the audio section in the main window works. |
9th May 2017, 20:23 | #5457 | Link |
I never used the OCE ... but maybe they are used to remove accidently added streams? So they only work when you clicked the '+' tab at least once? I don't have any material here right now...
9th May 2017, 20:57 | #5458 | Link | |
Thanks to Morku + hello_hello: Code:
2637 [Muxer] + [OneClick] removed unnecessary "X" buttons 2636 [Update] x64: fixed detection of the DGIndexIM package |
