6th February 2017, 13:37 | #501 | Link |
thank you
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 6th February 2017 at 13:42. |
22nd February 2017, 11:00 | #502 | Link |
Hello,
After editing srt subtitles sometimes I get empty lines. I can't figure out how to delete all lines in one go. Now I manually mark each empty line and then hit delete. Would be great if someone could enlighten me on this? Thanks... Edit: Found a workaround: Options-->Settings-->Check "Remove blank lines when opening a subtitle". But I would like to do the remove when I finished editing the srt. The workaround setting requires to first edit the srt, check the "Remove..." then close Subtitle Edit and open it again and blank lines will be removed. I will also have to uncheck "Remove..." before opening a new srt project to have the original srt untouched. Hope I'm making sense... and many thanks to the creator of this excellent software. Regards Last edited by varekai; 22nd February 2017 at 12:37. Reason: . |
22nd February 2017, 12:53 | #503 | Link |
Pig on the wing
You could use Fix common errors to remove the empty lines after you have finished working on the file.
3rd March 2017, 16:53 | #505 | Link |
Subtitle Edit 3.5.2 is out: https://github.com/SubtitleEdit/subtitleedit/releases
List view can now display cps and/or wpm + many minor improvements and fixes |
3rd April 2017, 18:43 | #507 | Link |
Hi.
Just reporting a bug (I assume) with naming Advanced Sub Station Alpha styles (I'm using Subtitle Edit 3.5.2 on XP). When creating a style and giving it a multi-word name (ie Magnificent New Style), Subtitle Edit drops everything after the first space, so "Magnificent New Style" becomes "Magnificent ". Style: Magnificent ,Courier New,20,&H00FFFFFF,&H0300FFFF,&H00000000,&H02000000,0,0,0,0,100,100,0,0,1,2,1,2,10,10,10,1 When saving the subtitle file, for the individual subtitles, it also drops the space. Dialogue: 0,0:22:54.82,0:23:01.12,Magnificent,,0,0,0,,Subtitle text...... The above only happens when first creating/naming a style. If you then edit the style without editing the name, when you re-save the subtitle file, Subtitle Edit also drops the space from the style name, so the subtitles go back to working properly again. For Sub Station Alpha subtitles, the space after the first word is dropped as soon as the style is created (or the subtitle file is first saved), so even though the style mightn't have the expected name, it doesn't break functionality. Style: Magnificent,courier new,20,-1,-50331904,-16777216,-50331648,0,0,1,2,1,2,10,10,10,0,1 Dialogue: Marked=0,0:22:54.82,0:23:01.12,Magnificent,NTP,0000,0000,0000,,Subtitle text...... Thank you for the continued work on Subtitle Edit. Last edited by hello_hello; 3rd April 2017 at 18:52. |
3rd April 2017, 20:00 | #508 | Link |
@Lucius Snow: Sorry, don't know (latest beta has improved drop frame support for Final Cut Pro XML+PNG...). Let me know if you find out what's wrong.
@hello_hello: thx for the info I've tried to make a fix - included in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip |
3rd April 2017, 21:16 | #509 | Link | |
I've given the beta version a quick test, and so far so good. Thanks. |
4th April 2017, 19:14 | #511 | Link |
Hi, still waiting for a response after ... 7 months ;
https://forum.doom9.org/showthread.p...46#post1779846 |
11th April 2017, 22:18 | #512 | Link | |
It is just annoying to me that the Controls, Audio and Video windows pop up everytime I open a subtitle to do a quick edit. The program also crashes and locks with many videofiles. And even when it works well it feels slower to open, so I would just love to be able to disable it when I don't wanna use it. Thank you for the great work. Last edited by Barneyk; 12th April 2017 at 12:55. |
16th April 2017, 11:25 | #513 | Link |
@Music Fan: Sorry, I started on it but did not find a good solution...
@Barneyk: Just had a few requests for that, so it's included in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip - see Options -> Settings -> Video player - "Auto-open video file when opening subtitle" |
22nd April 2017, 12:35 | #514 | Link |
Thank you for constantly updating this. It currently my main subtitle software.
I'm not sure if this feature is available yet, the option Word List > OCR seem quite close to what I need but it only get activate during OCR fix up tools. What I'm interest is, "short key" or "short words". When I subtitle there tend to be quite many repeat words and phrases (e.g Names or Idiom). Typing these out each time is a pain, I usually Copy/Paste it but clipboard can only hold one. Other method is I use a Acronym and use Replace (Ctrl+H) afterward. So the feature I'm hoping you add is the ability to use short cut/key and it will auto change to what I need. Feature: Short Cut/Key Words Example: Typing "abc" will replace it with, "all can bee", typing lol change it to "laugh out loud". These words and replacement key can be changed of course. Thank you. |
22nd April 2017, 14:02 | #515 | Link |
Hello I have been using subtitle edit,I wanted to convert this non-english sub into srt
It's Hindi sub in pgs I want to convert into Hindi srt I updated my software also updated Hindi dictionary (downloaded as I was ask to do so when I selected Hindi language on OCR main Page after loading pgs) here is PGS - https://www.sendspace.com/file/2s9jkh here is SRT - https://www.sendspace.com/file/ascd2t I got this srt,so pls let me know what to b done |
25th April 2017, 11:30 | #516 | Link | |
Another option might be a macro program. Maybe give AutoHotkey a try. One of it's most basic jobs would be to save strings of text to automatically type for you after you type a "hotstring" (pretty much any key combination you choose). As a simple example for a script such as the one below, typing "zzs" would cause AutoHotkey to replace "zzs" with "This is the phrase I don't want to repeatedly type" followed by the enter key. ;Some phrase. :*:zzs::This is the phrase I don't want to repeatedly type{Enter} AutoIT also seems to be quite popular. |
12th May 2017, 19:04 | #517 | Link |
@rockydon: Latest version works on your Hindi subtitle (at least for me). You'll probably need to download the Hindi Tesseract dictionary from inside SE again.
Also, Subtitle Edit 3.5.3 is out - https://github.com/SubtitleEdit/subtitleedit/releases Partial change log: * Minor OCR improvements * New Netflix quality checker - thx askolesov/pavel-belenko * Added optional list view column "Actor" for ASS/SSA - thx william * New subtitle format * Import plain text now also supports input as HTML * Added "Total words" to statistics - thx Barbara * Added more Tesseract dictionaries - thx lucybook/Elheym * Added "Video auto-load" to UI settings (so it's now possible NOT to auto-load videos) - thx mtarini * "names_etc.xml" renamed to "names.xml" + local dictionaries now has a "blacklist" - thx ivandrofly * In "Change casing" it's now possible to add extra names * Export image margins are now percentage - thx aaaxx/gorgorias * "Import plain text" now rembembers options - thx Leon * "Insert subtitle here..." added to waveform context menu * Drag'n'drop of subtitles now allows up to 10 MB - thx Silvena * Fixed crash in "Add to user dictionary" in OCR - thx alfix0 * Fixed original file name bug in "Undo" - thx darnn * Fixed non default timecode scales in MKV - thx mkver * Fix missing UTF-8 tag in OCR HTML export - thx dgonyier * Fixed "FCP + image" export for drop frame rates - thx chris * Fixed finding Tesseract traineddata files on Linux - thx mooop12 * Fixed loading of "mks" files from cmd line - thx Charles * Fixed new ASS/SSA style with space in name - thx hello_hello * Fixed crash in "Binary image compare" OCR with empty image * Some minor fixes for spell check "change whole word" - thx N/A |
13th May 2017, 16:56 | #518 | Link |
Disabling the "auto-open video file" setting doesn't seem to work for me.
Even though I have it disabled it still auto-opens. And it leads to subtitle edit crashing about 50% of the time I try and use it. And even when it doesn't crash it makes the program open really sluggishly and it is a pain to use all of the sudden. Is there a way to disable the videoplayer function completly? I just wanna edit subtitles, I want nothing to do with the videofiles. Last edited by Barneyk; 13th May 2017 at 16:58. |
13th May 2017, 19:56 | #519 | Link |
@Barneyk: Thx for the info
Could you try latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip (Also, you could try "mpv media player" - you can download the single dll file directly from SE video player settings.) |
13th May 2017, 21:26 | #520 | Link | |
But it still freezes and have to be terminated with some files. But it doesn't load the video files now so its fine as far as I am concerned. I would prefer it if there was an option to not open the video windows at all, they are in the way and makes the program feel clunky to me. I undocked them but they still open everytime I open the program whether I load a video file or not. |
