17th November 2014, 02:58 | #21 | Link | |
20th November 2014, 15:03 | #23 | Link |
Khanattila!
for update. I test Your plugin on different PC. It is work fine for Windows XP 32 with NVIDIA GeForce 8800 GTS 512 and Windows 7 64 with Intel HD, but have problem with Windows 7 64 with GTX 560 Script Code:
AVISource("chapter13.avi") AssumeTFF() ConvertToYV12(interlaced=true) SeparateFields() NLMeansCL2(device_type="GPU") Weave() Code:
Avisynth open failure: NLMeansCL2: Houston, we've had a problem! [clCreateContext (CL_INVALID_DEVICE)] (C:\Video\Source\stenyaev\tesnlmcl.avs, line 5) Code:
OpenCL 1.1 CUDA 6.5.12 FULL_PROFILE 1: GeForce GTX 560 Code:
Avisynth open failure: NLMeansCL2: Houston, we've had a problem! [create_image2d (CL_GENERIC_ERROR)] (C:\Video\Source\stenyaev\tesnlmcl.avs, line 5) Also when I try on other computer with avisynth+ and open avs in Virtualdub I get error about insert disk for installation, after cancel avs opened. When I replace to Avisynth 2.6 MT all became fine. yup. |
20th November 2014, 18:52 | #24 | Link |
Ok, let me explain.
This plugin use the default OpenCL context of your system because I have not yet implemented a system scan. If for example the system uses NVIDIA CUDA as default OpenCL context is not possible to set device_type = "CPU". Because NVIDIA CUDA do not support any CPU. It is possible that the system default is wrong. |
21st November 2014, 09:27 | #27 | Link | |
Khanattila!
Report from GPU Caps Viewer Quote:
yup. |
21st November 2014, 09:43 | #28 | Link | |
That's what I tried to explain.
Because NLMeansCL2 is still in development, it use only the default context. If you remove the intel OpenCL driver it should work. |
22nd November 2014, 03:25 | #31 | Link |
Hello
I wonder if this plugin will work in MeGUI? I was able to get NLMeansCL to work in MeGUI the minor problems I encountered I was able to overcome. I downloaded this plugin and copied it to the standard MeGUI folder for this kind of plugin but MeGUI doesn't seem to recognize it properly...OR...perhaps I didn't install it correctly? Will it work or shall I just continue to check in here to see if you've made it compatible with MeGUI? Thanks
Humanity does more than rhyme with insanity...it defines it. |
22nd November 2014, 03:33 | #32 | Link | |
AviSynth 2.6 Alpha 5 Visual C++ Redistributable Package for Visual Studio 2013 (x86) I don't use MeGUI so I can't check. |
22nd November 2014, 04:06 | #33 | Link |
RD, can I ask then, what do you use for h264, just curious.
22nd November 2014, 04:17 | #34 | Link |
x264.exe (I use tMod), I sometimes load the .avs directly, or use Avs2YUV to pipe to x264 (mainly for 10-bit video). Anyways this it OT so I'll stop.
---- @Khanattila When this filter becomes stable do you mind if I add to the AviSynth wiki? Last edited by Reel.Deel; 22nd November 2014 at 04:47. Reason: typo |
22nd November 2014, 10:59 | #38 | Link | |
Just copy the plugin in "C:\Program Files (x86)\AviSynth 2.5\plugins" (example). MeGui can call all of them. |
22nd November 2014, 18:58 | #39 | Link |
Khanattila
Sorry to be a dunce but I'm not having any luck and I don't want to waste anymore or your time, I'll just tune into this site every once in a while to see if any one has gotten this plugin working with MeGUI and hope they post instructions on HOW EXACTLY they managed it. Thanks
22nd November 2014, 19:03 | #40 | Link |
@HOB
error=0x7e? Hmm doesn't this error mean that a component is missing? Are you sure you have the 32-bit (x86) 2013 Redistributable Package? Edit: try loading NLMeansCL2.dll with Dependency Walker to be sure that nothing is missing. Last edited by Reel.Deel; 22nd November 2014 at 19:07. |
