Old 22nd November 2014, 20:39   #41  |  Link
HOB
Reel.Deel
I think you may be on to something, I may be missing a component for THIS plugin. I have quite a large number of third party plugins installed in MeGUI and I've not come across this problem with any of them. I'll double check to make sure I have the package you refer to installed and if not I'll get it installed...
Thanks for the suggestions....I'll be back.
Humanity does more than rhyme with insanity...it defines it.
HOB is offline   Reply With Quote
Old 23rd November 2014, 01:36   #42  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by HOB View Post
Khanattila
Sorry to be a dunce but I'm not having any luck and I don't want to waste anymore or your time, I'll just tune into this site every once in a while to see if any one has gotten this plugin working with MeGUI and hope they post instructions on HOW EXACTLY they managed it.
It's probably my fault but MeGUI is just a gui for AviSynth, x264 and other software.
AviSynth have two ways to load plugin. Using this code in a script
LoadPlugin ("filename" [, ...])
or copy plugin in this folder.
D:\Program Files (x86)\AviSynth 2.5\plugins
The plugins from 'plugins' folder are auto-loaded at AviSynth startup, and this is the safest way. So just copy "NLMeansCL2.dll" in "plugins" and all will go in the right way
http://s2.postimg.org/3ypdeb1ft/Me_GUI.jpg
Khanattila is offline   Reply With Quote
Old 23rd November 2014, 18:05   #43  |  Link
HOB
Hello Khanattila and Reel.Deel
I think Reel.Deel has the solution I AM missing a component...I copied the NLMeansCL2.dll to the indicated directory and got the following error message:
Any suggestions as to which component I need to download and install?
Old 23rd November 2014, 18:20   #44  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Did you at all install that?
Install it anway. If you did, re-install it.
If you don't know, install it.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 23rd November 2014, 20:09   #45  |  Link
HOB
Of course Isaac was right about that standing on the shoulders of giants business…with your help it WORKED.
Thanks Khanattila, Reel.Deel and Sparktank.
Old 28th November 2014, 13:01   #46  |  Link
Khanattila
Khanattila's Avatar
Edit.
Old 5th December 2014, 10:49   #47  |  Link
dbart
one technical HW question:
i dont play games, im happy with passive GT430 for video decoding and fft3dgpu filtering. Now playing with this filter i start thinking about GTX 750.
Is it better to have 2 GB memory version of this card, or 1 GB model is enough for using NLMeansCL2 ?
dbart is offline   Reply With Quote
Old 5th December 2014, 11:18   #48  |  Link
Groucho2004
The maximum graphics memory I have seen it use is about 160MB with 1080p, checked with GPU-Z. I run it on a GT240 with 512MB.
If you don't play games I think 1 GB would be plenty. However, you'll have to consider that other filters may be using the graphics memory (now or in the future). If the price difference is not too big, go for 2 GB.
Old 5th December 2014, 22:40   #49  |  Link
Khanattila
Khanattila's Avatar
In video memory are loaded the source and the target frame.
Each frame weighs 8-bit / 16-bit for pixel.
So in the worst case: 1920x1080, YV24, y=3, u=3, v=3, 16-bits.
1920*1080*16*2*3 = 190 MB.
Old 3rd January 2015, 23:49   #50  |  Link
Khanattila
Khanattila's Avatar
Edit.
Old 4th January 2015, 00:04   #51  |  Link
Groucho2004
Originally Posted by Khanattila View Post
New: about 10% faster.
Hm, 0.3.3 is slower than 0.3.2 on my box (XP32Sp3, i5-2500K).
0.3.2:
Frames processed:               500 (0 - 499)
FPS (min | max | average):      13.46 | 14.19 | 13.80
CPU usage (average):            25%
GPU usage (average):            95%
Thread count:                   8
Memory usage (phys | virt):     70 | 69 MB
Time (elapsed):                 00:00:36.220
0.3.3:
FPS (min | max | average):      11.24 | 11.84 | 11.58
GPU usage (average):            96%
Thread count:                   8
Time (elapsed):                 00:00:43.194
Script:
w = 1920
h = 1080
colorbars(width = w, height = h, pixel_type = "yv12").killaudio().assumefps(24000, 1001)
trim(0,499)
fadeio(248)
trim(0,499)
NLMeansCL2()
Old 4th January 2015, 00:35   #52  |  Link
Khanattila
Khanattila's Avatar
This is interesting.
(8.1, i5-2500k, GTX760)
0.3.3
FPS (min | max | average):      65.31 | 73.17 | 69.65
GPU usage (average):            83%
Thread count:                   8
Memory usage (phys | virt):     102 | 102 MB
Time (elapsed):                 00:00:07.179
0.3.2
FPS (min | max | average):      58.67 | 64.88 | 62.17
GPU usage (average):            85%
Thread count:                   8
Time (elapsed):                 00:00:08.043
Old 4th January 2015, 00:37   #53  |  Link
Groucho2004
Did you use the same script? Also, which Avisynth version?
Old 4th January 2015, 00:52   #54  |  Link
Khanattila
Khanattila's Avatar
All the same.
Another test, with more GPU load.
0.3.3
FPS (min | max | average):      22.21 | 27.08 | 25.67
GPU usage (average):            90%
Thread count:                   8
Memory usage (phys | virt):     105 | 96 MB
Time (elapsed):                 00:00:19.475
0.3.2
FPS (min | max | average):      19.60 | 23.73 | 22.60
GPU usage (average):            93%
Thread count:                   8
Memory usage (phys | virt):     105 | 97 MB
Time (elapsed):                 00:00:22.129
script
ColorBars(1920, 1080, "YV12").killaudio().assumefps(24000, 1001)
trim(0,499)
fadeio(248)
trim(0,499)
NLMeansCL2(A=8)
The new code should reduce GPU load, and increase the overall performance.
Old 4th January 2015, 01:03   #55  |  Link
Groucho2004
I have a GT240, obviously much slower than your card. Maybe the newer card has some optimizations that the GT240 does not have. Could also be a driver issue...
Note to self: Add GPU info to AVSMeter log.
Old 4th January 2015, 12:42   #56  |  Link
Khanattila
Khanattila's Avatar
Can you repeat the test and share the complete log?
AMD C-60, HD6290, W8.1. I have no other platform.
0.3.3
Frames processed:               100 (0 - 99)
FPS (min | max | average):      1.613 | 1.747 | 1.687
CPU usage (average):            5%
GPU usage (average):            82%
Thread count:                   1
Memory usage (phys | virt):     81 | 75 MB
Time (elapsed):                 00:00:59.283
0.3.2
FPS (min | max | average):      1.133 | 1.589 | 1.481
CPU usage (average):            4%
GPU usage (average):            75%
Thread count:                   1
Memory usage (phys | virt):     80 | 75 MB
Time (elapsed):                 00:01:07.511
script
w = 1920
h = 1080
trim(0,99)
fadeio(49)
trim(0,99)
NLMeansCL2()
http://pastebin.com/wtQfVknS
http://pastebin.com/euQqAXiQ
Old 4th January 2015, 13:04   #57  |  Link
Groucho2004
0.3.2: http://pastebin.com/tzqZZP35
FPS (min | max | average):      13.32 | 14.15 | 13.79
Thread count:                   8
Memory usage (phys | virt):     67 | 66 MB
Time (elapsed):                 00:00:07.250
0.3.3: http://pastebin.com/xYwGcK7k
FPS (min | max | average):      11.24 | 11.80 | 11.57
GPU usage (average):            91%
Thread count:                   8
Time (elapsed):                 00:00:08.646
WinXPSP3, i5-2500K @ 4GHz, GT240, Driver: 310.90
Old 4th January 2015, 14:38   #58  |  Link
Khanattila
Khanattila's Avatar
Maybe it is a problem due to the driver. There are some problems reported with 310.90.
Old 4th January 2015, 16:27   #59  |  Link
Groucho2004
I tried with the latest driver, same thing.
Could it be the OpenCL version (see below Aida64 report)?
    OpenCL Properties:
      Platform Name                                     NVIDIA CUDA
      Platform Vendor                                   NVIDIA Corporation
      Platform Version                                  OpenCL 1.1 CUDA 6.5.12
      Platform Profile                                  Full
    Device Properties:
      Device Name                                       GeForce GT 240
      GPU Code Name                                     GT215
      Device Type                                       GPU
      Device Vendor                                     NVIDIA Corporation
      Device Version                                    OpenCL 1.0 CUDA
      Device Profile                                    Full
      Driver Version                                    340.52
      OpenCL C Version                                  OpenCL C 1.1
Old 4th January 2015, 19:19   #60  |  Link
Khanattila
Khanattila's Avatar
According to khronos API:
 If the -cl-std build option is not specified, the CL_DEVICE_OPENCL_C_VERSION is used to select the version of OpenCL C to be used when building the program executable for each device.
Possible the same source code generate different machine code. In this case slower.
(-cl-std=CL1.0 is not allowed)
