10th December 2020, 12:53 | #8001 | Link |
I enable OS HDR before open file for test. If not - madVR activate NV HDR, but it's working only in exclusive full-screen.
10th December 2020, 13:09 | #8002 | Link | |
How? Which version of madvr? Can you post a screenshot about madvr OSD? I tried these 2 files from the links you posted: Sony_Another_World_4K_Demo-184047-tmu_hlg10_hevc.mkv TravelXP 4K HDR HLG Demo.ts
10th December 2020, 13:11 | #8003 | Link | |
Edit: same SDR using fullscreen exclusive mode here. Edit2: same SDR when I toggle Windows HDR button. So I'm pretty sure it has nothing to do with madvr. Even Envy users asked about HLG support recently. Btw, I use Lav filters. Do you use the internal ts / mkv filter of mpc-be?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 10th December 2020 at 13:16. |
10th December 2020, 13:14 | #8004 | Link |
sorry i can't test this fullscreen exclusive doesn't work on my system with OS HDR active. could be AMD "issue".
i would really like to know if it is the same "wrong" HLG as mpcVR is showing me where everything is to bright. and HLG to HDR10 with OS HDR and exclusive mode doesn't sound like something madshi would implement this sounds more like a bug. very interesting. |
10th December 2020, 13:19 | #8005 | Link |
I'm using in MPC-BE using internal video decoder. I think you are using LAV - it's don't send information about HDR for HLG to madVR, but send to MPCVR
Here screen - https://i.imgur.com/GAnSUYL.png Here from input pin info from madVR(from MPC Video Decoder): Code:
VIDEOINFOHEADER2: dwInterlaceFlags: 0x00000081 dwCopyProtectFlags: 0x00000000 dwPictAspectRatioX: 16 dwPictAspectRatioY: 9 dwControlFlags: 0x82422581 - VideoChromaSubsampling: 5 (MPEG-2) - NominalRange : 2 (16-235) - VideoTransferMatrix : 4 (BT.2020) - VideoLighting : 0 - VideoPrimaries : 9 (BT.2020) - VideoTransferFunction : 16 (ARIB STD-B67 (HLG)) dwReserved2: 0x00000000
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 10th December 2020 at 13:22. |
10th December 2020, 13:31 | #8006 | Link |
Thanks, I'll take a look later.
10th December 2020, 13:39 | #8007 | Link |
you should be careful with DXVA2 decode. madVR has troubles with it and the image can be altered in an unforeseen way it can't access the image without DXVA2 altering it. could be true for mpcVR too. that's why lav filter is used with copyback or d3d11 just to remove it as a potential issue.
i will test this in detail later with mpc-be internal decoder. |
10th December 2020, 13:51 | #8008 | Link |
In MPC VR, even if use DXVA2 decoding in decoder, if use shader - data copied from Direct3D9 surfaceto local memory(like DXVA2 copy-back in LAV) without "lose" data. Yes it takes longer - but picture perfect as software or DX11 native.
10th December 2020, 14:34 | #8009 | Link |
Can you clarify a bit to avoid confusion?
Do you mean that if using DXVA2 native input, MPCVR will always do a copyback internally, or only when using shaders? And what counts as shaders in this case, just user supplied ones from the player, or also the internal HDR2SDR shader and resize shaders (if DXVA2 video processor unchecked)? Maybe show something like "CopySurface" in the OSD on postprocessing line, when this extra step is performed. It is useful to know this when helping people to identify possible causes of performance issues. Small bug report (unrelated to above): When opening MPCVR settings using rundll32, the dropdown menus do not display correctly when clicking in them. They display with height of just one entry. |
10th December 2020, 14:37 | #8010 | Link | |
10th December 2020, 14:43 | #8012 | Link |
Windows 10 is identifying the 5798 x64 installer build on https://yadi.sk/d/hlf1lfC8mKU58/!_last as containing a virus. As confident as I am about it being a false positive, I just wanted to mention it.
10th December 2020, 15:54 | #8013 | Link |
You can submit Windows Defender false positives here:
https://www.microsoft.com/en-us/wdsi/filesubmission I just build MPCVR rev1509. Some bugs: - The passthrough checkbox isn't unchecked when its greyed out (on Win7). The code currently uses "if (1)" for always greying out. I assume that is intentional for testing. - OSD still says "Convert to SDR" when I uncheck that option |
10th December 2020, 18:10 | #8014 | Link |
ok i tested the sample with madVR the result has to be incorrect is far far to bright.
i use the sushi sample. edit: i will create a bug report for madVR so we know if madVR is working correctly. Last edited by huhn; 10th December 2020 at 18:13. |
10th December 2020, 19:22 | #8015 | Link |
Something Else
When playing SDR content, my monitor is able to switch to the correct matching refresh rate (or multiple) when "use autochange fullscreen monitor mode" is enabled but not when i play HDR content.
11th December 2020, 00:21 | #8016 | Link | |
About "Passthrough to display" and "Convert to SDR" - it's apply only on startup. There is no need to handle the changes right away - but the code will get very complicated.
12th December 2020, 13:08 | #8017 | Link | ||||
I just had to enable the internal filters and didn't ahve to change anything else on madvr side and it outputs HDR10 But I still think that's the case: Quote:
I think the problem is that HDR10 and HLG HDR use different eotf curves and madvr only understand the HDR10 one, so it deals with the HLG video incorrectly as it was HDR10. I need to compare this way and with Plex on the TV, but it seems to be way off most of the times.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 12th December 2020 at 13:19. |
12th December 2020, 13:14 | #8018 | Link |
Windows 10 support only HDR10 output-passthrough.
12th December 2020, 13:21 | #8019 | Link | |
I understand, but that's not the problem but this:
Same with mpcvideorenderer. So as far as I understand, madvr and your renderer has to convert HLG HDR to HDR10 at first and then do its/your thing
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 12th December 2020 at 13:25. |
12th December 2020, 14:19 | #8020 | Link | |
