Old 17th January 2021, 07:08   #8221  |  Link
JarrettH
Originally Posted by senzaparole View Post
Hello everyone!
I have a problem with MPC-BE and madVR.
If from windows I set the audio output "topping" to send the audio to the DAC / AMP Topping to listen to headphones, madvr goes crazy: I lose many frames.
If instead from windows I set the optical output of the motherboard to send the audio to the DAC / AMP for listening in headphones, madvr works as well as ever.
This problem is only with MPC-BE. With MPC-HC no problem both if the audio output is "topping" and if the audio output is "optical"
In MPC-BE I added LAV video and audio filters to MPC-BE.
And they are the same as MPC-HC.
Are you running at least 4.86 usb driver on the Topping? Don't ask me why, but 4.86 fixed something for me having to do audio issues I was experiencing in MPC-BE under WASAPI.
https://www.tpdz.net/download
Old 17th January 2021, 11:29   #8222  |  Link
chros
chros's Avatar
Originally Posted by Aleksoid1978 View Post
I can't reproduce "bug" with MPC VR, so can't do something. No one provided any evidence, preferably in the form of a video recording with included statistics ...
Sorry, I deleted those when I edited the post above, here they are:
- recorded bug (SDR hevc 2160p 59p file on 1080p 60Hz monitor)
- settings
Try to recreate with Lav settings and PotPLayer (OSD should display d3d11 VLD decoder).
Old 17th January 2021, 11:46   #8223  |  Link
Aleksoid1978
Aleksoid1978's Avatar
- settings
Ok thanks. Try uncheck NV12/P010 and other.
Old 17th January 2021, 18:44   #8224  |  Link
v0lt
Looks like messed up frame order after decoder or deinterlacing.
Old 17th January 2021, 19:36   #8225  |  Link
chros
chros's Avatar
Probably (it's a progressive video, so no deint), it looks like those old childish puzzle games sometimes
But if I understand it right (see below), the above nvidia setting (Vertical Sync set to "Fast") now make sense why it made a difference.
That solved it! Thanks
So what does that Video Processor section mean in mpcVR?
Does it mean that all those operations done by the GPU driver instead of mpcVR shaders (in my case luma/chroma scaling)?
If so, then it's really confusing, I wonder how many other people use them wrong
Old 17th January 2021, 23:07   #8226  |  Link
senzaparole
hi, thanks for the reply. I had the E30 / L30 Topping but returned to the seller for the known issues.
Today the SMSL M500 arrived and I have the exact same problem: madVR goes crazy! As with the Topping, I solved it by setting the DEVICE BUFFER to default
TV:LG B9 65 Amplifier: Denon X4500H Front Speakers: n. 3 XTZ Cinema M6 Subwoofer: XTZ 10.17 EDGE Atmos Speakers:n. 4 XTZ S2 Surround Speakers: n. 2 XTZ Spirit 2 - HTPC: Fractal Meshify C-RX 5700 XT
senzaparole is offline   Reply With Quote
Old 17th January 2021, 23:14   #8227  |  Link
senzaparole
I don't understand what you mean "stuttering" ? Maybe more detail explain, screenshot/video ???
I use DX11 + FSE, all perfect after switching window/FSE mode.
Here is the screenshot of MPC-HC in playback mode:
Here is the screenshot of MPC-BE in playback mode:
Old 18th January 2021, 00:22   #8228  |  Link
Aleksoid1978
When NV12/P010 and other check - color conversion YUV -> RGB do DX9/D3D11 video processor(some functional in GPU driver). When uncheck - color conversion do MPC VR using own shaders.
Old 18th January 2021, 15:41   #8229  |  Link
cmhrky
Can you add the "Zoom +" and "Zoom -" commands to the zoom options? The 50%, 100%, 200% and Zoom Auto Fit commands are insufficient to set intermediate values. It is also really difficult to adjust intermediate values with the mouse. It might be nice to set it up with mouse and keyboard shortcuts. (Alt + 5, Alt + 6, Ctrl + Mouse Wheel Up / Down ...)
cmhrky is offline   Reply With Quote
Old 18th January 2021, 16:07   #8230  |  Link
chros
chros's Avatar
Thanks for the explanation.
I think those settings needs more documentation, e.g. tooltip, or on the github page?
Old 18th January 2021, 20:50   #8231  |  Link
beter
Update for translation of Traditional Chinese and Dutch
https://www.sendspace.com/file/t0gdnp
beter is offline   Reply With Quote
Old 19th January 2021, 04:25   #8232  |  Link
v0lt
@beter
Thanks. Updated in r5978.
Are you sure you need to resize the window? After all, an arbitrary window size can be easily obtained using the mouse and the "Limit window proportions on resize" option.
You can change the size of the frame using the Num1 and Num9 keys.
PS: I do not add key combinations for new commands, users will have to do it themselves. Because too many keys have already been used.
Old 19th January 2021, 11:32   #8233  |  Link
cmhrky
The "Limit window proportions on resize" option is active. I usually use it in window mode and I use it with default windows settings.
When I want to adjust it to the applications I use, the zoom options often fall short, because it's either too big or too small. It is also difficult to adjust with the mouse. I thought it could be adjusted quickly with "Zoom +/-".
I wrote the key combinations as an example. It doesn't need to be the default.
Old 19th January 2021, 20:38   #8234  |  Link
cmhrky
I prepared a toolbar.svg and flybar.svg with the icons here. If you want to try, you can download it.
Main source of icons: Fluent UI System Icons
Old 19th January 2021, 21:43   #8235  |  Link
Klaus1189
Wow
Old 19th January 2021, 22:22   #8236  |  Link
Make this the new default imo, only problem is that the icons have thin lines on dark backgrounds. The new icons look nicer but I prefer the bold look of the old ones.
cmhrky, can you increase thickness of the lines of these icons by maybe 50%, I think it will help a lot.
Old 20th January 2021, 05:15   #8237  |  Link
v0lt
@ryrynz
If you don't like the new SVG toolbars, then you can use the old toolbar_xx.png.
Take the desired size, rename it to "toolbar.png" and put it in the player folder.
@cmhrky
The microphone for selecting audio tracks looks strange. I think a note icon would be more appropriate.
Old 20th January 2021, 13:11   #8238  |  Link
Grimsdyke
@cmhrky
Great work, but I also think using a microphone for an audio out function is not the best solution. I think you should create an icon based on a speaker symbol and give it your spin. Thanks !!
Old 20th January 2021, 21:01   #8239  |  Link
cmhrky
@ryrynz
I prepared 2 files of different thickness. I added it inside the zip file.
@volt, @Grimsdyke
Old 20th January 2021, 21:07   #8240  |  Link
Klaus1189
4 and 5 are amazing. Love how the audio icon is also in a rounded rectangle just like the subtitle icon.
