14th October 2010, 16:53 | #9841 | Link | |
BluRay Maniac
check this for detailed instructions and parameters for x264 settings http://sites.google.com/site/x264bluray/home |
14th October 2010, 17:04 | #9842 | Link |
don't blame me!
I have got a question about the presets in the altenate movie-only output box.
Does the the preset MKV Container, 1920x1080, 192Kbs AC3 downmix to ac3 2.0 or does it keep the soround channels? Thx. |
14th October 2010, 18:40 | #9843 | Link | |
Thanks Mr. Dobbs,
I made the change to FFDSHOW and reran the program, this time I had a good run, pretty fast too, completed in about 90 minutes. That video encoding is pretty CPU intensive, it's the first time my quad core really broke a sweat! Anyway, thank you for a great application. I will be sure to contribute financially to support your efforts. Hope you can see it through to a GA version. Quote:
14th October 2010, 20:49 | #9844 | Link |
do not convert dts to ac3
I'm doing blu-ray to BD9. In settings I checked the box "do not convert dts to ac3". When BD-RB gets to "Reencoding audio tracks (if req'd)", I get windows message "wavi.exe has stopped working" and BD-RB stops working. When I close the windows message BD-RB starts working again and there are no error messages in the BD-RB log. The build is set to use LPCM only.
What is causing wavi.exe to stop? Is it my settings or something else?
Windows 7 Pro Quad Core Intel Core i7 920 Asus P6T Deluxe V2 2 ATI Radeon HD 4770 Video Cards 6GB OCZ Gold DDR3 1600 Intel X25-M 80GB SSD HD 2 HANNS-G 28" Monitors 2 Hyundai 19" Monitors |
14th October 2010, 21:21 | #9845 | Link |
Problem with audio-Bd Rebuilder 03501
- [18:11:31] Reencoding audio tracks (if req'd)
- [18:11:33] ReencodeAudio() 00075 1801 [22:16:30] - Failed to reencode audio, aborted In the latest beta or not recode the audio or gets me this error and fails. Anyone can help me |
14th October 2010, 22:56 | #9846 | Link | |
i:BlackmanResize( 1280, height, taps=5 ) i:QTGMC( Preset="Very Fast", EdiMode="nnedi3" ).SelectEven() i:BlackmanResize( width, 720, taps=5 ) But I'm dropping half the temporal resolution and x264 is still being given the -tff command, making it encode as if it were interlaced material and losing 8-15% bitrate efficiency. You're right that HD and SD would additionally need to be distinguished. Like an additional couple of avisynth prefixes, besides the i:, e:, etc. - one for SD and one for HD. *Or*, an option to specify one's own 1) deinterlacing method and 2) resizing method, quite apart from the avisynth filters section, would seem to cover all the bases? Like, besides just "Resize 1080p to 720p", have a suboption for *how*. And besides "use DECOMB filter on interlaced source", have a suboption for *how*? Perhaps configurable only as a hidden setting? |
15th October 2010, 00:35 | #9847 | Link |
You need to post the entire log, not just the parts you want me to see. Posting little pieces always makes me assume there is something you don't want me to see. Use "CODE" to wrap it (the "#" symbol at the top of the reply dialog) so it doesn't fill the page (it becomes scrollable).
15th October 2010, 00:47 | #9849 | Link | |
I'd need more information to try and figure out why you're getting the error. The audio .AVS file of the affected M2TS/track would help (AUD_XXXXX_YYYY.AVS, XXXX=M2TS number, YYYY=PID) . It would also be nice to know what disc you're attempting. One thing to remember is that if you are doing a movie-only to BD-9 and have "strict AVCHD" selected, the DTS audio is going to be reencoded to AC3 (even with "do not convert dts to ac3" selected). "Strict AVCHD" tells BD-RB that you want to stay compliant with the AVCHD standard -- and DTS doesn't exist in that standard. For a better explanation, read that section in the BD-RB FAQ post (it's a sticky in this sub forum). A little confusion on my part: If you're only keeping LPCM, why are you bringing up the "do not convert DTS" flag? BTW, LPCM is always converted for BD-9... it's too big to keep. Last edited by jdobbs; 15th October 2010 at 01:00. |
15th October 2010, 01:07 | #9851 | Link | |
15th October 2010, 01:34 | #9852 | Link | |
15th October 2010, 01:47 | #9853 | Link | |
15th October 2010, 03:15 | #9854 | Link |
BD Rebuilder works several times for me in the past, but now I get a windows popup error message "wavi.exe has stopped working"
Here is the lines a get in the log before the error : [19:02:05] BD Rebuilder v0.33.04 (beta) - Source: 82860856_DAVE_MATTHEWS_DISC_1 - Input BD size: 40.47 GB - Approximate total content: [02:55:19.901] - Target BD size: 7.72 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:02:07] PHASE ONE, Encoding - [19:02:07] Extracting A/V streams [VID_00012] - [19:02:08] Reencoding: VID_00012 (1 of 4) And this is from the cmd window: C:\BD_Rebuilder>"C:\BD_Rebuilder\tools\wavi.exe" "D:\WORKING\WORKFILES\AUD_00012 _4352.AVS" - | "C:\BD_Rebuilder\tools\aften.exe" -v 1 -b 224 -readtoeof 1 - "D :\WORKING\WORKFILES\AUD_00012_4352.AC3" Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. Does anybody has a clue about what is the problem ? Thanks, Olivier I'm having the same problem only when the original file is LPCM
15th October 2010, 03:18 | #9855 | Link | |
15th October 2010, 04:18 | #9856 | Link | |
I've attached a screenshot
15th October 2010, 07:13 | #9857 | Link | |
Not an answer full of suspicions |
15th October 2010, 13:59 | #9858 | Link | |
AUD_00006_4352.AVS #Created by BD Rebuilder - v0.35.01 (beta) LoadPlugin("C:\BD Rebuilder\BD_Rebuilder\tools\nicaudio.dll") audio=DirectshowSource("00006.track_4352.wav").Amplify(1.2) audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio ConvertAudioTo16bit(ResampleAudio(audio, 48000))
15th October 2010, 14:09 | #9859 | Link | |
Error 10/15/2010 8:37:29 AM Application Error 1000 (100) Log Name: Application Source: Application Error Date: 10/15/2010 8:37:29 AM Event ID: 1000 Task Category: (100) Level: Error Keywords: Classic User: N/A Computer: Waynezo-i7-920 Description: Faulting application name: wavi.exe, version: 0.0.0.0, time stamp: 0x46c49fdf Faulting module name: ntdll.dll, version: 6.1.7600.16559, time stamp: 0x4ba9b29c Exception code: 0xc0000374 Fault offset: 0x000cdc9b Faulting process id: 0x1f18 Faulting application start time: 0x01cb6c65b9ef6da3 Faulting application path: C:\BD Rebuilder\BD_Rebuilder\tools\wavi.exe Faulting module path: C:\Windows\SysWOW64\ntdll.dll Report Id: f87d91d9-d858-11df-83c6-90e6ba2fb081 Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID> <Level>2</Level> <Task>100</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2010-10-15T12:37:29.000000000Z" /> <EventRecordID>196527</EventRecordID> <Channel>Application</Channel> <Computer>Waynezo-i7-920</Computer> <Security /> </System> <EventData> <Data>wavi.exe</Data> <Data>0.0.0.0</Data> <Data>46c49fdf</Data> <Data>ntdll.dll</Data> <Data>6.1.7600.16559</Data> <Data>4ba9b29c</Data> <Data>c0000374</Data> <Data>000cdc9b</Data> <Data>1f18</Data> <Data>01cb6c65b9ef6da3</Data> <Data>C:\BD Rebuilder\BD_Rebuilder\tools\wavi.exe</Data> <Data>C:\Windows\SysWOW64\ntdll.dll</Data> <Data>f87d91d9-d858-11df-83c6-90e6ba2fb081</Data> </EventData> </Event>
15th October 2010, 15:22 | #9860 | Link | |
@waynezo
That's now 6 posts all reporting the same error. Here is a quote from the first post of this thread: Quote:
