5th June 2018, 04:58 | #51161 | Link |
Is the processing used by your TV any different than when you use your Blu-ray player?
Also, try setting calibration to BT.2020. The display is likely expecting BT.2020. Maybe this will also fix your color issue. I assume you’re referring to SDR mode. You might also want to try BT.709 to see if it makes any difference.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 5th June 2018 at 05:01. |
5th June 2018, 05:05 | #51162 | Link |
And I didn't mean to be insulting with the quest for perfection comment. I was just saying it isn't easy to tweak things to be perfect. There are too many factors involved to get it right for every system with every source.
5th June 2018, 11:36 | #51163 | Link | |
Right now I'm away from home and I'll only be able to test those settings further when I'm back. I'll try to take some pictures for comparison but I believe I'm 90% there with madVR, it might be just be a matter of one of two tweaks. Also I've slowing reading your guide on all the settings to understand those properly. Once again, thank you. |
5th June 2018, 16:39 | #51164 | Link |
I would disable calibration controls in madVR and try sending the source through as BT.709. The color space conversion is most likely place for things to go wrong if you aren't using something like PC or game mode on the TV.
5th June 2018, 16:52 | #51165 | Link | |
I'm using Game mode while using it as a desktop and when I start a movie I change it to Cinema pro. I'll test those chroma subsampling test patterns to find out if chroma is being downsampled to 4:2:0 while in Cinema pro mode. |
5th June 2018, 19:07 | #51166 | Link | |
I'm also getting much lower render times, but "true" render times seem to be the same, and they're just incorrectly reported. I drop frames at the same rate with slightly too taxing settings before and after the update regardless of what the OSD says is the render time. |
5th June 2018, 19:14 | #51167 | Link |
OK good news. thank you for this information. I have asked several time this question and did not have feedback.
"Turn off all of focus assist" : what do you mean ? is this option in the zoom menu of madVR ? Is it a good solution to remove this update and go back to 1709 waiting for a better day ? Last edited by Polopretress; 5th June 2018 at 19:17. |
5th June 2018, 19:15 | #51168 | Link | |
5th June 2018, 20:41 | #51169 | Link |
It is a new Windows 10 feature, search Windows 10's settings for "focus assist".
madVR options explained |
5th June 2018, 23:26 | #51170 | Link | ||
I was not aware of this new feature which is named completly differently en French windows ..... I have tested and disable and all works fine now. This new feature is very closed from the function "exclusive" but more open to configuration. Is it forcasted by Microsoft to be a replacement of the actual FSE ? Quote:
6th June 2018, 02:06 | #51171 | Link |
I wanna ask the senior masters here about how to turn off madVR smooth motion features and restore original frame rate,for example restoration of 23.976 fps.Because my cpu usage is so high that the 4K uhd images appear choppy and the sounds appear stammering,I think it should get possibly better to turn off maVR smooth motion features.
Would senior masters here like to feed back to Mr.madshi about the bug? |
6th June 2018, 06:43 | #51174 | Link |
I'm having many problems all of a sudden, and I need help.
First, my HZ on my TV used to be 23.97600-23.97602 or so, now when I set windows to 23HZ mpc-hc stats say it's at 23.979. If I set a custom mode, the closest I can get is 23.97655, which causes a repeat every 20-30 minutes, not terrible but I can't see a reason this changed. I updated to Windows 10 1803 and my Sony X930E TV firmware updated around that time as well. Video Card is GTX 1080Ti, and I've tried going back several driver versions, would anyone know a cause or fix? Secondly, I am having trouble entering Full Screen Exclusive mode, sometimes it takes 30 seconds or more, sometimes it never happens, with the result being that my Windows on my other monitor become laggy. I've re-installed Windows 10 1803 and run the default settings batch file in madvr directory, and with nothing installed or changed on the system, both issues happened again immediately. My last question, I was thinking of building a dedicated PC for movie watching, I thought I read somewhere that Radeon's have better chip timing or what have you over Nvidia cards for true 23.976 playback, is this true? I want 4K+HDR, so which would be the best card for this to put into this new PC (price not an issue). |
6th June 2018, 09:37 | #51175 | Link |
@suanm
madVR uses the GPU not the CPU to use smoothmotion. you uncheck smoothmotion to disable it that'S all. if you get high CPU usasges with DXVA copyback you may need a GPU or CPU that can decode HEVC first... @JamesG76 you don't try to get 23.976 to stop frames from repeating/dropping if you try todo that you missed the point why there is even a repeated dropped frame. and yes AMD is usually closer to 23.976 but that'S not the source of the underlying problem. |
6th June 2018, 10:03 | #51176 | Link |
I'm no expert on this stuff, but I thought if the video FPS was 23.976 and the display is over or under that, then the video will become out of sync from the audio and you need to repeat or drop frames to get them back in sync. Where should I start if that is not the problem?
6th June 2018, 10:36 | #51177 | Link | |
Bit in-depth, but have a look at this, just for the explanation at least. https://forum.doom9.org/showthread.php?t=173571 Ironically, I fixed mine with this link below, and just had to change 1 figure, but maybe a fluke, and as has been said it does not sit at 23.976 when playing, more like 23.97544 once it stabilises for me anyway, and must be right for the audio clock to synch on my setup, as I get a few hours. https://forum.redfox.bz/threads/how-...-nvidia.72844/ I went back to older drivers to see if that helped, running 390.77 at the moment. I also updated to the latest Windows Insider build Version 1803 OS Build 17682.1000 and apart from having to create a custom resolution again with the 2nd link, its working fine. |
6th June 2018, 10:37 | #51178 | Link |
@huhn
I'm surprised my cpu usages are not too high(around 28% cpu usages) as I play 4k HDR movies with potplay and its in-built D3D11 renderer.Only disadvantage with the playback way is that HDR passthrough doesn't work.I only watch 4k SDR movies although my TV set and original movies are with HDR features. |
6th June 2018, 10:51 | #51179 | Link |
@huhn
When i decrease resolution to 2556*1600P,seems to play fluently movies with madVR HDR passthrough mode.Can you give me some useful advice about how to optimize CPU usages while the playback of 4K HDR movies? Thank you. |
6th June 2018, 10:54 | #51180 | Link | |
It sounds more like you have the settings up way to high on any scaling settings and hammering your system. If you explained more about what setup you have, and what you are trying to do, then there will be better answers, as the smooth motion you mention does not fit in with what your problems are. https://forum.doom9.org/showthread.php?t=171787 http://forum.kodi.tv/showthread.php?tid=259188 Last edited by madjock; 6th June 2018 at 10:58. Reason: links |
