Old 3rd January 2015, 12:49   #1141  |  Link
jpsdr
but I will certainly do it before the next "final" release.
That's finaly all that matters.
Old 3rd January 2015, 16:14   #1142  |  Link
justonce01
Got it. Thanks.
justonce01 is offline   Reply With Quote
Old 10th January 2015, 22:38   #1143  |  Link
Octo-puss
Would it be possible to add the possibility to add entire folder(s) as a source? I have one huge folder containing the discography of a band I want to encode, and it's very annoying to add each album manually.
Octo-puss is offline   Reply With Quote
Old 11th January 2015, 11:43   #1144  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Try "File" → "Open Folder Recursively"
Old 12th January 2015, 15:08   #1145  |  Link
Octo-puss
Haha thanks, I didn't think there was any other functionality hidden somewhere in the menus. Could you add it as an extra button though, please?
Old 13th January 2015, 21:42   #1146  |  Link
LoRd_MuldeR
Software Developer
Hmm, I don't think I will add yet another button for this.
Old 14th January 2015, 09:26   #1147  |  Link
Octo-puss
Why not? It makes perfect sense. Lots of programs have extra buttons for either selecting a file or an entire folder. Why would I have to go to a menu to do something that is so similar to something else that has its own button? It's not like my arm would fall off by going into a menu instead of clicking on a button, but as you could see, I didn't even think such functionality existed, because the first impression you get from LameXP is that all the functionality is right there in the windows.
Old 14th January 2015, 20:43   #1148  |  Link
LoRd_MuldeR
Software Developer
I think the button triple of "Add", "Remove" and "Clear" is good just the way it is. So I don't want to spoil the clarity of the GUI. Adding a second (slightly different) "Add" button would be kind of redundant. Also I believe that adding a whole directory structure recursively is not something that most users need most of the time. And if they ever need it, the "File" menu is the most obvious place to look for something like this. But maybe I'll add a word or two to the manual.
Old 14th January 2015, 21:21   #1149  |  Link
manolito
manolito's Avatar
XMPlay uses another interesting alternative:
It only has single buttons for adding / removing titles, but if you right-click one of the buttons it deals with whole folders instead of single files. Another possibility would be using Shift-Click for dealing with folders...
Cheers
manolito
Old 14th January 2015, 22:50   #1150  |  Link
LoRd_MuldeR
Software Developer
... But maybe I'll add a word or two to the manual.
Done.
Old 16th January 2015, 14:03   #1151  |  Link
schiff1108
I would like to understand the approach on tags. What tags should get copied from source to output?
In particular I am missing the tags "composer" and "album artist".
When I check the source file with MediaInfo, I do find the tag values as expected. I have made some shots with using Custom Encoding Parameters, but w/o success.
schiff1108 is offline   Reply With Quote
Old 16th January 2015, 22:19   #1152  |  Link
LoRd_MuldeR
Software Developer
Meta data is extracted from the original file via MediaInfo. It then will be kept in an internal data structure. And finally it will be re-embedded into the output file, according to the individual encoder's capabilities.
One important thing to understand is that there is not the one standard for meta information! Every file format uses its own eccentric way to keep meta information. Some file formats, like e.g. MP3's "ID3v1" tags, are very limited, with only a few pre-defined fields. With those you can only use the pre-defined fields and that's it. At the same time, some other formats are very flexible, because they store arbitrary key-value pairs. On the one hand, this flexibility is great. But on the other hand, it makes it hard to figure out which keys are actually used practice - and which ones are actually recognized by (most) applications. Therefore "copying" meta information from one file format to another one is not as trivial as you might imagine!
The approach that I took with LameXP is that I designed the internal "meta information" data structure roughly as a "smallest common denominator" for what most file formats offer. This data structure will be filled with the meta tags that MediaInfo brings up. However, not every information that MediaInfo might be able to extract from a specific file format necessarily has an equivalent field in the internal data structure! There are far too many different (obscure) tags that might appear in some file to reserve a field for every single one of them. Instead, our internal data structure is restricted to the most important tags. So it's quite possible that we can not retain every single bit of information that MediaInfo has tracked down!
[EDIT]
Currently, the meta information that can be kept in the internal data structure are as follows:
QString m_titel;
QString m_artist;
QString m_album;
QString m_genre;
QString m_comment;
QString m_containerType;
QString m_containerProfile;
QString m_audioType;
QString m_audioProfile;
QString m_audioVersion;
QString m_audioEncodeLib;
unsigned int m_audioSamplerate;
unsigned int m_audioChannels;
unsigned int m_audioBitdepth;
unsigned int m_audioBitrate;
unsigned int m_audioBitrateMode;
unsigned int m_duration;
unsigned int m_year;
unsigned int m_position;
ArtworkModel m_cover;
Old 16th January 2015, 23:45   #1153  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Would you consider adding a QMap of unknown and custom tags, that can be re-embedded if the output supports them?
Old 16th January 2015, 23:58   #1154  |  Link
LoRd_MuldeR
Software Developer
I don't think that would solve anything. Of course, with a Map we can maintain arbitrary key-value pairs. That is very flexible, obviously. So we could simply dump everything that MediaInfo brings up into the Map. That's straight forward. But the real challenge here is that, eventually, we need to re-embed all that information into the output file! For example, the LAME encoder accepts a "--tt" switch to specify the "title" of the track and a "--ta" switch to specify the "artist". Thus, I know that if we are using LAME, then I need to pass the value of m_titel via "--tt" switch and the value of m_artist via "--ta" switch. But what to do with the "PhaseOfMoonWhenThisAlbumWasRecorded" entry, if such key appears in the Map?
Old 17th January 2015, 10:28   #1155  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Well, if you have Ogg/FLAC or APE tags you just write them back as-is, same if you're going from one id3v2 format to another, just copy everything. (Except encoder and created date tags.) For everything else, map if tags are standardized, drop if not; no one's going to seriously expect to see a PhaseOfMoon tag to end up in mp3. You must already have a map of common entries from one format to another, in the form of the conversions to and from your variables, since id3v2 and Ogg tags are completely different, so it's mostly a matter of extending that with more common tags and allowing arbitrary ones to pass through if possible.
(Album Artist is especially extremely common and part of the default file properties GUI in almost every media player, so that in particular should get special treatment. Even if the Vorbis and id3v2 specs don't mention it, the defacto standard is ALBUMARTIST for the comment tag and TPE2 for id3v2.)
I can try to whip something up if you like, I'm free tomorrow.
Old 17th January 2015, 15:14   #1156  |  Link
LoRd_MuldeR
Software Developer
It's not as simple as that, I think. Any solution that is like "if we are going from file format A to file format B then let's do it like this, and if we are going from file format C to file format D then let's do it like that" is not really feasible in practice, because there are way to many possible combinations. Having to implement a special path for each possible combination is no good solution and is hardly extensible. Instead, what we need in practice are solutions that work from any file format to any file format. This, however, requires boiling things down to a "smallest common denominator". And then, of course, not every eccentricity of every file format can be retained. But that's an acceptable trade-off.
For example, the LAME encoder has a dedicated "--ta" switch to set the "artits" of the track. So if the original file had an "artist" tag, we certainly want to pass this via "--ta name" switch, and not via the generic "--tv key=value" switch (introduced with ID3v2.3). Now you could say that we have a few recognized tags that will be passed via dedicated switches and everything else is passed via the generic "--tv" switch. However, what if the original did not have an "artist" tag, but did have a "performer" tag instead? In this case we probably want to pass the value of the "performer" tag to the "--ta" switch, rather than the generic "--tv" switch! Thus, some "smart" mapping of the commonly used tags needs to be implemented.
But we don't want to re-implement this required mapping again and again in every single encoder class! Currently, the required mapping happens at one single point! And that's the FileAnalyzer class. After that, our internal data structure either has a value in its m_artist field, or not. That's a clean design. And the LameEncoder class does not need to care about file format eccentricities, e.g. whether the info originally had been called "artist", "performer" or whatever. LAME simply passes the value of m_artist to the "--ta" param. And that's it! Making the FileAnalyzer class "dumb", by having it dump everything into a Map, would require scattering the actual processing of metainfo among all the Encoder classes - bad code design, IMHO.
Old 17th January 2015, 19:10   #1157  |  Link
soneca
It would be very difficult to implement an access to a database to LameXP and thus choose from such information to this database?
Old 17th January 2015, 22:19   #1158  |  Link
LoRd_MuldeR
Software Developer
You mean like Gracenote or FreeDB?
I haven't digged into this topic enough to give a definite answer. I would have to see what kind of API these services offer and whether we can use them 100% free of charges. Somehow they need to "analyze" the audio file in order to be able to determine the meta info. So, if their API requires access to the "raw" (uncompressed) audio data to do the required analysis, it probably wouldn't fit into LameXP. That's because LameXP doesn't actually decompress the input audio files until they are actually converted. And if they require the application to compute some kind of "fingerprint" which is then sent to the web-server for analysis, then it all would depend on how exactly that fingerprint has to be computed...
Old 18th January 2015, 01:19   #1159  |  Link
soneca
That's it!
But not to analyze file by file, but the cd's as a whole, the commercial albums.
As the plugin (CTBD) of Cuetools for example.
Old 25th January 2015, 19:14   #1160  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.11 Beta-14
http://sourceforge.net/projects/lame...4.exe/download
Changes between v4.10 and v4.11 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2013 with Update-4
* Starting with this version, LameXP is based on the MUtilities library + massive code clean-up
* Updated MediaInfo to v0.7.72 (2015-01-07), compiled with ICL 15.0 and MSVC 12.0
* Updated SoX to v14.4.2-Git (2012-10-06), compiled with ICL 15.0 and MSVC 12.0
* Updated Opus libraries to v1.1.x and Opus-Tools v0.1.9 to latest Git Master (2014-10-04)
* Updated mpg123 decoder to v1.21.0 (2014-10-11), compiled with GCC 4.9.1
* Updated Vorbis encoder to OggEnc v2.87 (2014-06-24), using libvorbis v1.3.4 and aoTuV b6.03_2014
* Updated Vorbis decoder to OggDec v1.10.1 (2014-06-25), using libVorbis v1.3.4
* Updated FLAC encoder/decoder to v1.3.1 (2014-11-26), compiled with ICL 15.0 and MSVC 12.0
* Updated GnuPG to v1.4.18 (2014-06-30), compiled with GCC 4.9.1
* Updated QAAC add-in to the latest to QAAC v2.44, including a fix for the --artwork option
* Fixed potential crash in Cue Sheet importer (occurred when all input files were missing)
* Fixed a severe performance bottleneck, especially with a large number of parallel instances
* Fixed a very rare problem that, occasionally, prevented the TEMP folder from being removed
* The limit for the maximum number of parallel instances has been increased to 32
* Experimental support for Windows 10 Technical Preview
