Old 4th June 2014, 11:05   #241  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
New version 4.0.0 changes:
-Added: Video downloader
-Added: Total progress will be updated more smoothly
-Added: MP4Box progress will be shown
-Added: A tool to create gif image from video
-Added: An option to disable trimming
-Added: Audio track option won't be used for mpeg sources as default
-Fixed: Subtitle position wasn't used
-Fixed: Duration info in the file list wasn't updated after trimming
-Updated: FFMpeg
Download location.
Prefer portable version if you don't want to deal with software offers.
ozok is offline   Reply With Quote
Old 10th June 2014, 18:41   #242  |  Link
kolpotoru
Originally Posted by Ryo94 View Post
Hi ozok, is it possible to join/merge video segments (same AR, bitrate, codecs, etc) in direct copy (no losing quality) with tencoder? If not is there any chance to implement this in a near future? thanks in advance.
Originally Posted by ozok View Post
I probably will add it as a tool.
edit: To make it more clear, not as a separate tool but as a function under "Tools" menu.
I was waiting for this feature in the new version. But didn't find it in the changes log.
kolpotoru is offline   Reply With Quote
Old 10th June 2014, 21:23   #243  |  Link
ozok
ozok's Avatar
I didn't give a specific time about that. I'll add it, don't worry. I already had codes ready for video downloader so I implemented it first.
Old 10th June 2014, 22:49   #244  |  Link
kolpotoru
Thanks for clarifying that, looking foreword to it.
Old 5th July 2014, 13:01   #245  |  Link
ozok
ozok's Avatar
New version 4.1.0 changes:
-Added: TEncoder will now check output files after encoding
-Added: An option to keep ssa and ass subtitle styles
-Added: Info about subtitles won't be shown in summary list if FFMpeg is selected
-Added: TEncoder will now remember the active tab
-Fixed: Several problems with batch download link add
-Fixed: Couldn't read video codec of some files with more than one audio track
-Fixed: "Update video downloader" didn't work
-Updated: Youtube-dl
Download
Source
Edit: Think of this as a bug fix release. DVD ripper and merger will be in the next releases. I wasn't planning the release this one but I had to fix link adding bug.
Old 5th July 2014, 15:19   #246  |  Link
disto
Hello ozok, thank you for this great program.I have some feature suggestions.Can you use FFmpeg for burning subtitles not Mplayer.FFmpeg can use fontconfig and have ass/ssa subtitles.This option to keep ssa/ass style is very useful,can you provide gui to edit these styles (for example font,size,italic,bold color outline shadow).
Thanks again and sorry for my bad english.
disto is offline   Reply With Quote
Old 5th July 2014, 21:29   #247  |  Link
ozok
ozok's Avatar
@disto Last time I tried to use ffmpeg to burn in subtitles it didn't work. Perhaps they improved it but I have to check it first. I can't add it if ffmpeg cannot burn in srt subtitles for example.
Old 19th July 2014, 14:29   #248  |  Link
ozok
ozok's Avatar
New version 4.2.0:
-Added: Post-encode options for video downloader
-Added: Users can now stop video link adding process
-Added: A few changes to progress interface
-Fixed: Adding an YouTube link from a playlist could cause some problems
-Fixed: Download time value written to log was always empty
-Fixed: Post-encode options weren't used
-Fixed: TEncoder couldn't write logs because logs folder wasn't created in some rare cases
-Updated: FFMpeg
There was a previous version I failed to post here:
-Added: A tool to add watermarks to video (thx to joby_toss)
-Added: A text to show video downloading progress
-Added: TEncoder will now check downloaded files too
-Added: A link to the list of supported video sites (thx to webfork)
-Added: TEncoder will save encoder logs into "logs" sub-folder (thx to webfork)
-Added: A few small interface changes
-Fixed: Stopping video downloader didn't reset progress informations
-Fixed: Update checker caused a message box to be shown when settings window was opened
-Fixed: Couldn't clear some logs
-Updated: FFmpeg
Source
Download
Old 5th August 2014, 10:21   #249  |  Link
disto
Thank you for the answer.
In this case can you implement gui for this option in mencoder ass-force-style.
This option can override ass/ssa style with user choice options.For example:
Gui for font,color,size,margins.Something like this:
Once again ,thank you!
P.S.1: In version 4.3.0 there is ability to add custom arguments to mencoder.I can write custom .ass style via ass-force-style and it works fine.Excellent job.
But there is one problem with mencoder,It can not use full cpu power.Even though i selected 4 threads in settings mencoder can not use 100 %.
In encoding settings can you provide an option for choosing threads to auto mode (threads=0).It probably can help to utilize full cpu power.
P.S:2:Are you considering to add support for mpv player?.It is a fork of mplayer/mplayer2/mencoder with different syntax for commands.
More info about mpv player encoding abilities: https://github.com/mpv-player/mpv.io...s/encoding.rst
P.S.3:Can you add an option for selecting FDKAAC.Sherpya mplayer/mencoder build support this encoder.
Old 6th August 2014, 15:46   #250  |  Link
ozok
ozok's Avatar
4.3.0 changes:
-Added: [Video Downloader] An option to skip download if output file exists and contains audio
-Added: [Video Downloader] Ability to enter user name and password
-Added: [Video Downloader] An option to disable thumbnail loading
-Added: [Video Downloader] Some interface changes
-Added: [Video Downloader] Improved video downloader starting performance
-Added: [Video/Audio Converter] Re-enabled "Delete unfinished files" option
-Added: [Video/Audio Converter] Moved custom arguments options to "Codec Options" window
-Added: [Video/Audio Converter] When "Direct Copy" is selected as video codec ffmpeg will be used
-Added: [General] Changed default skin to "Web2"
-Fixed: [Video Downloader] Downloaded "M4A DASH" and "WEBM AUDIO" audio files couldn't be played by some players
-Fixed: [Video Downloader] Logs weren't saved and shown properly
-Fixed: [Video Downloader] Did not encode to audio only
-Fixed: [Video Downloader] Did not encode to selected format
-Fixed: [Video Downloader] Some interface problems
Download
Old 7th August 2014, 19:53   #251  |  Link
ozok
ozok's Avatar
CPU usage depends on many things. The codec you are using, codec settings, input file's properties etc. I generally don't get 100% cpu usage when I use MEncoder so I run several instances of it at once. Make sure you unchecked "Use single process for x264" under "Encoding" settings.
I tried to make something out of mpv a while ago. It has many improvements over mencoder but syntax change isn't appealing (I don't remember syntax being too different than ffmpeg's). I'll keep it in mind though.
TEncoder doesn't use that mplayer/mencoder build anymore. I couldn't get it to work with subtitle fonts so I dumped it. Also fdkaac support needs and external library (a dll) file and I'm not sure if I can distribute it.
Old 8th August 2014, 05:36   #252  |  Link
disto
Yeah,i tried all available mencoder/x264 settings , but mencoder still use around 85% cpu.It's not Tencoder fault.
Mencoder is broken by design,ffmpeg is faster.But with mencoder is easier to hardburn custom styled .ass subs and i will stick with it.
I only ask to add option to choose fdk in audio codec settings in Tencoder.I will compile my own build.I dont like other aac encoders,fdk for now is best among others.
And at last one feature request.Can you add ability to edit whole command line options before encoding.For instance scale is used always and i want to remove it.
Once again thank you for this great program!
Old 22nd August 2014, 01:42   #253  |  Link
infante
subtitle help
Been trying out TEncoder to create "hard subtitles" into existing mpg files. This is the odd behavior we are seeing
1. Source video files are MPG, with MPEG 1 Audio Layer 2, FPS 29.97
2. trying to burn a subtitle file saved as an SRT and created in subtitle edit. The subtitles are perfectly syncd in subtitle edit
3. The exported settings are H264, 6000 KBPS, CBR, aspect ratio :keep, FPS: same as source, container: mp4
The end result has the subtitles out of sync but burned in.
Any suggestions to fix the sync? Any subtitle format other than SRT?
Also, the "Trim" feature tool is grayed out. Is this feature activated yet? any hints if so?
infante is offline   Reply With Quote
Old 22nd August 2014, 18:55   #254  |  Link
ozok
ozok's Avatar
@disto I don't think the mencoder version included in the package supports fdkaac. It's a bit old but is the only mencoder version that I've came across that respects subtitle font settings.
@infante Everything seems to right about your steps. Is it possible that mencoder detects source's fps wrong? I can't think of nothing else, please check encoder logs or post them here. Also, did you try first preview the file within TEncoder? You can enable trimming in settings window > encoding tab.
Regards.
Old 22nd August 2014, 21:24   #255  |  Link
infante
Hi Ozok
I've posted my logs here. There appears to be an extra frame??
the subs are in sync in the beginning and then slowly get worse and worse...
Curious. I thought that FFMPEG does support burned in subs using libass?https://trac.ffmpeg.org/wiki/HowToBu...itlesIntoVideo
Thanks!
Old 24th August 2014, 15:30   #256  |  Link
infante
Hi All,
found more info.
Our original steps which resulted in bad sync from TEncoder were: 1. digibeta source and captured/encoded to MPG with TMPGENC 2. Brought the MPG file into subtitle Edit (using VLC to display video) to sync subtitles and noticed it was off and resync'd the file. It looked good in subtitle edit when done. 3. re-encoded in TEncoder to burn subs which resulted in out of sync.
I wanted to confirm the source so I re-encoded the source to MKV and brought the MKV into subtitle edit and the SRT file worked perfectly without any modifications. I re-processed the "burned subs" in TEncoder and it sync'd perfectly!
I re-looked at the original MPG that resulted in the bad sync and interestingly VLC player was displaying the time code as 1:49:17 and TMPENC/AVANTI were both showing timecode at 1:49:49 .
So my conclusion is that VLC is the culprit as I used VLC as my video player in subtitle edit. VLC correctly read the MKV but incorrectly read the MPG which threw off everything else. I have since changed subtitle edit to use DirectShow and everything works well. Thanks Ozok for the message...
Old 15th September 2014, 12:56   #257  |  Link
ozok
ozok's Avatar
New version 4.4 is out. Changes in this release are:
-Added: DVD ripper
-Added: [Video/Audio Converter] Max. parallel process count is now 16
-Added: [Video/Audio Converter] An option to send TEncoder to tray while encoding
-Added: [Video/Audio Converter] Improved logs window's performance
-Added: [General] Switching between functions will enable/disable related UI controls
-Fixed: [Video/Audio Converter] MEncoder produced invalid ogg vorbis streams
-Fixed: [Video/Audio Converter] Support for FLAC encoding
-Added: [Video Downloader] Improved progress update performance
-Fixed: [Video Downloader] Couldn't stop batch url adding
-Fixed: [Video Downloader] "Argument out of range" error while downloading
Download
Old 28th September 2014, 19:29   #258  |  Link
kolpotoru
Is there any progress about adding video joiner tool?
There is a option in some video converters to "Enable GPU Acceleration" due to which the conversion becomes very fast please implement this feature in TEncoder if possible.
Old 14th October 2014, 16:42   #259  |  Link
ozok
ozok's Avatar
Changes for versions 4.5.0, 4.5.1 and 4.5.2:
-Added: [Video/Audio Converter] Support for embedded subtitles
-Added: [Video/Audio Converter] Support for ".ts" files
-Improved: [Video/Audio Converter] Audio track selection accuracy
-Improved: [Video/Audio Converter] FFMpeg encode starting performance
-Fixed: [Video/Audio Converter] Audio index problems with MEncoder
-Fixed: [Video/Audio Converter] Duration information from some mkv files couldn't be extracted
-Fixed: [Video Downloader] Couldn't mux if file name ended/started with space
-Fixed: [Profiles] Users could create profiles with empty file names
-Fixed: [Trimming] Reset didn't work properly
--4.5.1 Hotfix
-Fixed: [Video/Audio Converter] Wouldn't encode video if video stream wasn't the first stream
-Fixed: [General] Many memory leaks
-Fixed: [General] Version info shown in the interface was wrong
-Fixed: [General] 32bit versions would report memory leaks on exit
--4.5.2
-Removed: Ads from installers
Download
Source
@kolpotoru I can add this iff ffmpeg or mencoder supports it. AFAIK latest versions of ffmpeg has some hardware decoding support but I don't know to what extended that is. I constantly forget about merging. Sorry about that.
Old 22nd October 2014, 19:25   #260  |  Link
kolpotoru
Please add the video joiner in the next release because it is a important part of any video processing tool.
If Information about Hardware acceleration is not available now then we can wait until we find more information about it.
ffmpeg, gui, mencoder, multithreaded, subtitle
