Old 10th October 2017, 22:33   #14361  |  Link
madshi
eac3to v3.32 released
http://madshi.net/eac3to.zip
* added support for UHD Blu-Ray playlists and clip infos
* added support for h265/HEVC bitstream parsing
* added support for m2ts h265/HEVC splitting
* added support for MKV h265/HEVC splitting
* added support for h265/HEVC framerate modifications
* added detection for Dolby Vision Enhancement Layer
madshi is offline
Old 10th October 2017, 23:32   #14362  |  Link
Thunderbolt8
nice, thanks for an update!
can you comment on how accurate HEVC UHD BD support & remuxing is? Im referring to that you said you dont have/didnt use to have exact UHD specifications to implement this.
is all metadata like HDR and dolby vision remuxed as well?
Thunderbolt8 is offline
Old 10th October 2017, 23:37   #14363  |  Link
madshi
Well, I can't *re*mux HEVC, just *de*mux, because I'm still using the Haali DirectShow filter for MKV muxing, which doesn't support HEVC. But other than that I think everything should work just fine. But of course I can't guarantee that there are no bugs, so some testing might make sense.
madshi is offline
Old 11th October 2017, 00:17   #14364  |  Link
Gizzmo
thanks for the update. Tryed it and now the UHD BD structure is recognized. But the videostream with h265/HEVC is not recognized
as videostream. It is shown as audiostream.
Maybe only a UI issue, with Clown_BD ? Will do the demux now.
Gizzmo is offline
Old 11th October 2017, 06:08   #14365  |  Link
Thunderbolt8
has the format and structure of .sup files changed with UHD BDs in any way compared to regular BDs? or did everything stay the same?
Old 11th October 2017, 08:52   #14366  |  Link
XadoX
XadoX's Avatar
Is there a way to get the eac3to console output in PowerShell in multiple lines? For me eac3to outputs everthing only into the first line.
XadoX is offline
Old 11th October 2017, 08:56   #14367  |  Link
madshi
Originally Posted by Gizzmo View Post
thanks for the update. Tryed it and now the UHD BD structure is recognized. But the videostream with h265/HEVC is not recognized as videostream. It is shown as audiostream.
This is very likely to be an issue with Clown_BD, not with eac3to.
I don't know, haven't tested that yet, why don't you give it a try and report back?
Weird. It works for me with PowerShell in Windows 10. I wouldn't really comment using PowerShell for eac3to, though. A simple command line window is probably the better choice. E.g. PowerShell already stumbles if you do something like "eac3to 1)", it doesn't like the ")".
madshi is offline
Old 11th October 2017, 09:10   #14368  |  Link
XadoX
XadoX's Avatar
...Weird. It works for me with PowerShell in Windows 10. I wouldn't really comment using PowerShell for eac3to, though. A simple command line window is probably the better choice. E.g. PowerShell already stumbles if you do something like "eac3to 1)", it doesn't like the ")".
Hmm... maybe I have to change some setting in PowerShell.
Yeah I am still using CMD, but since Microsoft removed the feature "Start CMD here" with right click in Win10 I am using PowerShell often for quick demuxing.
XadoX is offline
Old 11th October 2017, 09:13   #14369  |  Link
madshi
It's easy to get the "Start CMD here" back, a quick google search will tell you how.
madshi is offline
Old 11th October 2017, 09:14   #14370  |  Link
XadoX
XadoX's Avatar
I know the reg value. But somehow it feels wrong to use things that are not official implemented
It's just a matter of time CMD dies completely.
XadoX is offline
Old 11th October 2017, 09:21   #14371  |  Link
The reason for this issue is probably that eac3to prepends every output text line with a large number of backspace characters.
I have no clue why Madshi believes this to be necessary.
LigH is offline
Old 11th October 2017, 13:04   #14372  |  Link
hubblec4
Matroska find' ich toll
Thanks for the new version, madshi.
Nice to see that few first features for UHD-Bluray are come.
Have you new (hidden)switches implemented?
hubblec4 is offline
Old 11th October 2017, 13:55   #14373  |  Link
d3rd3vil
So how can I use eac3to to just show all the information about a video stream like the Dolby Vision layer and stuff?
d3rd3vil is offline
Old 11th October 2017, 14:55   #14374  |  Link
hubblec4
I have extracted UHD-BD sup files with the new eac3to and all seems to work. BDSup2Sub read the sups and extract also forced sups.
hubblec4 is offline
Old 11th October 2017, 15:32   #14375  |  Link
Originally, eac3to was a tool to process audio streams. If you want to know "all details" about video streams, you will probably need different tools.
LigH is offline
Old 12th October 2017, 01:37   #14376  |  Link
Megalith
I just realized I haven't updated eac3to since 3.27 (the version that comes with Clown_BD). One of the most significant fixes appears to be "TrueHD Atmos streams could not be demuxed or decoded," but I have been able to extract these just fine for remuxing. Is that weird?
Megalith is offline
Old 12th October 2017, 16:15   #14377  |  Link
tebasuna51
tebasuna51's Avatar
Thanks madshi.
In my first test all seems ok.
Can you do anything with EAC3 tracks?
At last to preserve the name 'eac3'to
tebasuna51 is offline
Old 12th October 2017, 16:19   #14378  |  Link
madshi
What do you mean? E-AC3 tracks should be fully supported.
madshi is offline
Old 12th October 2017, 20:15   #14379  |  Link
tebasuna51
tebasuna51's Avatar
Not all:
http://bugs.madshi.net/view.php?id=450
https://forum.doom9.org/showthread.p...92#post1802092 and next
Old 12th October 2017, 23:46   #14380  |  Link
Blu-ray EAC3 (as core AC3 extension only) is still a different case, I believe... ffmpeg can't handle it yet, either:
Dependent substream decoding is not implemented.
LigH is offline
eac3to
