Old 9th July 2015, 19:16   #201  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by sl1pkn07 View Post
[del]please send me your github user[/del]
oh, you forked it. then i can remove from my repository?
Yes, and thanks. I took configure and GNUmakefile.
Khanattila is offline   Reply With Quote
Old 9th July 2015, 19:27   #202  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Has anyone done comparison between KNLMeans and FF3DFilter denoising quality? What's the difference?
MysteryX is offline   Reply With Quote
Old 10th July 2015, 13:55   #203  |  Link
feisty2
I'm Siri
feisty2's Avatar
NLMeans slays
feisty2 is offline   Reply With Quote
Old 10th July 2015, 21:39   #204  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Yes, it does beat FF3DFilter! It also alters x264.exe encoding results as it gave me 41.8mb instead of 53.2mb without changing anything else, but it lost too much details in encoding. I'm trying again with higher encoding settings to compensate.
Question. For dual-graphics computer, to make sure it runs on the Radeon, if I'm running AVSMeter in a CMD shell, which application do I have to configure as "high performance", CMD or AVSMeter?
Old 10th July 2015, 23:33   #205  |  Link
Groucho2004
Oh my, this is so wrong on so many levels...
First of all, you did not tell us what settings you used for the de-noisers. Secondly, you're comparing apples and oranges, the algorithms of these 2 are very different. The difference in size of your encodes just means that KNLMeans (with the settings you used which we don't know) removed more noise and therefore details.
Using "higher encoding settings" will not bring back details lost with excessive de-noising.
No idea what "configure as high performance" means. You select the device with the KNLMeans "device_type" parameter. You can test it by using the "info = true" parameter.
Groucho's Avisynth Stuff
Old 11th July 2015, 03:25   #206  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Oh my, this is so wrong on so many levels... First of all, you did not tell us what settings you used for the de-noisers.
I did a very simple test. Replaced
fft3dfilter(sigma=3, bt=5, bw=48, bh=48, ow=24, oh=24, sharpen=.15)
with
KNLMeansCL(D=2, A=1, h=3)
Spatial has more impact on performance than Temporal, and I haven't seen much difference at all between D=2, A=1 and D=2, A=2
Thees two commands seem to give a similar level of noise-removal. With KNLMeansCL, however, the details are sharper and there is a bit less noise. The biggest difference is in zones with lots of artifacts, where it makes those look much better.
Which means that when I preview the script, KNLMeansCL definitely has more details. By encoding with x264.exe (preset veryslow), however, there's something about KNLMeansCL's patterns that makes x264 discard much more data. So the preview has more detail while the final file has less details.
I just have to play around to adapt the encoding quality setting to compensate for this. It's not an issue, but this is curious.
Old 11th July 2015, 06:43   #207  |  Link
feisty2
I'm Siri
feisty2's Avatar
not true, denoisers got their own ways to distinguish noise and actual image, and some does it better, so you can kill a lot of noise and lose not that many details, some does it, well, not that good, you lose huge amount of actual image along with noise, extreme case, blurring filter, the origin of all modern denoise filters, will sacrifice the whole image to remove noise
I wouldn't use frequency domain denoisers (FFT3D and its superior DFTTest ) to do regular kind of denoise stuff, they make ringings like all frequency filters, and very destructive to high frequencies unless you don't filter high frequencies at all
Old 11th July 2015, 08:03   #208  |  Link
Groucho2004
Yes, but my point was simply that one de-noiser removed more of the actual image which resulted in a lower encoding size. Even noise can be considered "detail", for example when it is used as an artistic tool ("300", "Black Swan").
Old 11th July 2015, 17:33   #209  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
and my point is that this isn't the case as it left MORE details
Old 13th July 2015, 18:35   #210  |  Link
Khanattila
Khanattila's Avatar
Version 0.5.7: https://github.com/Khanattila/KNLMea...ses/tag/v0.5.7
Old 14th July 2015, 04:25   #211  |  Link
feisty2
I'm Siri
feisty2's Avatar
G8! testing it right now
Old 15th July 2015, 08:11   #212  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I did an encoding test on another video. This time the output file was slightly larger than when using FF3DFilter. So, it alters the way x264.exe decides what to keep, and sometimes it gives a small output, sometimes a larger output, depending on the source.
The biggest difference I'm seeing between FF3DFilter and KNLMeans is that with this, the image almost appears 3D. Even with a very low quality source, the shapes somehow take a 3D life. Whereas the source itself is just flat; and with any blurring denoiser it still lo9oks flat.
Old 15th July 2015, 14:08   #213  |  Link
Khanattila
Khanattila's Avatar
I only changed the way it calculates the distance between two colors in a RGB color space. With YUV color space it is equal to the previous version.
Old 15th July 2015, 19:25   #214  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I wasn't comparing with your previous release, but with the other algorithm I was using before Great job. Definite improvement in my script.
And because this gets run first, all other operations afterwards start from better quality source and the difference gets amplified with NNEDI3 frame quadrupling. Another difference is that FF3DFilter needs sharpening afterwards, while this doesn't lose the sharpening to begin with.
Old 17th July 2015, 18:12   #215  |  Link
Khanattila
Khanattila's Avatar
I read the release notes of NVIDIA CUDA Toolkit v7.5 and OpenCL 1.2 is still missing. Really embarrassing.
I'll have to use the AMD APP SDK v2.9.1.
Old 17th July 2015, 18:26   #216  |  Link
Groucho2004
Not sure if we're talking about the same thing but OpenCL 1.2 has been supported by NVIDIA for a few months now (since driver version 350.xx I think). See also here
Old 17th July 2015, 19:51   #217  |  Link
Khanattila
Khanattila's Avatar
I'm talking about OpenCL headers and library.
To write a OpenCL program, a SDK in required, like CUDA Toolkit (Nvidia), APP SDK (AMD), INDE (Intel).
For execute a OpenCL program is only required a device drivers.
Old 17th July 2015, 21:03   #218  |  Link
Groucho2004
I see. Odd though that they have not provided a 1.2 SDK yet.
Old 18th July 2015, 03:14   #219  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
The OpenCL headers should be identical between APP, nVidia, and the official Khronos downloads anyway. nVidia's samples all use the official ones.
Old 18th July 2015, 08:46   #220  |  Link
Khanattila
Khanattila's Avatar
Yes sure. Nvidia software is more... practical, like https://developer.nvidia.com/nvidia-...studio-edition
