14th February 2018, 18:28 | #67 | Link | |
but if you in some case want to use deblocking pixelshader, then you can use Jan-Willem deblocking shader, but Of course madvr RCA deblocking filter have much better result. https://forum.doom9.org/showthread.php?t=157634 |
14th February 2018, 20:01 | #69 | Link |
just download Video pixel shader pack v1.4.7z http://www.mediafire.com/file/025vse...r+pack+v1.4.7z
and extract it, then change (.txt) file to (.hlsl), and add any shader you want to mpc. |
14th February 2018, 20:12 | #70 | Link | |
14th February 2018, 20:18 | #72 | Link |
Does MPC-BE have any features you miss in MPC-HC? Then changing is "worth" it. If not then not. I'm sticking to MPC-HC. Either way, switching between them is not a big deal as they are so similar. Not a big learning curve.
14th February 2018, 20:35 | #75 | Link | |
before madvr RCA deblocking filter appears i some times use r=6 as deblocker shader. yeah it is denoise shader but can get good deblock from him to. Last edited by ABDO; 14th February 2018 at 20:48. |
14th February 2018, 23:03 | #77 | Link | ||
There will not be installers for each minor update. All you need to do is install 1.7.14 and then replace the .exe with the newest version.
1) You guys discuss which shaders are good in ANOTHER topic. 2) Several people like a specific shader 3) The shader has decent performance. So include some performance test results in that OTHER topic. |
15th February 2018, 00:11 | #78 | Link | |
15th February 2018, 08:40 | #79 | Link | |
Last edited by foxyshadis; 16th February 2018 at 18:13. Reason: copyright violation |
