Old 12th January 2020, 17:46   #801  |  Link
sadly not on AMD as long as P010 is used DXVA2 chroma scaling is NN.
Old 12th January 2020, 18:16   #802  |  Link
eddman
Originally Posted by clsid View Post
Switching from DXVA2 native to copyback is enough here to fix the poor quality chroma upscaling with NVIDIA.
Tried it now. No change; still aliased. Only the solutions mentioned by huhn work here.
eddman is offline   Reply With Quote
Old 12th January 2020, 21:04   #803  |  Link
Antonio
@Antonio, I have improved the YDL bypass check to fix your issue.[/QUOTE]
Thank you very much, the detection of URL pointing to a media file should now work weither the address includes a "?" or not, with this new logic taking into account both situations.
All my gratitude to the people working on maintaining this great app active.
Antonio is offline   Reply With Quote
Old 13th January 2020, 09:52   #804  |  Link
Bozotheclown
Hello,
There is small inaccuracy in language dll:
Because mpcresources.uk.dll is for Ukrainian language so the name should be mpcresources.ua.dll uk is reserved for United Kingdom.
Bozotheclown is offline   Reply With Quote
Old 17th January 2020, 17:56   #805  |  Link
Andouille
Registered sausage
Andouille's Avatar
Originally Posted by Bozotheclown View Post
Hello,
You should make a "mpcresources.TR.dll" for TRolling.
Andouille is offline   Reply With Quote
Old 17th January 2020, 17:59   #806  |  Link
But tr is already turkish!
On the original request, uk is the official ISO 639-1 language code for ukranian. So, you are wrong.
This is about languages, not countries. And in the U.K. they speak English.
Old 17th January 2020, 18:14   #807  |  Link
Andouille
Registered sausage
Andouille's Avatar
If im not wrong english is default language and does not require any ressource iso named dll.
Where are iso named external files of lavfilter ???
Where is the mpchc source that says iso/itu/cancer is used by law ?
Searching for "iso 639 mandatory" did not make any result.
Is your point trumpist, graftist or zenitramist ?
Old 18th January 2020, 14:05   #808  |  Link
crunchlab
crunchlab's Avatar
@clsid
When MPC-HC is opened in full screen mode (Alt+Enter) I can't properly Alt+Tab to other apps. MPC-HC loses its focus, taskbar pops up on top of the video and that's it. If I press Alt+Tab again I will switch to the app following the one that I expected.
View > On Top is set to "Default", other options in that menu don't help either. Is this a bug or expected behaviour? Can anything be done about it?
This issue has been bothering me for some time because I do remember I could easily do it few years ago.
I'm on Windows 7, EVR (custom presenter) @ MPC-HC v1.9.0 x64
crunchlab is offline   Reply With Quote
Old 19th January 2020, 20:02   #809  |  Link
magic144
Hi - I'm trying MPC-HC again recently - had a question I couldn't figure out...
Is there any way to change the timeout on the auto-hide of the play/nav bar when in full-screen mode? I can't seem to find a setting for this and it's quite short right now.
Thanks in advance!
magic144 is offline   Reply With Quote
Old 19th January 2020, 23:50   #810  |  Link
clsid
No option for that. But you can hover your mousepointer over it to keep it visible.
Old 20th January 2020, 06:33   #811  |  Link
magic144
Thank you - I was asking with respect to a keypress to make it visible (e.g. CTRL+3), but I've since discovered there doesn't seem to be a keypress that exactly mimics the mouse-over anyway, so I'll just be doing that!
Very much appreciate the software and the feedback.
Old 21st January 2020, 19:40   #812  |  Link
clsid
1.9.1 is now available
Old 21st January 2020, 20:52   #813  |  Link
Klementh
Another one so soon, thanks a lot again clsid.
SHA-256 hashes:
MPC-HC.1.9.1.x64.exe: 0DFEFA7B41122D508AF53E14CB398DB09827928BBDC3BEEC0686A7FC87369453
MPC-HC.1.9.1.x64.zip: 25E176936A68BD666A9ECD08E55AD3F361AB87BA5F71CDE8984BA051CBC7DC46
MPC-HC.1.9.1.x86.exe: FCE6A84E6E6360D40F39803F8AB60A7F1F32124E37CB55815388CA1A14DF193E
MPC-HC.1.9.1.x86.zip: 7C130E81B6860197B8D42E9FD68F7EBC6C7BA9F1C7317B69F9F579A40E5F080B
Verify with Hashtab.
Klementh is offline   Reply With Quote
Old 21st January 2020, 21:23   #814  |  Link
Krishty
adipose, clsid – thanks a lot for fixing the MP3 cover memory leak and for maintaining my favorite player!
Krishty is offline   Reply With Quote
Old 22nd January 2020, 09:35   #815  |  Link
crunchlab
crunchlab's Avatar
@clsid
Could you please take a look at my post? For some reason it popped up in between of the old messages...
Old 22nd January 2020, 13:32   #816  |  Link
GCRaistlin
GCRaistlin's Avatar
clsid
Clicking on LAV Video system tray icon makes LAV Video properties to be displayed on the same display on which the player window is. This is very unconvenient if the video is playing back on a secondary display in full screen mode. Can you please change this behaviour to make the properties (as well as MPC-HC options) being always displayed on a primary display?
Windows 8.1 x64
Magically yours
Raistlin
GCRaistlin is online now   Reply With Quote
Old 22nd January 2020, 16:14   #817  |  Link
theoneofgod
Originally Posted by theoneofgod View Post
Good work with the dark theme.
I noticed a couple of label scaling issues with LAV Filters though. Check the images. Display resolution is 3840x2160 (150% scaling).
Audio:
https://i.ibb.co/H2mMwvm/Capture.png
https://i.ibb.co/59vbqMc/Capture2.png
Video:
https://i.ibb.co/xjMP43b/Capture4.png
https://i.ibb.co/P4qBrF0/Capture3.png
Good to see this fixed in 1.9.1, thanks!
theoneofgod is offline   Reply With Quote
Old 22nd January 2020, 17:10   #818  |  Link
clsid
Alt+Tab works fine for me.
That would probably require modifying LAVFilters code and I am not interested in that atm.
Old 22nd January 2020, 18:44   #819  |  Link
bitterman
Thank you as always for maintaining this wonderful player.
bitterman is offline   Reply With Quote
Old 22nd January 2020, 20:16   #820  |  Link
chros
chros's Avatar
+1 I don't know what would I do without HC and BE. Thanks guys!
