17th May 2010, 17:09 | #21 | Link | |
Thank you! It does work the first script, the second script comes from this post. He says he is only motion compensating the clip, but I dont know at what stage of the process output (I dont want to Despot) the clip as I dont understand the method. This paper explains very well my case I think, in the case of low frequence jitter artifacts. Anyways, I dont expect to go so far, fixing my actual script would be enough to start encoding.
Edit: What about this? I used the first "Despot Script" as the prefiltered clip of the second script. SSIM detects further changes. Now ideally I think that after the interleave command I should perform a strong temporal denoiser (temporalsoften?) to average those 3 frames. Problem is temporalsoften affects the 4th frame too thus creating an ugly blending. Quote:
EDIT: I just wanted to point out the investigation these guys are making on the subject using B-Splines with bUnwarpJ
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 25th May 2010 at 08:33. |
26th May 2010, 11:26 | #22 | Link | |
Thank you guys, at last I will use medianblur. I will start encoding in the next few days. Im also not using the mask as it was aimed at spot removal and cant load it with medianblurt nor any other filter.
Deshaker by Gunnar + Quote:
1Mb mp4 http://www.sendspace.com/file/rpjuv5
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 27th May 2010 at 22:50. |
bake, dejitter, deshake, stab, wave |
