30th December 2013, 19:02 | #18704 | Link | |
Mr
Never mind. I found it under Settings/Import Quick-Play settings. Last edited by dfsooner; 30th December 2013 at 19:40. |
31st December 2013, 07:45 | #18707 | Link |
It was a fun adventure for me to notice also. "Oh, not a funky feature or a rodent in the program...ahhhh!" You're welcome.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 31st December 2013 at 07:48. |
31st December 2013, 18:15 | #18708 | Link |
Hello jdobbs,
is it actually possible to run the first pass with a CRF (e.g. 20) and only run the second pass if the target size would be exceeded? This would help to reduce the size and also limit the size to a given value. Thanks! |
31st December 2013, 18:33 | #18709 | Link |
Hi jdobbs
They lent me a large collection of favorite movies on bluray. I would like to pass them as I always do with bd rebuilder but somehow able to remove the extras and things i do not want but retaining the original menu. I donīt know the option is there any way? Cheers and have a happy new year, you and everyone on the forum! |
31st December 2013, 18:44 | #18710 | Link |
This violates our forum rule 6, putting our forum in jeopardy. You cannot make backups of copyrighted videos that someone has lent to you. Stop this nonsense or strikes will follow.
I also see that you are cross-posting, violating rule 8. You need to read and follow our forum rules or you will run into difficulties here. Last edited by Guest; 31st December 2013 at 19:05. |
31st December 2013, 22:21 | #18711 | Link | |
Thanks for alerting me and tell me about this. I'll read the rules Honestly, I do not know, there was no bad intention Thank you again! |
2nd January 2014, 01:16 | #18716 | Link |
Tried a BD5 today with a one-pass CRF. The CRF value was 16.33 and the final disc 4.00gb.
When DVD Rebuilder misses the target by that much on a one-pass I'd normally deincrement the Q value, click 'Encode' then 'Rebuild'. Although a CRF of 16.33 probably can't be improved by much, is a similar method available to tune BD RB? Is a 3 step vs one-click setting coming in the future? What is the target size set to for a BD5, 4482mb or something less? @ Racer - If the target size of a one-pass fails, doing a second pass shouldn't improve either quality or encoding speed. A new CRF encoding after adjusting the value is the best answer (if it is possible). |
2nd January 2014, 01:37 | #18717 | Link | |
@DoctorM
2nd January 2014, 20:59 | #18720 | Link |
@gonca - I know when I've manually encoded using CRF (with MeGUI), tenths of a point rarely made much difference. Later I'm going to try testing clips and comparing 16.33 to 16.00. The bitrate difference should be awfully minor. To extrapolate 16.33 as the best with the next lower tested value is .69 below that seems like a pretty big estimation. Still, I don't know the algorithm used... and DVD RB's method always seemed damn good so I'm willing to assume it's still the best possible system.
@jdobbs - I'm a bit concerned about something though. Doing some further playing around with a BD25 to BD5 one pass CRF, I decided I wanted to compare source vs encode for quality. Code:
source=ffmpegsource2("(Source)\BDMV\STREAM\00000.m2ts").subtitle("Source") encode=ffmpegsource2("(BDRB Encode)\BDMV\STREAM\00000.m2ts").subtitle("Encode") interleave(source,encode) |
