20th October 2010, 11:36 | #3581 | Link | |
I am using the latest version (sorry for the confusion but I added two logfiles to my previous post). I have edited my previous post. |
20th October 2010, 12:09 | #3582 | Link | ||
HDConvertToX author
and aac audio is recognized too! try using mmg 4.3.0.. Quote:
please post on mediafire thanks BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
21st October 2010, 10:32 | #3584 | Link |
Thank you buzzqw for HDC. I just upgraded from Vista to Windows 7 and also from HDC 2.X to the latest 3.0.691.4632. For some reason, there is no converted file at the end. Any suggestion? What did I do wrong? Thanks.
HDConvertToX v.3.0.691.4632 report Input File: k:\hdc\job1\vts_01_1.vob ( L:\VIDEO_TS\VTS_01_0.IFO ) PGC : PGC 2. Length: 2:00:50:23 / chained=0 Codec Video: mpeg Width / Heigh : 720 / 480 Framerate / Framecount: 29.970fps / 217283 frames Duration(hh:mm:ss): 2:0:50 Aspect Ratio: 1.3334 Resized resolution: 720 / 480 Crop Values : 0:0:0:0 Activate: Crop Obey to AR Activate: Follow ITU Resizing No Resize & Crop: On Start Video Configuration -> Encoding Settings: X264 Extreme Quality ; Bitrate= 2000 Final Size: Denoise Level: None Set Manual Bitrate: 2000 Video Handling: Use Best Decoder Deinterlace: Interlaced -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 0.3 Audio Channels: 2 Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 80: English (AC3 2ch, 0xBD 0x80) [1] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G echo job number: 1 "C:\Program Files\HDConvertToX\applications\Vstrip\Vstrip.exe" @"K:\HDC\job1\list.ini" -i"L:\VIDEO_TS\VTS_01_0.IFO" -o"K:\HDC\job1\VTS_01_1.VOB" -p1 "C:\Program Files\HDConvertToX\applications\dgmpgdec\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[K:\HDC\job1\VTS_01_1.VOB] -OF=[K:\HDC\job1\movie] -exit -minimize "C:\Program Files\HDConvertToX\applications\eac3to\eac3to.exe" "k:\hdc\job1\vts_01_1.vob" 2: stdout.wav -normalize -down2 | "C:\Program Files\HDConvertToX\applications\audio\neroaacenc.exe" -if - -q 0.3 -ignorelength -of "K:\HDC\job1\hdencodertox-pid80.mp4" "C:\Program Files\HDConvertToX\applications\x264\x264.exe" --pass 1 --bitrate 2000 --preset medium --ref 4 --subme 9 --direct auto --trellis 0 --me umh --b-adapt 2 --bframes 4 --threads auto --thread-input --sar 1:1 --output "K:\HDC\job1\hdconverttox_vts_01_1.h264" "K:\HDC\job1\hdconverttox_vts_01_1.avs" "C:\Program Files\HDConvertToX\applications\x264\x264.exe" --pass 2 --bitrate 2000 --preset medium --ref 4 --subme 9 --direct auto --trellis 0 --me umh --b-adapt 2 --bframes 4 --threads auto --thread-input --sar 1:1 --output "K:\HDC\job1\hdconverttox_vts_01_1.h264" "K:\HDC\job1\hdconverttox_vts_01_1.avs" 2>HDConvertToX_x264_job1.log "C:\Program Files\HDConvertToX\applications\Chapter\ChapterXtractor.exe" "L:\VIDEO_TS\VTS_01_0.IFO" "K:\HDC\job1\chapters.txt" -p5 "C:\Program Files\HDConvertToX\applications\MKVtoolnix\mkvmerge.exe" -o "K:\HDC\BF-035.MKV" --default-duration 0:29.970fps --aspect-ratio -1:1.3334 --compression 0:none "K:\HDC\job1\hdconverttox_vts_01_1.h264" --compression 0:none --language -1:eng "K:\HDC\job1\hdencodertox-pid2.mp4" --chapters "K:\HDC\job1\chapters.txt" --title "BF-035. Done with HDConvertToX v.3.0.686.4609" -> End Queue AviSynth Script -> Working with files: K:\HDC\job1\hdconverttox_vts_01_1.avs Load_Stdcall_plugin("C:\Program Files\HDConvertToX\filters\yadif.dll") Mpeg2Source("K:\HDC\job1\movie.d2v") Yadif(mode=0,order=-1) ColorMatrix(d2v="K:\HDC\job1\movie.d2v") return last -> End AviSynth Script Last edited by psychoxxx; 21st October 2010 at 10:37. |
21st October 2010, 11:57 | #3585 | Link |
HDConvertToX author
please open the savs script ( K:\HDC\job1\hdconverttox_vts_01_1.avs ) with virtualdub or mediaplayer classic, got any errors ?
are you sure you have installed all required applications ? BHH
22nd October 2010, 09:40 | #3586 | Link | |
Media Player Classic Homecinema 1.4.2499.0 can play K:\HDC\job1\hdconverttox_vts_01_1.avs from the beginning to the end (all 2 hours). It has no audio which I think is normal. I have uninstalled and reinstalled all required applications: Avisynth_258, ffdshow_rev3611_20101006_clsid, MatroskaSplitter 1.10.262.12, Xvid-1.2.2-07062009 and HDConvertToX_3.0.691.4632 I set ffdshow to use libmpeg2 as decoder for MPEG2 and DVD, and wmv9 as decoder for VC-1. I selected Haali Media Splitter to Enable AVI support and Enable MPEG-PS support during installation. I set AVIMux_GUI to run in compatibility mode for WinXP SP2. Using Win7DSFilterTweaker_3_7, I selected ffdshow. I chose ffdshow (DXVA) when that option is available. I have also tried to run HDC as an administrator. Thanks. Code:
HDConvertToX v.3.0.691.4632 report Input File: k:\hdc\job1\vts_01_1.vob ( L:\VIDEO_TS\VTS_01_0.IFO ) PGC : PGC 2. Length: 2:00:50:23 / chained=0 Codec Video: mpeg Width / Heigh : 720 / 480 Framerate / Framecount: 29.970fps / 217283 frames Duration(hh:mm:ss): 2:0:50 Aspect Ratio: 1.3334 Resized resolution: 720 / 480 Crop Values : 40:0:40:0 Activate: Crop Obey to AR Activate: Follow ITU Resizing No Resize & Crop: On Start Video Configuration -> Encoding Settings: X264 Extreme Quality ; Bitrate= 2000 Final Size: Denoise Level: None Set Manual Bitrate: 2000 Video Handling: Use Best Decoder Deinterlace: Interlaced -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 0.3 Audio Channels: 2 Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 80: English (AC3 2ch, 0xBD 0x80) [1] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G echo job number: 1 "C:\Program Files\HDConvertToX\applications\Vstrip\Vstrip.exe" @"K:\HDC\job1\list.ini" -i"L:\VIDEO_TS\VTS_01_0.IFO" -o"K:\HDC\job1\VTS_01_1.VOB" -p1 "C:\Program Files\HDConvertToX\applications\dgmpgdec\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[K:\HDC\job1\VTS_01_1.VOB] -OF=[K:\HDC\job1\movie] -exit -minimize "C:\Program Files\HDConvertToX\applications\eac3to\eac3to.exe" "k:\hdc\job1\vts_01_1.vob" 2: stdout.wav -normalize -down2 | "C:\Program Files\HDConvertToX\applications\audio\neroaacenc.exe" -if - -q 0.3 -ignorelength -of "K:\HDC\job1\hdencodertox-pid80.mp4" "C:\Program Files\HDConvertToX\applications\x264\x264.exe" --pass 1 --bitrate 2000 --preset medium --ref 4 --subme 9 --direct auto --trellis 0 --me umh --b-adapt 2 --bframes 4 --threads auto --thread-input --sar 1:1 --output "K:\HDC\job1\hdconverttox_vts_01_1.h264" "K:\HDC\job1\hdconverttox_vts_01_1.avs" "C:\Program Files\HDConvertToX\applications\x264\x264.exe" --pass 2 --bitrate 2000 --preset medium --ref 4 --subme 9 --direct auto --trellis 0 --me umh --b-adapt 2 --bframes 4 --threads auto --thread-input --sar 1:1 --output "K:\HDC\job1\hdconverttox_vts_01_1.h264" "K:\HDC\job1\hdconverttox_vts_01_1.avs" 2>HDConvertToX_x264_job1.log "C:\Program Files\HDConvertToX\applications\Chapter\ChapterXtractor.exe" "L:\VIDEO_TS\VTS_01_0.IFO" "K:\HDC\job1\chapters.txt" -p5 "C:\Program Files\HDConvertToX\applications\MKVtoolnix\mkvmerge.exe" -o "K:\HDC\output\movie.MKV" --default-duration 0:29.970fps --aspect-ratio -1:1.3334 --compression 0:none "K:\HDC\job1\hdconverttox_vts_01_1.h264" --compression 0:none --language -1:eng "K:\HDC\job1\hdencodertox-pid2.mp4" --chapters "K:\HDC\job1\chapters.txt" --title "movie. Done with HDConvertToX v.3.0.686.4609" -> End Queue AviSynth Script -> Working with files: K:\HDC\job1\hdconverttox_vts_01_1.avs Load_Stdcall_plugin("C:\Program Files\HDConvertToX\filters\yadif.dll") Mpeg2Source("K:\HDC\job1\movie.d2v") Yadif(mode=0,order=-1) ColorMatrix(d2v="K:\HDC\job1\movie.d2v") return last -> End AviSynth Script Last edited by psychoxxx; 22nd October 2010 at 10:04. |
22nd October 2010, 11:39 | #3587 | Link |
HDConvertToX author
so.. launch from dos the encoding part
"C:\Program Files\HDConvertToX\applications\x264\x264.exe" --pass 1 --bitrate 2000 --preset medium --ref 4 --subme 9 --direct auto --trellis 0 --me umh --b-adapt 2 --bframes 4 --threads auto --thread-input --sar 1:1 --output "K:\HDC\job1\hdconverttox_vts_01_1.h264" "K:\HDC\job1\hdconverttox_vts_01_1.avs" BHH
22nd October 2010, 14:53 | #3588 | Link | |
maybe I should try the 2.X version on Windows 7? |
22nd October 2010, 17:53 | #3589 | Link |
Only mp3 in conversion with Win7 and HD-PVR
Been fighting this and can not figure it out:
Upp'ed to Win 7, and installed V3.0.691.4632 (from first post) now then, when using a video file recorded from an Hauppauge HD-PVR that is 1080i and Dolby Digital, I get a great pic but no audio unless I convert to mp3. I've looked through the thread - (we need to narrow this down into an FAQ maybe, it's so large) and can't find anything. Help? If it IS listed, just point me in the right direction. ************** edit ******************** Ok, I WASN'T using V3.x. Now that I am, I'm having problems with Win 7 complaining (they didn't fix that in this release) that xvid-encraw.exe has stopped working. Last edited by Macgyver; 22nd October 2010 at 21:19. |
23rd October 2010, 07:20 | #3590 | Link | ||
HDConvertToX author
you must get an error at some time (maybe at chapter extraction ?) Quote:
BHH
23rd October 2010, 10:11 | #3591 | Link |
I think the problem is the output file location which is a SATA HDD (drive K) connected to an onboard chip Marvell 61xx raid controller, not the Intel ICH10R chip. My motherboard is Asus P5Q-E (P45 and ICH10R). The converted file can be saved in another drive (drive H, connected to the ICH10R) but not the 2 drives (drives I and K) attached to the Marvell chip. Both drives I and K have over 100GB of free space and all drives are formatted as NTFS. I am not using RAID, just using the 2 extra SATA jacks from the Marvell chip as regular SATA connections. Perhaps it's a hardware driver and Windows 7 (32bit) issue? I am now testing another movie. Thank you so much for your help.
23rd October 2010, 10:32 | #3593 | Link |
@buzzqw
HDC v3 Source is .m2ts and target is .m2ts, blu-ray structure. Ticking 'Insert Chapters evey...' in the Muxing Tab has no effect. The chapters are not inserted in the .meta. Normally I would not use this because the chapters are extracted from the source .m2ts. However not all streams include a chapter track. In these cases the 'Insert Chapters every...' would be handy. Can it be done? |
23rd October 2010, 17:31 | #3594 | Link | |
Thank you. ***************** EDIT *********************** Correction: On the second pass it crashes, so that is still problem #2. BUT problem #1, is more interesting problem, if I convert using any video codec but the container is MP4, and use AC3/448/5.1 in the settings, the resultant file has no sound. If I change the container to anything else - the sound returns to the final file. **** added ***** When I play the ac3 file within the job folder it's fine. Ditto the video. Did I miss something along the way? Last edited by Macgyver; 24th October 2010 at 19:56. |
23rd October 2010, 23:44 | #3595 | Link | |
Playing with MKV files...
Heh, heh. I just now tried it again while I'm typing this and now it's working. Must have been a computer issue that required a restart. That's what I ended up doing. I never could get the subtitles to rip from the last chapter of my DVD for some reason. So I acquired a plain-text subtitle file from a third party and just remuxxed my original file, removing vsrip's subs and adding the text-based ones.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 |
25th October 2010, 07:54 | #3596 | Link | ||
HDConvertToX author
BHH
25th October 2010, 20:01 | #3599 | Link |
I'm using HDC 3.0 (updated) to do some DVD Backup test. I've tried several DVD from film to animation and i've encountered some problem with interlaced material. I've ripped the movie on my HD from the DVD with DVDfab and analyzed with the internal tool of HDC, here is the response (15% of total movie analyzed):
Spirited Away (Sen to Chihiro no Kamikakushi): Code:
Source is declared tff by a margin of 1306/75. Analyzed 774 sections of five frames Found Interlace Sections: 431 55.68% Found Progressive Sections:179 23.13% Found Telecined Sections: 164 21.19% Found Zero Mov: 23.13% 179 Found One Mov: 10.59% 82 Found Two Mov: 21.19% 164 Found Three Mov: 22.74% 176 Found Four Mov: 10.21% 79 Found Five Comb: 12.14% 94 The Movie is declared to interlaced Code:
Source is declared bff by a margin of 1898/6. Analyzed 2262 sections of five frames Found Interlace Sections: 1914 84.62% Found Progressive Sections:151 6.68% Found Telecined Sections: 197 8.71% Found Zero Mov: 6.68% 151 Found One Mov: 2.12% 48 Found Two Mov: 8.71% 197 Found Three Mov: 12.60% 285 Found Four Mov: 8.84% 200 Found Five Comb: 61.05% 1381 The Movie is declared to interlaced I've tried Interlaced, Interlaced HQ and Yadif Bob but i can't achieve a good result because the final output it's deinterlaced but lacks totally on sharpness (and it's not caused by the compression settings because i'm using a quite high value for CFR). It's like all the edges are all very blurry (maybe later i can post a screenshot). With progressive material, with the same settings for compression the result is almost identical to the original source with all details preserved. So the big question is: What is the best way to treat interlaced material (especially Animation and Cartoons)? What filters or chain of filters i should use? Is there a filter that you suggest from HDC? My first concern is quality so i don't bother for now on computing time or file size (i will find the good balance later ). Thanks for all help! EDIT: I've read all the suggestions from FPS100 and the best deinterlacer should be Combination of Bob+Weave (=Progressive Scan). Is it possible to achieve on HDC? Last edited by DottorLeo; 25th October 2010 at 20:06. |
25th October 2010, 21:03 | #3600 | Link |
Perfect, thanks!
Another minor issue: When I remove the tickmark for 'Log x264 encoding' in the 'Resizers & Options' tab, it is not saved when I 'Save Settings' but is always restored when I restart HDC. Is this intentional? Anyway, it's really not critical. |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
