Old 10th June 2016, 14:35   #14421  |  Link
Originally Posted by Zenophobe View Post
C:\>"C:\Users\Zenophobe\Downloads\RipBot264\EncodingClient.exe" "C:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
C:\>"C:\Users\Zenophobe\Downloads\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Zenophobe\Videos\Hunger Games, Mockingjay - Part 2, The (2015) [1080p] [PG-13].mkv" --compression 0:none --title "Hunger Games, Mockingjay - Part 2, The (2015) [1080p] [PG-13]" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:eng --sync 0:0 "C:\Temp\RipBot264temp\job1\1_audio_English.flac" --chapters "C:\Temp\RipBot264temp\job1\chapters.txt"
mkvmerge v9.1.0 ('Little Earthquakes') 32bit
Error: The file 'C:\Temp\RipBot264temp\video.264' could not be opened for reading: open file error.
Elapsed Time: 01h:48m:05s
Node Address : 192.168.1.197:1000
Encoded Chunks : 45 of 136 (33%)
Encoded Frames : 64792
Encoding Speed : 12 fps
Node Work Time : 01:28:56
Node Address : 192.168.1.197:3000
Encoded Frames : 64747
Node Work Time : 01:31:35
Node Address : 192.168.1.197:2000
Encoded Chunks : 46 of 136 (34%)
Encoded Frames : 67478
Node Work Time : 01:34:51
this is an e5 2680 v4 using 3 instances of the distributed encoder. Ideas?
run cmd.exe and then execute C:\temp\RipBot264temp\job1\Chunks\CombineAllChunks.cmd
And show us what you see.
Old 17th June 2016, 17:14   #14422  |  Link
soneca
Hello Atak, i am not able to convert flv files, RipBot264 does not detect/demuxing audio.
You could check this?
Old 17th June 2016, 17:47   #14423  |  Link
send me sample if you want me to take a look.
Old 17th June 2016, 19:09   #14424  |  Link
slalom
slalom's Avatar
Can we select by default 2 encoding clients (or more) for each PC, every time we run the program?
Preferably the second client minimized to tray too like the first one
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 17th June 2016, 20:13   #14425  |  Link
Sure you can.
Just create simple batch file
ripbot264.exe
EncodingServer.exe
EncodingServer.exe
Old 17th June 2016, 20:53   #14426  |  Link
soneca
Sent via PM.
Old 18th June 2016, 02:32   #14427  |  Link
burt123
burt123's Avatar
Sure you can.
ripbot264.exe
EncodingServer.exe
EncodingServer.exe
That sounds like a great idea, but excuse my ignorance, where do you put this "batch file", so it executes. ??
burt123 is offline   Reply With Quote
Old 18th June 2016, 08:04   #14428  |  Link
slalom
slalom's Avatar
You run the batch file instead of ripbot264.exe
Old 18th June 2016, 11:28   #14429  |  Link
It does not matter as long as you have valid path to executables
for example
RunRipBot264and2Servers.cmd
c:\program files\Ripbot264\Ripbot264.exe
c:\program files\Ripbot264\EncodingServer.exe
Old 18th June 2016, 12:21   #14430  |  Link
slalom
slalom's Avatar
What about minimizing the second server, like the first one does?
Old 18th June 2016, 13:23   #14431  |  Link
EncodingServer always starts in Tray (minimized) by default.
Old 18th June 2016, 16:10   #14432  |  Link
slalom
slalom's Avatar
Yes, the :1000. The :2000 minimizes to taskbar
Old 18th June 2016, 17:23   #14433  |  Link
soneca
Thanks Atak!
The problem is that the demuxing is extremely slow to flv files.
For this type of file will extract before using FLV Extract.
Old 19th June 2016, 06:35   #14434  |  Link
burt123
burt123's Avatar
for example
OK, I have to say it took me a little while to get this right, but I can only seem to get 2 encoding servers to start up, when I have 4, in the batch file.
Also, I put Ripbot in the Documents folder, which made it a little different.
Old 20th June 2016, 14:51   #14435  |  Link
fatpizza
I just noticed that when using Ripbot if I change the fps of a clip from 25fps to 23.976 the chapter times get sped up rather than slowed down. Is this an easy fix? Thanks.
fatpizza is offline   Reply With Quote
Old 20th June 2016, 19:36   #14436  |  Link
This should fix this silly mistake.
http://www.mediafire.com/download/jw...tChapterFix.7z
I was passing wrong values to this tool
ModifyChapters.exe "original-chapters.txt" (SourceNumberOfFrames/SourceFPS) / (CurrentNumberOfFrames/CurrentFPS) "chapters.txt"
but it should be in reversed order
ModifyChapters.exe "original-chapters.txt" (CurrentNumberOfFrames/CurrentFPS) / (SourceNumberOfFrames/SourceFPS) "chapters.txt"
Old 21st June 2016, 04:20   #14437  |  Link
fatpizza
Thanks, I looked inside the tools folder earlier on and noticed this so I was fixing it up myself by running my own cmd file. But not having to worry about doing that myself is better of course.
Old 21st June 2016, 19:59   #14438  |  Link
userx
userx's Avatar
shared folder
[QUOTE=Atak_Snajpera;1768168]
Added: hidden option to move mkv to shared folder. Following lines must be added manually to EncodingClient.ini
	[hidden settings]
	MoveMKVtoSharedFolder=1
Added: Updater automatically fixes corrupted updater.ini file
Fixed: Downmix 4.0 to 2.0 didn't work
Changed: In order to avoid language issues Encoding Client will share ripbot264temp folder using following command line
	icacls "...\RipBot264temp" /T /C /Q /Grant:R *S-1-1-0:(OI)(CI)F
I manually shared the RipBot264temp folder and after client has started, the networkshare disapears again.
(On commandline icacls cmd is working)
userx is offline   Reply With Quote
Old 23rd June 2016, 18:14   #14439  |  Link
dirct
Hello Atak_Snajpera, first I would like to forgive me for writing mistakes because they do not speak English (I'm Brazilian) and I'm using an online translator for that, I would say that I am a great admirer of his work and accompany the roughly six years, good will then ask you a layman's question because I do not know if you can:
You can direct more ripbot264 processing to the GPU than the CPU? I ask this question because the GPUs seem to be at higher evolution than the CPUs in a matter of processing, the latest generation of both Nvidia and AMD less lithography 16nm or 14nm had a brutal gain processing performance, you can use this processing in ripbot264 now or in a future release to reduce the load on the CPU? I'm sorry if I'm talking nonsense as I said I am a layman in relation to programming, anyway continue with your great work the ripbot264 is simply wonderful I love the function to use multiple PCs together to encode dividing the work.
dirct is offline   Reply With Quote
Old 25th June 2016, 01:38   #14440  |  Link
chane2k1
Download Poster no longer working
Hello Atak,
It appears as though The Movie Database may have made changes to their API, your Download Poster application is no longer downloading posters. I have tried on three different computers and two different networks, you can query a title and a list of results will return, but when you select one of the items there is just the spinning wheel that appears with the Downloading... text that accompanies it.
