16th April 2009, 14:30 | #4701 | Link | |
I have experienced this on both of my Vista x64 systems and simply can't figure out what is causing it. None of my other encoding programs do this.... |
17th April 2009, 08:44 | #4702 | Link |
Something strange happens with the calculation when adding forced sups, but if the forced sup isn't added last it seems to calculate ok though.
no sups = 4503 kbps 1 sups = 4489 kbps 2 sups = 4479 kbps 3 sups = 4502 kbps (this is a forced sup) loading forced sup first: 4503 / 4503 / 4475 / 4466 Atak: also I see you've been asking around for 720p sups and this has been possible for a few months with BDSup2Sub. I've used it successfully on about 15 movies so far. |
17th April 2009, 11:00 | #4703 | Link |
slow encodes
im using an Intel T7500 laptop running XP 32bit and coreavc pro, which is using the Cuda part of my 8600GT GPU to accelerate decoding of the AVC stream. the trouble is even with all that power if i run say a 15gb mkv through the program to resize it to 7.95gb, it takes forever. im getting maybe 10fps on the first pass and then maybe 3.7fps on the second pass. is this normal?
17th April 2009, 14:28 | #4704 | Link | |||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th April 2009 at 15:28. |
17th April 2009, 16:38 | #4705 | Link |
HDConvertToX author
even jar can be used in command line
java -jar file.jar BUT application need a command line interface BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
18th April 2009, 06:59 | #4707 | Link | |
Subs that only have english subtitles for non-english parts for instance.
It does have a command line interface for example to resize all sups in D:\video to 720p you could use Code:
java -jar bdsup2sub.jar D:\video\*.sup *-720.sup /res 720 |
19th April 2009, 14:54 | #4708 | Link |
So I've finally figured out the odd issues where the encoding never starts, or when ripbot says an encode is completed within a second. For some reason, ripbot is not updating the job1.avs file within temp. When I'm initially on the "New Job" section, no matter what I do when I hit the Done button the job1.avs does not have the #Audiosource or #Audiodub sections populated.
However, if I click on the arrow next the Audio source, select none, then re-select the Audio source, I notice that ffdshow pops up in my tray. Immediately after, the job1.avs file does have the audio sections populated. I can then carry on with making all my audio, subtitle, and video quality settings, then select Done. So far I've been able to encode 2 movies successfully. Does anyone know why job1.avs isn't being populated until I mess with those audio options? |
19th April 2009, 16:04 | #4709 | Link |
Atak, would you consider adding the option of muxing external Vobsubs (*.sub/*.idx) in addition to the other sub formats you already have? Thanks...
Second question: Is there any theoretical difference in encode quality between A.) Auto crop and resize to HD-ready res (720p) by adding borders OR B.) No crop, just resize downward to HD-ready res (720p). |
20th April 2009, 20:51 | #4710 | Link | |
Location: Between a clown and a mime, holding an uzi to each head.
And as I walk through the Valley of the Shadow of Death, Lord, thy balls and shaft, they comfort me, you annoint my head with oil, some salt, a dash of pepper, a sprigg of parsley......Lord?............Lord??? What dost thou intend to do with that fork??? |
20th April 2009, 20:53 | #4711 | Link | |
21st April 2009, 02:26 | #4712 | Link | |
I am building an i7 test box at my work, and I just wish it had a BD drive so I could run my conversions overnight there lol If it's really that fast, I might have to go ahead with mine. I already have the CPU since I got the 920 for $200 from MicroCenter a couple of weeks ago |
21st April 2009, 19:22 | #4713 | Link | |
Mark |
21st April 2009, 22:07 | #4714 | Link |
first i must say great app it worked great for the first movie i did(The new rambo) but now i'm trying to do sin city and it is acting odd. i can select the m2ts file and select the vid and audio streams and it does the demuxing but then it opens up media player classic and says "cannot decod stream"(or something to that effect. i'm not sure if it something i messed up(i don't think it is) but i can't get it to work at all. i have tried re-downloading and extracting ripbot but the same thing happened. i am trying it again now but have moved mpc out of the tools folder just to see what it would do i'm expecting a diff error. any help would be appriciated.
in case it makes a difference i'm using alcohol 120% to mount an image created with my ps3 and have any dvd hd to do the decrypt. Also i was able to play the file that ripbot creates in the temp folder using VLC. and VLC can play the movie right from the bd image. |
21st April 2009, 22:15 | #4715 | Link |
Install Windows Media Player 11. I suspect that you don't have VC-1 decoder installed!
http://www.microsoft.com/windows/win...1/default.aspx
21st April 2009, 22:55 | #4716 | Link |
Hi Atak,
First of all, i've been using your program for aboub past year or so. Great job man! There's nothing else out there like it. I was wondering, is there any plans in the near future to 1. Integrate the ripping and exact stream copying of eac3 or trueHD, and DtsHD stream. ( i plan on converting all my hd-dvds to mkv while keepin the losless stream) 2. Implement the capability of the GPU rendering power. Again thanks for the great software, and i hope you keep on improving it and make it better. Long live RipBot |
21st April 2009, 23:18 | #4717 | Link |
I have this strange case.
I was encoding a TV show DVD, DHW season 4 for my girlfriend for XBMC. Anyway, I locked the size to 350mb (2 pass) to save up space... I was using my own profile, and set the Audio at 2.0 OGG Vorbis which is around at 128 kbps [q 4] and did 6 shows. They all came out to be exactly 340 mb!! What happened to last 10 mb?? My guess is because the resolution is not divisible by 16... I am resizing them at 704x396. Should I post log.txt? |
21st April 2009, 23:20 | #4718 | Link | |
and having moved the wmpc folder out of tools did not result in any error but it still did not allow me to continue with encoding. Last edited by grondinm; 21st April 2009 at 23:26. |
21st April 2009, 23:30 | #4719 | Link | |
LINK |
21st April 2009, 23:42 | #4720 | Link | ||
reboot install latest ffdshow 2895
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st April 2009 at 23:47. |
