Old 13th March 2020, 20:01   #7441  |  Link
Lucius Snow
Hi all,
I'm trying to optimize the encoding speed with my Ryzen 3990X (64 cores - SMT disabled) on Windows 10 64 bit.
When encoding UHD @ 23,76 fps file, i only reach 55-58% of CPU charge.
I tried to add "--numa-pools=64" "settings but there's no change.
I currently use 3.2+38-fdbd4e4 build with VS 2019 / AVX2.
Do you have any idea how to speed up encoding?
Thank you.
Lucius Snow is offline   Reply With Quote
Old 13th March 2020, 20:17   #7442  |  Link
Stereodude
Originally Posted by Lucius Snow View Post
Hi all,
Thank you.
1) That's not the right switch. You'd want: --pools 64, but it x265 should generate 64 threads automatically if there are 64 logical processors showing to the OS.
2) It depends where the bottleneck is. Your source could be unable to feed frames to the encoder fast enough.
3) Split the encode into pieces on a scene change and run them simultaneously.
Old 13th March 2020, 20:35   #7443  |  Link
Hi all,
Thank you.
Disabling smt is ultra stupid idea because you lose a lot of performance! Up to 40%. The only good idea is to split video in chunks and encode then simultanously.
Old 13th March 2020, 20:48   #7444  |  Link
Stereodude
Windows 10 generally doesn't support more than 64 logical cores per NUMA node, so disabling SMT is the best way to get the most performance out of a 3990 under Windows 10 unless he uses Windows 10 Enterprise which can use all 128. Using 64 real cores is better than 64 logical cores across 32 real cores.
Old 13th March 2020, 21:08   #7445  |  Link
Lucius Snow
Exactly StereoDude.
I use Windows 10 LTSC so I have better performances with SMT disabled.
Old 14th March 2020, 00:55   #7446  |  Link
Lucius Snow
Interesting details:
I have a little better performance on Linux (Centos 8.1) but still far from 100% of CPU charge.
However, I made this X265 benchmark test: http://www.xin.at/x265/index-en.php
I reached 00:40:09:644 on Linux and 01:14:24.446 on Windows.
Old 14th March 2020, 03:15   #7447  |  Link
In video encoding 64 logical cpus per CPU group is not a problem. You just have to run additional x265 instances. Problem solved! Disabling smt is a bizarre workaround to low CPU usage by video encoder.
Old 14th March 2020, 09:41   #7448  |  Link
MeteorRain
結城有紀
Up to 40%.
Do you have benchmarks to support that? I thought we'd lose at most 20% performance by not using SMT but that's just my wild guess. Would love to see actual numbers showing the difference.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 14th March 2020, 14:12   #7449  |  Link
Stereodude
What is an exception code of 0xc0000005 in x265?
Faulting application name: x265.exe, version: 3.3.0.1, time stamp: 0x5e4bfd9a
Faulting module name: x265.exe, version: 3.3.0.1, time stamp: 0x5e4bfd9a
Exception code: 0xc0000005
Fault offset: 0x00000000004fb4d2
Faulting process id: 0x23a4
Faulting application start time: 0x01d5f9aa83090eef
Faulting application path: C:\HDTV Tools\x265\x265.exe
Faulting module path: C:\HDTV Tools\x265\x265.exe
Report Id: 921cdb5a-b329-4dac-b876-d60ff8a06c73
I made a few changes to my x265 command line and have gotten the same exception code twice in 10 hours (out of 8 simultaneous encodes on two different encode segments) mid encode after never seeing it ever before of many days of simultaneous encoding on the same system with the same version of x265. Frankly, I've never seen this error before from any version of x265 on any system before with any combination of command line switches.
I changed from this:
START "Enc #6" /NORMAL /NODE 0 /AFFINITY 00000F00 "x265.exe" --pools 4 -F 1 --crf 16.0 -p veryslow --no-sao --aq-mode 1 --aq-strength 1.15 --vbv-maxrate 25000 --vbv-bufsize 25000 --level 5.0 --keyint 120 --open-gop -D 10 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --qpfile 6.chp -o "out_6.265" "in_6.avs"
to this:
START "Enc #6" /NORMAL /NODE 0 /AFFINITY 00000F00 "x265.exe" --pools 4 -F 1 --crf 16.0 -p veryslow --aq-strength 1.15 --vbv-maxrate 25000 --vbv-bufsize 25000 --level 5.0 --keyint 120 --open-gop -D 10 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --qpfile 6.chp -o "out_6.265" "in_6.avs"
The video has the following properties:
AVSMeter 2.9.8 (x64), 2012-2020, (c) Groucho2004
AviSynth+ 3.4 (r2925, master, x86_64) (3.4.0.0)
Number of frames:                30565
Length (hh:mm:ss.ms):     00:21:14.815
Frame width:                      1920
Frame height:                     1080
Framerate:                      23.976 (24000/1001)
Colorspace:                  YUV420P10
I restarted the first of the two segment that crashed and it has made it past the prior crash point.
I'm using HolyWu's build if that matters.
Old 14th March 2020, 14:20   #7450  |  Link
Stereodude
*sigh*
Disabling SMT is how you optimize the performance of an application that will only run on a single NUMA node with a processor like a 3990. The FPS of his single encode with SMT disabled from his single x265 instance is significantly higher than it would be if SMT was enabled. I'd estimate 70-80%.
Is there an alternative workaround for maximizing x265 performance with running multiple simultaneous encodes, yes.
Old 14th March 2020, 18:36   #7451  |  Link
Lucius Snow
I can't split the video source file so I don't think running multiple instances would help :\
Old 14th March 2020, 20:37   #7452  |  Link
Stereodude
What file format is the video source? You don't have to split the source video file. You only have to split the encoding of the source video file.
By the way, you could just encode two different video source files at the same time.
Old 15th March 2020, 08:06   #7453  |  Link
LazyNcoder
Hey guys, any good and free tool to extract hdr10plus meta tags as json and re use it with x265?
I used quietvoid's hdr10plus_parser tool but it gives me error:
Reading parsed dynamic metadata... thread 'main' panicked at 'assertion failed: `(left == right)`
left: `10`,
right: `9`', src/hdr10plus.rs:324:13
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace.
Tried it on several sources. Any other tool around here?
LazyNcoder is offline   Reply With Quote
Old 15th March 2020, 17:30   #7454  |  Link
quietvoid
Make sure to update to 0.2.7. If that doesn't work either, I'll need more info.
quietvoid is online now   Reply With Quote
Old 15th March 2020, 18:15   #7455  |  Link
LazyNcoder
Yes, tried it with 0.2.5 0.2.6 0.2.7 all was the same.
What info do you need? Let me know. I wanted to PM you about it but seems like it's not available.
Old 15th March 2020, 18:34   #7456  |  Link
quietvoid
I just need a sample (or title) of what you're trying to parse, it's hard to test everything. You can open an issue on Github or PM me here.
Old 16th March 2020, 10:42   #7457  |  Link
@Stereodude: I used to believe that the more threads are working on the same video, the smaller the scope of each thread gets, the less efficient the search for redundant areas will be, which will limit quality. Is that no concern for you?
Old 16th March 2020, 13:28   #7458  |  Link
Stereodude
Why do you say that?
I've been using --pools 4 -F 1 for my encodes. Mostly because in prior testing I saw a noticeable quality improvement limiting the simultaneous frames to 1. I limit the pools to 4 mostly because when I set frames to 1 it only uses about 4 threads worth of CPU.
I'm going to retest if -F 1 is still necessary with the latest builds since it seems to have considerably image quality improvements that are leading me to rather different conclusions on my preferred settings vs. the last time I tested over a year ago. I find AQ2 w/ SAO left enabled has a very pleasing look now whereas I previously thought it was terrible. Maybe it's just me...
Old 16th March 2020, 16:29   #7459  |  Link
fauxreaper
With less frame-threads and no-wpp, the encode has better quality and uses less bitrate. In my tests, disabling wpp is more effective to quality and bitrate than decreasing frame-threads.
fauxreaper is offline   Reply With Quote
Old 16th March 2020, 16:40   #7460  |  Link
Stereodude
Where can I get another 64-bit Windows build of 3.3+1-f94b0d32737d? I already have a HolyWu build made with Clang 9.0.0 and want to compare a behavior I see to a different build of the same x265 version.
