Old 16th April 2020, 09:07   #2121  |  Link
VincAlastor
Originally Posted by Beelzebubu View Post
How did you mux the file? The problem suggests that the muxer did not mark the keyframes in the container index.
i muxed with mp4box Feb 2020 and mkvmerge 45.
mkvmerge i tested --cues iframes and --cues all
nothing was working.
VincAlastor is offline   Reply With Quote
Old 16th April 2020, 12:50   #2122  |  Link
Beelzebubu
You need to file a bug report (or feature request) with mp4box to add support for invisible keyfames, which is how AV1 calls non-IDR / open-GOP keyframes.
Beelzebubu is offline   Reply With Quote
Old 16th April 2020, 20:38   #2123  |  Link
benwaggoner
Originally Posted by littleD View Post
i have actualized recently (not remember a day) av1 extension from store and decoding is stilll slow.
They have updated the extension pretty regularly, alas without release notes.
Ben Waggoner
My Compression Book
Old 21st April 2020, 20:14   #2124  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
https://www.blog.google/products/duo...tay-connected/
Pretty cool, Google has announced using AV1 in their Duo voice chat app, targeting 30 Kbps!
Old 21st April 2020, 21:19   #2125  |  Link
soresu
Wow 30 kbps, that is pretty incredible, even old 2-2.5g mobile networks and ancient DSL could field that, which is probably exactly the point.
Sounds like they are also trying to compete with that Zoom app and Skype for group video calls with the current demand for it skyrocketing.
Even with them looking to expand to 12 participant group calls it would only be 330 kbps down and 30 kbps up.
soresu is offline   Reply With Quote
Old 21st April 2020, 21:41   #2126  |  Link
Blue_MiSfit
Yeah I wonder what encoder they're using (presumably libaom), and how it's configured! I imagine they're doing like 15 fps and some very small frame size like 240x430 or 160x284
Old 21st April 2020, 22:33   #2127  |  Link
soresu
Even with a small frame size they may have a dynamic res DNN scaler to sweeten the pot given their AI/ML focus in the last decade.
Old 21st April 2020, 22:55   #2128  |  Link
utack
And yet their blog is using.....gif to showcase the moving components
utack is offline   Reply With Quote
Old 22nd April 2020, 00:28   #2129  |  Link
Blue_MiSfit
That very much makes senes, though I wonder how good these can really be.... LC-EVC seems to be a much better solution than smart upscaling.
Old 22nd April 2020, 03:33   #2130  |  Link
soresu
If it only needs to work for a phone size screen, or at worst a 10 inch tablet then it won't be much of an issue anyways.
Old 22nd April 2020, 19:55   #2131  |  Link
benwaggoner
Video chat content is generally quite simple to encode. No camera motion, faces don't move that fast. So pixels/bit can typically be a lot higher than for TV/film content.
384x288 24 fps at 30 Kbps of video chat is feasible with a good HEVC and persumably AV1 encoder. Not pretty, but with lip sync and some sense of non-verbal communication. Lower frame rate and fps mean a lot of MIPS/pixel so AV1's broader encoding speed challenges shouldn't be a substantial issue.
Ben Waggoner
My Compression Book
Old 30th April 2020, 15:32   #2132  |  Link
marcomsousa
YouTube for Android TV enable AV1 video codec support on capable plaforms
https://www.xda-developers.com/youtu...rtain-devices/
AV1 win64 VS2019 builds
Last build here
marcomsousa is offline   Reply With Quote
Old 30th April 2020, 15:39   #2133  |  Link
hbbs
Just tested on my Nvidia Shield TV.
Only getting VP9. Also, apparently, there is no way to enable AV1 on the app settings.
Sent from my Moto Z3 Play using Tapatalk
hbbs is offline   Reply With Quote
Old 30th April 2020, 15:55   #2134  |  Link
hajj_3
I assume it is just for android tv devices that have an av1 hardware decoder or maybe it is only used for low resolutions if your internet connection is slow.
Old 30th April 2020, 23:30   #2135  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Based on a look through the decompiled source, it does seem to require hardware support, and also requires Android 10. I don't think the Shield has either.
Old 1st May 2020, 00:12   #2136  |  Link
Blue_MiSfit
Shield definitely does not have a hardware AV1 decoder. It's an nVidia Tegra X1 / X1+ SOC.
Old 1st May 2020, 03:32   #2137  |  Link
soresu
I believe this is pre emptive support for the rumoured Android TV powered Chromecast Ultra supposedly coming out later this year - if it uses Amlogic S905x4 as I believe it would, it should do 4K AV1 in hardware.
If that happens I would expect a ramp up in AV1 content on Youtube, Google Play Movies/TV, and Vimeo.
Old 1st May 2020, 05:28   #2138  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I would've loved to have been a fly on the wall on the meetings held over whether the AV1 block would be ready in time to meet the already delayed X1+ tape-out or not. "Just two more weeks, it's almost done!"
Old 1st May 2020, 18:25   #2139  |  Link
Selur
Selur's Avatar
Is there an alternative to https://aomedia.googlesource.com/aom.../noise_model.c to build a film grain table for aomenc?
Preferably something that does only support humongous raw yuv files as input.
Having to:
1. create a raw yuv file from the source and from a denoised version of the source
2. create the film grain table with noise_model
(3. encode using the film grain table)
just seems like too much pain for this to be usable for anything but small samples.
So does anyone know a better tool or a better workflow to create the filmgrain tables? (may be a modified ffmpeg version?)
Cu Selur
Old 1st May 2020, 19:14   #2140  |  Link
marcomsousa
Libaom have a new branch applejack some people are saying that this is for Libaom 2.0? Anyone know anything about this?
Marco Sousa
Last build here
