Old 20th May 2020, 21:50   #1861  |  Link
44vince44
Originally Posted by JKyle View Post
Well, AFAIK, libbrotlidec.dll is a Brotli compression library included in mingw64 / MSYS2. (Here.)
I guess there was something wrong in the course of making ffmpeg static. (Not sure though.)
Indeed, there shouldn't be such depencies !
and you're welcome :-)
44vince44 is offline
Old 20th May 2020, 21:59   #1862  |  Link
44vince44
Then, copying libbrotlidec.dll next to ffmeg.exe generates another error: libbrotlicommon.dll is missing.
Copying that one fixes the problem and i get the following output:
C:\Program Files\StaxRip\Apps\Encoders\ffmpeg>ffmpeg -version
ffmpeg version N-97833-gc94550eb31-gb707abf091+3 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 10.1.0 (Rev2, Built by MSYS2 project)
configuration: --cc='ccache gcc' --cxx='ccache g++' --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-libsvthevc --enable-openal --enable-vapoursynth --enable-opencl --enable-opengl --enable-openssl --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --enable-nonfree
libavutil 56. 46.100 / 56. 46.100
libavcodec 58. 84.100 / 58. 84.100
libavformat 58. 43.100 / 58. 43.100
libavdevice 58. 9.103 / 58. 9.103
libavfilter 7. 81.100 / 7. 81.100
libswscale 5. 6.101 / 5. 6.101
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
Old 21st May 2020, 00:10   #1863  |  Link
Atlantis
AviSynth+ 3.6.0
Atlantis is offline
Old 21st May 2020, 06:39   #1864  |  Link
ACKR
hello i have a problem everything else works fine with vapoursynth but when i give files as file batch it crashes so i have to give every single file one after another. is there any fix for this?
ACKR is offline
Old 21st May 2020, 11:36   #1865  |  Link
stax76
stax76's Avatar
If it's not the last beta then please try the last beta.
stax76 is offline
Old 21st May 2020, 19:41   #1866  |  Link
mcjordan
Stax, do you plan to update the FrameServer generally to AviSynth headers interface V8 ?
There are a huge list of plugins that which are already in line with it or are in the process of the adapting.
Later I will publish what I have followed so far.
mcjordan is offline
Old 21st May 2020, 20:39   #1867  |  Link
stax76
stax76's Avatar
I don't know if I should but can ask an avisynth dev.
Has anybody tried AviSynth+ 3.6.0, QTGMC working?
stax76 is offline
Old 21st May 2020, 20:46   #1868  |  Link
mcjordan
Not yet, but maybe later. I'm terribly tired, I'll continue tomorrow morning. Excuse me, Stax.
mcjordan is offline
Old 21st May 2020, 20:58   #1869  |  Link
stax76
stax76's Avatar
Have a good night.
stax76 is offline
Old 22nd May 2020, 09:18   #1870  |  Link
Patman
Patman's Avatar
Originally Posted by 44vince44; JKyle
FFMPEG issue
I reinstalled msys2 and compiled ffmpeg again. Now it works without problems. Give it a try.
Tools for StaxRip | x264 - x265
Patman is offline
Old 22nd May 2020, 09:37   #1871  |  Link
Patman
Patman's Avatar
Have a look here
Patman is offline
Old 22nd May 2020, 11:04   #1872  |  Link
JKyle
App Digger
JKyle's Avatar
Super! The text input error is also gone.
JKyle is offline
Old 22nd May 2020, 19:26   #1873  |  Link
mcjordan
DirectN library have an update - 1.90
Changelog: Updated with Windows SDK 19041
mcjordan is offline
Old 23rd May 2020, 11:58   #1874  |  Link
colinhunt
A bit of a mystery here, would appreciate any advice on how to solve.
StaxRip 2.1.1.4 on two PCs, both AMD Zen CPUs, both with Nvidia GPUs (1080Ti & 2080 Super). Both running same version of Win10, AviSynth+ and other dependencies as far as I can tell.
When I drop a file in StaxRip and try to set MCTemporalDenoise (Avisynth), the 1080Ti one has no problem, but the 2080 Super one says this:
"Cannot load file 'C:/Users/xxxxxx/Desktop/videotools/Stax2114/Apps/Plugins/AVS/FFT3DGPU/FFT3dGPU.dll' Platform returned code 126: the specified module could not be found.
But the .dll is definitely in that directory. I can't figure out why this is happening or how to fix it.
colinhunt is offline
Old 23rd May 2020, 14:08   #1875  |  Link
mcjordan
NVEncC 5.0.2 is out
https://github.com/rigaya/NVEnc/releases/tag/5.02
mcjordan is offline
Old 23rd May 2020, 15:45   #1876  |  Link
Khun_Doug
One thing that you can check is what MS Visual C libraries are installed on each machine. It is possible that there is a dependency and the machine with the 2080 Super doesn't have something installed that the 1080 machine does.
Khun_Doug is offline
Old 24th May 2020, 02:59   #1877  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Is there no more DGIndexNV Support in the newest BETA?
-QfG- is offline
Old 24th May 2020, 19:49   #1878  |  Link
Atlantis
Has anybody re-encoded iphone videos? I get this error
-------------------------- System Environment --------------------------
StaxRip    : 2.0.8.0
Windows    : Windows 10 Pro 1909
Language   : English (United States)
CPU        : Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
GPU        : NVIDIA GeForce GTX 980 Ti
Resolution : 3840 x 2160
DPI        : 168
------------------------ MediaInfo Source File ------------------------
Z:\Media\Video\Making\QVPI0471.MP4
General
Complete name            : Z:\Media\Video\Making\QVPI0471.MP4
Format                   : MPEG-4
Format profile           : Base Media / Version 2
Codec ID                 : mp42 (isom/mp41/mp42)
File size                : 92.5 MiB
Duration                 : 12 s 672 ms
Overall bit rate         : 61.2 Mb/s
Encoded date             : UTC 2020-05-24 18:09:26
Tagged date              : UTC 2020-05-24 18:09:39
Video
Format                   : HEVC
Format/Info              : High Efficiency Video Coding
Format profile           : Main@L5.1@High
Codec ID                 : hvc1
Codec ID/Info            : High Efficiency Video Coding
Source duration          : 12 s 835 ms
Bit rate                 : 60.6 Mb/s
Width                    : 3 840 pixels
Height                   : 2 160 pixels
Display aspect ratio     : 16:9
Frame rate mode          : Variable
Frame rate               : 60.000 FPS
Minimum frame rate       : 54.545 FPS
Maximum frame rate       : 60.000 FPS
Color space              : YUV
Chroma subsampling       : 4:2:0
Bit depth                : 8 bits
Bits/(Pixel*Frame)       : 0.122
Stream size              : 91.5 MiB (99%)
Source stream size       : 92.4 MiB (100%)
Title                    : Core Media Video
Color range              : Limited
Color primaries          : BT.709
Transfer characteristics : BT.709
Matrix coefficients      : BT.709
Codec configuration box  : hvcC
Audio
Format                   : AAC LC
Format/Info              : Advanced Audio Codec Low Complexity
Codec ID                 : mp4a-40-2
Duration                 : 12 s 671 ms
Source duration          : 12 s 864 ms
Bit rate mode            : Constant
Bit rate                 : 48.0 kb/s
Nominal bit rate         : 64.0 kb/s
Channel(s)               : 1 channel
Channel layout           : C
Sampling rate            : 44.1 kHz
Frame rate               : 43.066 FPS (1024 SPF)
Compression mode         : Lossy
Stream size              : 76.9 KiB (0%)
Source stream size       : 78.2 KiB (0%)
Title                    : Core Media Audio
--------------------------- AviSynth Script ---------------------------
LoadPlugin("Z:\Data\Portable Apps\Video\StaxRip\Apps\Plugins\Dual\L-SMASH-Works\LSMASHSource.dll")
LSMASHVideoSource("Z:\Media\Video\Making\QVPI0471.MP4")
#AssumeFPS(25)
---------------------- Source Script Information ----------------------
Width     : 3840
Height    : 2160
Frames    : 770
Time      : 20:25:05.000
Framerate : 0.0001075 (2/18593)
Format    : YUV420P8
---------------------- Target Script Information ----------------------
Width     : 3840
Height    : 2160
Frames    : 770
Time      : 20:25:05.000
Format    : YUV420P8
- Error Video encoding using x265 3.3+10-g08d895bb6 GCC 10.0.1 Patman -
Video encoding using x265 3.3+10-g08d895bb6 GCC 10.0.1 Patman failed with exit code: 1 (0x1)
It's unclear what the exit code means, in case it's a Windows system error then it possibly means:
Incorrect function
---- Video encoding using x265 3.3+10-g08d895bb6 GCC 10.0.1 Patman ----
"Z:\Data\Portable Apps\Video\StaxRip\Apps\Support\avs2pipemod\avs2pipemod64.exe" -y4mp "Z:\Media\Video\Making\QVPI0471_temp\QVPI0471 new.avs" | "Z:\Data\Portable Apps\Video\StaxRip\Apps\Encoders\x265\x265.exe" --crf 21 --output-depth 10 --colorprim bt709 --colormatrix bt709 --transfer bt709 --range limited --frames 770 --y4m --output "Z:\Media\Video\Making\QVPI0471_temp\QVPI0471 new_out.hevc" -
[sgpd] box has more bytes than expected: 60
[sgpd] box has more bytes than expected: 2
[sgpd] box has more bytes than expected: 4
avs2pipemod[info]: writing 770 frames of 2/18593 fps, 3840x2160,
sar 0:0, YUV-420-planar-8bit progressive video.
x265 [error]: unable to open input file <->
avs2pipemod[info]: finished, wrote 0 frames [0%].
avs2pipemod[info]: total elapsed time is 0.351 sec.
avs2pipemod[error]: only wrote 0 of 770 frames.
Start:    8:41:11 PM
End:      8:41:12 PM
Duration: 00:00:01
Any idea? [sgpd] box has more bytes than expected?
Atlantis is offline
Old 24th May 2020, 19:58   #1879  |  Link
Atlantis
I noticed, it is not indexing the file?
Atlantis is offline
Old 24th May 2020, 20:16   #1880  |  Link
stax76
stax76's Avatar
LSMASHVideoSource only supports .mp4 and it's an index free source filter because the container format allows that.
Width : 3840
Height : 2160
Frames : 770
Time : 20:25:05.000
Format : YUV420P8
stax76 is offline
