15th September 2017, 23:21 | #201 | Link |
Open source means you can use it, as long as you don't charge for borrowed code and you acknowledge the source. Maybe some of the legacy support code can be removed, particularly if it is impinging in any way. The 64 bit avisynth shouldn't have any of the 32 bit compatibility stuff since you can't use those filters. Maybe all the compatibility code that is still valid but not useful for most modern filters can be moved to a plugin, no point limiting Avisynth with unuseful constraints.
16th October 2017, 14:57 | #202 | Link | |
See My Avisynth Stuff |
9th November 2017, 05:54 | #203 | Link |
It seems that maybe the scaling feature doesn't work as intended. I was using mt_lut with range of 256, with bit depth 12, and the result was as if there was no scaling (all black). If I convert back to 8 bit first, run it, and then convert back to 12 bits it works properly.
9th November 2017, 08:47 | #204 | Link | |
15th November 2017, 18:43 | #205 | Link |
so, since the expr is added to avs+, are you going to make mt_lut* use it with some option or it's not possible?
15th November 2017, 20:49 | #206 | Link |
I was just thinking about it while rideing homeward. Sure, it won't be a default behaviour.
It has performance penalty. Scaling inputs to a common range requires a floating multiplication within the expression, right after reading the source pixels, unless the common bitdepth is the same as source clip bitdepth. I suppose - knowing that this behaviour was requested because of the easy conversion of old scripts - that this common bit depth is in 8 bit scale 0-255. So for 16 bit input clips the multiplier is 1/256. For 8 bit input, there is no performance loss in this scenario. A second conversion occurs before storing the result back. Another ambiguity comes on whether the source is a limited range yuv or full scale. Limited range can nicely be scaled by bit shift method, but this method will give wrong results if we use it on a full scale source. Other. In Expr not all operators/functions are implemented, there are masktools-only syntax elements. Do you know scripts that are using these operators? Modulo, sin, cos, all kinds of rounding? |
15th November 2017, 21:39 | #207 | Link |
You can try this first, mt_lut at 16bit still faster than Expr 10% speed.
Function kf_expr_x(clip clip1, string "expr", string "yExpr", string "uExpr", string "vExpr", string "aExpr", int "Y", int "U", int "V", int "A", bool "sse2", bool "avx2", bool "optSSE2", bool "optSingleMode", bool "optAvx2") { sCSP = clip1.kf_GetCSP() IsY8 = sCSP == "Y8" IsRGBA = sCSP == "RGBA" sBit = clip1.BitsPerComponent() use_mt_expr = (sBit == 8) yExpr = Default(yExpr, expr) uExpr = Default(uExpr, yExpr) vExpr = Default(vExpr, yExpr) aExpr = Default(aExpr, yExpr) optSSE2 = Default(optSSE2, sse2) optAvx2 = Default(optAvx2, avx2) Y = Default(Y, 3) U = Default(U, 1) V = Default(V, 1) A = Default(A, 1) yExpr = (Y == 3) ? yExpr : "" uExpr = (U == 3) ? uExpr : "" vExpr = (V == 3) ? vExpr : "" aExpr = (A == 3) ? aExpr : "" out = use_mt_expr ? mt_lut(clip1, expr=expr, yExpr=yExpr, uExpr=uExpr, vExpr=vExpr, aExpr=aExpr, Y=Y, U=U, V=V, A=A, sse2=sse2, avx2=avx2) \ : IsY8 ? Expr(clip1, yExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : !IsRGBA ? Expr(clip1, yExpr, uExpr, vExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : Expr(clip1, yExpr, uExpr, vExpr, aExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) return out } Function kf_expr_xy(clip clip1, clip clip2, string "expr", string "yExpr", string "uExpr", string "vExpr", string "aExpr", int "Y", int "U", int "V", int "A", bool "sse2", bool "avx2", bool "optSSE2", bool "optSingleMode", bool "optAvx2") { sCSP = clip1.kf_GetCSP() IsY8 = sCSP == "Y8" IsRGBA = sCSP == "RGBA" sBit = clip1.BitsPerComponent() use_mt_expr = (sBit == 8) yExpr = Default(yExpr, expr) uExpr = Default(uExpr, yExpr) vExpr = Default(vExpr, yExpr) aExpr = Default(aExpr, yExpr) optSSE2 = Default(optSSE2, sse2) optAvx2 = Default(optAvx2, avx2) Y = Default(Y, 3) U = Default(U, 1) V = Default(V, 1) A = Default(A, 1) yExpr = (Y == 3) ? yExpr : "" uExpr = (U == 3) ? uExpr : "" vExpr = (V == 3) ? vExpr : "" aExpr = (A == 3) ? aExpr : "" out = use_mt_expr ? mt_lutxy(clip1, clip2, expr=expr, yExpr=yExpr, uExpr=uExpr, vExpr=vExpr, aExpr=aExpr, Y=Y, U=U, V=V, A=A, sse2=sse2, avx2=avx2) \ : IsY8 ? Expr(clip1, clip2, yExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : !IsRGBA ? Expr(clip1, clip2, yExpr, uExpr, vExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : Expr(clip1, clip2, yExpr, uExpr, vExpr, aExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) return out } Function kf_expr_xyz(clip clip1, clip clip2, clip clip3, string "expr", string "yExpr", string "uExpr", string "vExpr", string "aExpr", int "Y", int "U", int "V", int "A", bool "sse2", bool "avx2", bool "optSSE2", bool "optSingleMode", bool "optAvx2") { sCSP = clip1.kf_GetCSP() IsY8 = sCSP == "Y8" IsRGBA = sCSP == "RGBA" sBit = clip1.BitsPerComponent() use_mt_expr = (sBit == 8) yExpr = Default(yExpr, expr) uExpr = Default(uExpr, yExpr) vExpr = Default(vExpr, yExpr) aExpr = Default(aExpr, yExpr) optSSE2 = Default(optSSE2, sse2) optAvx2 = Default(optAvx2, avx2) Y = Default(Y, 3) U = Default(U, 1) V = Default(V, 1) A = Default(A, 1) yExpr = (Y == 3) ? yExpr : "" uExpr = (U == 3) ? uExpr : "" vExpr = (V == 3) ? vExpr : "" aExpr = (A == 3) ? aExpr : "" out = use_mt_expr ? mt_lutxyz(clip1, clip2, clip3, expr=expr, yExpr=yExpr, uExpr=uExpr, vExpr=vExpr, aExpr=aExpr, Y=Y, U=U, V=V, A=A, sse2=sse2, avx2=avx2) \ : IsY8 ? Expr(clip1, clip2, clip3, yExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : !IsRGBA ? Expr(clip1, clip2, clip3, yExpr, uExpr, vExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : Expr(clip1, clip2, clip3, yExpr, uExpr, vExpr, aExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) return out } Function kf_expr_xyza(clip clip1, clip clip2, clip clip3, clip clip4, string "expr", string "yExpr", string "uExpr", string "vExpr", string "aExpr", int "Y", int "U", int "V", int "A", bool "sse2", bool "avx2", bool "optSSE2", bool "optSingleMode", bool "optAvx2") { sCSP = clip1.kf_GetCSP() IsY8 = sCSP == "Y8" IsRGBA = sCSP == "RGBA" sBit = clip1.BitsPerComponent() use_mt_expr = (sBit == 8) yExpr = Default(yExpr, expr) uExpr = Default(uExpr, yExpr) vExpr = Default(vExpr, yExpr) aExpr = Default(aExpr, yExpr) optSSE2 = Default(optSSE2, sse2) optAvx2 = Default(optAvx2, avx2) Y = Default(Y, 3) U = Default(U, 1) V = Default(V, 1) A = Default(A, 1) yExpr = (Y == 3) ? yExpr : "" uExpr = (U == 3) ? uExpr : "" vExpr = (V == 3) ? vExpr : "" aExpr = (A == 3) ? aExpr : "" out = use_mt_expr ? mt_lutxyza(clip1, clip2, clip3, clip4, expr=expr, yExpr=yExpr, uExpr=uExpr, vExpr=vExpr, aExpr=aExpr, Y=Y, U=U, V=V, A=A, sse2=sse2, avx2=avx2) \ : IsY8 ? Expr(clip1, clip2, clip3, clip4, yExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : !IsRGBA ? Expr(clip1, clip2, clip3, clip4, yExpr, uExpr, vExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) \ : Expr(clip1, clip2, clip3, clip4, yExpr, uExpr, vExpr, aExpr, optSSE2=optSSE2, optSingleMode=optSingleMode, optAvx2=optAvx2) return out } Function kf_GetCSP(clip c) { try { csp = c.kf_GetCSP_avsPlus() } catch (error_msg) { csp = c.kf_GetCSP_avs() } return csp } Function kf_GetCSP_avs(clip c) { return c.IsPlanar ? c.IsYV12 ? "YV12" : \ c.IsYV16 ? "YV16" : \ c.IsYV24 ? "YV24" : c.kf_GetCSP_Y8_YV411() : \ c.IsYUY2 ? "YUY2" : \ c.IsRGB32 ? "RGB32" : \ c.IsRGB24 ? "RGB24" : "Unknown" Function kf_GetCSP_Y8_YV411(clip c) { try { c.UtoY csp = "YV411" } catch (error_msg) { csp = "Y8" } return csp } } Function kf_GetCSP_avsPlus(clip c) { return c.Is420 ? "YV12" : \ c.IsY ? "Y8" : \ c.Is422 ? "YV16" : \ c.Is444 ? "YV24" : \ c.IsYUVA ? "YUVA" : \ c.IsYV411 ? "YV411" : \ c.IsYUY2 ? "YUY2" : \ c.IsRGB32 ? "RGB32" : \ c.IsRGB24 ? "RGB24" : \ c.IsPlanarRGB ? "RGB" : \ c.IsPlanarRGBA ? "RGBA" : \ c.IsPackedRGB ? "RGBIL" : "Unknown" } |
15th November 2017, 21:54 | #208 | Link | |
so for safe choice, useexpr parameter should be:- useexpr="internal" or "none" (default) so anyone update some function that has mt_lut* can make it faster if it possible by set it to "internal", and the "internal" will be "none" automatically if normal avs or old avs+ is used aside from that now, maybe in future if someone update the clexpr, then it will be another options with "internal" and "none"
15th November 2017, 22:01 | #209 | Link |
didn't try it but what about RAM usage ?
16th November 2017, 09:43 | #211 | Link | |
And I'd like to ask you (or someone) with AVX2, could you please compare the performance of lut/lutxy with Expr on your machines (for a basic expression like "x x +" for lut and "x y -" for lut_xy, and a more complex one?) with optAvx2=False and optAVX2=true. For 8, 10 and 16 bits. (10 bit lut_xy has not that much memory overhead) Thanks. |
16th November 2017, 11:39 | #212 | Link | |
mt_lut 8bit-16bit 10%+ faster with complex Expr. mt_lutxy 8bit faster Expr, other way Expr much faster. I7 3770k 4.2g 16bit Expr Y8: 201fps 49% cpu 42Mib Memory Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) last.Expr("x x +") ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) last.mt_lut("x x +", y=3, u=1, v=1) ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) last.Expr("x 111 + 3 * 100 - 2 / 2 ^ 0.02 * 4 ^ 11 +") ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) last.mt_lut("x 111 + 3 * 100 - 2 / 2 ^ 0.02 * 4 ^ 11 +", y=3, u=1, v=1) ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") Expr(p1, p2, "x y -") ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") mt_lutxy(p1, p2, "x y -", y=3, u=1, v=1) ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) #ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") Expr(p1, p2, "x y -") #ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) #ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") mt_lutxy(p1, p2, "x y -", y=3, u=1, v=1) #ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) #ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") Expr(p1, p2, "x y < x x y - 0.8 * - x x y - 0.9 * - ?") #ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) #ConvertBits(bits=16) p1 = last p2 = p1.Invert("Y") mt_lutxy(p1, p2, "x y < x x y - 0.8 * - x x y - 0.9 * - ?", y=3, u=1, v=1) #ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=10) p1 = last p2 = p1.Invert("Y") Expr(p1, p2, "x y < x x y - 0.8 * - x x y - 0.9 * - ?") #ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12") ConvertToY8() trim(0, 5000) ConvertBits(bits=10) p1 = last p2 = p1.Invert("Y") mt_lutxy(p1, p2, "x y < x x y - 0.8 * - x x y - 0.9 * - ?", y=3, u=1, v=1) #ConvertToStacked().DitherPost(mode=6, ampo=1) Last edited by edcrfv94; 16th November 2017 at 11:48. |
16th November 2017, 13:58 | #213 | Link | |
Can you check again these two numbers? I feel that the difference is too big between them. "x y -" 16bit Expr Y8: 159fps 34% cpu 50Mib Memory 8bit Expr Y8: 708fps 12% cpu 35Mib Memory edit: the difference occured because of the final stacked + dither post conversion This script eliminates the conversion overhead before the lut/expr (and no conversion occurs after, avsmeter can report the real comparison of the methods) Code:
SetMemoryMax(3000) bits=16 # set 8, 10, .. 16 lut=true # true:lut, false:expr clipcount=1 # 1: clip/lut, 2: two clips/lutxy simpleexpr=false # choose simple (true) or a more complex expression format="YUV420P"+String(bits) colorbars(width=1920, height=1080, pixel_type=format) ConvertToY() trim(0, 5000) p1 = last p2 = p1.Invert("Y").trim(0,-1).loop(p1.framecount()) # all cached, no speed penalty expr_1d_simple = "x x +" expr_1d_complex = "x 111 + 3 * 100 - 2 / 2 ^ 0.02 * 4 ^ 11 +" expr_2d_simple = "x y -" expr_2d_complex = "x y < x x y - 0.8 * - x x y - 0.9 * - ?" expr = clipcount==1 ? (simpleexpr ? expr_1d_simple : expr_1d_complex) : (simpleexpr ? expr_2d_simple : expr_2d_complex) if(clipcount==1) { result = lut ? mt_lut(p1, expr, y=3, u=1, v=1) : Expr(p1, expr) } else { result = lut ? mt_lutxy(p1, p2, expr, y=3, u=1, v=1) : Expr(p1, p2, expr) } result Code:
i7-3770 @ 3.40 GHz (No AVX2) results in [fps] reported by AvsMeter Bits: 8 Lut/Expr Simple, 1 Clip 790/700 Complex, 1 Clip 796/306 Simple, 2 Clips 540/684 Complex, 2 Clips 540/219 Bits: 16 Lut/Expr Simple, 1 Clip 655/713 Complex, 1 Clip 664/300 Simple, 2 Clips 41.2/684 # masktools2 16 bit lutxy is not lookup but realtime calc Complex, 2 Clips 6.45/224 # masktools2 16 bit lutxy is not lookup but realtime calc Last edited by pinterf; 16th November 2017 at 16:42. |
16th November 2017, 17:20 | #214 | Link |
the top is Expr, then Expr with optAvx2=False, then mt_lutxy, using this https://ark.intel.com/products/75459...up-to-2_60-GHz
colorbars() converttoyv12 d=last Expr(last,d,"x y -") #Expr(last,d,"x y -",optAvx2=False) #mt_lutxy(last,d,"x y -")
See My Avisynth Stuff Last edited by real.finder; 16th November 2017 at 17:25. |
16th November 2017, 19:43 | #216 | Link |
win7 64 sp1, not my pc btw
See My Avisynth Stuff Last edited by real.finder; 16th November 2017 at 19:46. |
30th November 2017, 09:33 | #217 | Link |
kf_limit_dif8_128_expr_test(src_f, src, thr=1.0, elast=1.0, y=3, u=3, v=3) Code:
kf_limit_dif8_128_expr_test(src_f, src, thr=1.0, elast=1.01, y=3, u=3, v=3) kf_limit_dif8_128_mt_test(src_f, src, thr=1.0, elast=1.01, y=3, u=3, v=3) Maybe "- Expr optimization: eliminate ^1 +0 -0 *1 /1 " cause problems? Code:
SetMemoryMax(3000) colorbars(width=1920, height=1080, pixel_type="yv12").killaudio().assumefps(25, 1) #ConvertToY8() trim(0, 5000) #Limiter() #InvertNeg() #VToY() src = last src_f = src.RemoveGrain(11, 11, 11) kf_limit_dif8_128_expr_test(src_f, src, thr=1.0, elast=1.0, y=3, u=3, v=3) #kf_limit_dif8_128_mt_test(src_f, src, thr=1.0, elast=1.0, y=3, u=3, v=3) #kf_limit_dif8_128_expr_test(src_f, src, thr=1.0, elast=1.01, y=3, u=3, v=3) #kf_limit_dif8_128_mt_test(src_f, src, thr=1.0, elast=1.01, y=3, u=3, v=3) Function kf_limit_dif8_128_expr_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V") { smooth = Default(smooth, True ) thr = Default(thr, 1.0 ) elast = Default(elast, smooth ? 3.0 : 128./thr) darkthr = Default(darkthr,thr ) Y = Default(Y, 3 ) U = Default(U, 3 ) V = Default(V, 3 ) Y = min(Y, 4) U = min(U, 4) V = min(V, 4) Yt = Y == 3 Ut = U == 3 Vt = V == 3 Y31 = Yt ? 3 : 1 U31 = Ut ? 3 : 1 V31 = Vt ? 3 : 1 thr = max(min( thr, 128.0), 0.0) darkthr = max(min(darkthr, 128.0), 0.0) elast = max(elast, 1.0) mode = thr == 0 && darkthr == 0 ? 4 : thr == 128 && darkthr == 128 ? 2 : 3 smooth = elast==1 ? False : smooth diffstr = " x range_half - " elaststr = " "+string(elast)+" " thrstr = diffstr+" 0 > "+string(darkthr)+" scalef "+string(thr)+" scalef ? " alphastr = elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstr+" * / ? " betastr = thrstr+elaststr+" * " sexpr = smooth ? alphastr+diffstr+" * "+betastr+diffstr+" abs - * range_half + " \ : thrstr+diffstr+diffstr" abs / * range_half + " expr = diffstr+" abs "+thrstr+" <= x "+diffstr+" abs "+betastr+" >= range_half "+sexpr+" ? ? " thrstrc = " "+string(thr)+" scalef " alphastrc= elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstrc+" * / ? " betastrc = thrstrc+elaststr+" * " sexprc = smooth ? alphastrc+diffstr+" * "+betastrc+diffstr+" abs - * range_half + " \ : thrstrc+diffstr+diffstr" abs / * range_half + " exprc = diffstr+" abs "+thrstrc+" <= x "+diffstr+" abs "+betastrc+" >= range_half "+sexprc+" ? ? " # diff = filtered - original # alpha = 1 / (thr * (elast - 1)) # beta = elast * thr # When smooth=True : # output = diff <= thr ? filtered : \ # diff >= beta ? original : \ # original + alpha * diff * (beta - abs(diff)) # When smooth=False : # output = diff <= thr ? filtered : \ # diff >= beta ? original : \ # original + thr * (diff / abs(diff)) diff = mt_makediff(filtered, original, y=Y31, u=U31, v=V31) ldiff = expr(diff, expr, exprc, exprc) merged = mt_adddiff(original, ldiff, y=Y31, u=U31, v=V31) merged = Y==2 || U==2 || V==2 || Y==4 || U==4 || V==4 ? mt_lutxyz(filtered, original, merged, Y=Y==3?5:Y, U=U==3?5:U, V=V==3?5:V) : merged return mode == 4 ? original \ : mode == 2 ? filtered \ : merged } Function kf_limit_dif8_128_mt_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V") { smooth = Default(smooth, True ) thr = Default(thr, 1.0 ) elast = Default(elast, smooth ? 3.0 : 128./thr) darkthr = Default(darkthr,thr ) Y = Default(Y, 3 ) U = Default(U, 3 ) V = Default(V, 3 ) Y = min(Y, 4) U = min(U, 4) V = min(V, 4) Yt = Y == 3 Ut = U == 3 Vt = V == 3 Y31 = Yt ? 3 : 1 U31 = Ut ? 3 : 1 V31 = Vt ? 3 : 1 thr = max(min( thr, 128.0), 0.0) darkthr = max(min(darkthr, 128.0), 0.0) elast = max(elast, 1.0) mode = thr == 0 && darkthr == 0 ? 4 : thr == 128 && darkthr == 128 ? 2 : 3 smooth = elast==1 ? False : smooth diffstr = " x range_half - " elaststr = " "+string(elast)+" " thrstr = diffstr+" 0 > "+string(darkthr)+" scalef "+string(thr)+" scalef ? " alphastr = elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstr+" * / ? " betastr = thrstr+elaststr+" * " sexpr = smooth ? alphastr+diffstr+" * "+betastr+diffstr+" abs - * range_half + " \ : thrstr+diffstr+diffstr" abs / * range_half + " expr = diffstr+" abs "+thrstr+" <= x "+diffstr+" abs "+betastr+" >= range_half "+sexpr+" ? ? " thrstrc = " "+string(thr)+" scalef " alphastrc= elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstrc+" * / ? " betastrc = thrstrc+elaststr+" * " sexprc = smooth ? alphastrc+diffstr+" * "+betastrc+diffstr+" abs - * range_half + " \ : thrstrc+diffstr+diffstr" abs / * range_half + " exprc = diffstr+" abs "+thrstrc+" <= x "+diffstr+" abs "+betastrc+" >= range_half "+sexprc+" ? ? " # diff = filtered - original # alpha = 1 / (thr * (elast - 1)) # beta = elast * thr # When smooth=True : # output = diff <= thr ? filtered : \ # diff >= beta ? original : \ # original + alpha * diff * (beta - abs(diff)) # When smooth=False : # output = diff <= thr ? filtered : \ # diff >= beta ? original : \ # original + thr * (diff / abs(diff)) diff = mt_makediff(filtered, original, y=Y31, u=U31, v=V31) ldiff = mt_lut(diff, yexpr=expr, uexpr=exprc, vexpr=exprc, y=Y31, u=U31, v=V31) merged = mt_adddiff(original, ldiff, y=Y31, u=U31, v=V31) merged = Y==2 || U==2 || V==2 || Y==4 || U==4 || V==4 ? mt_lutxyz(filtered, original, merged, Y=Y==3?5:Y, U=U==3?5:U, V=V==3?5:V) : merged return mode == 4 ? original \ : mode == 2 ? filtered \ : merged } |
6th December 2017, 21:47 | #220 | Link |
any news on scaling things for both expr and lut?
