Old 15th April 2020, 15:15   #59121  |  Link
oldpainlesskodi
Yeah, virtually the same mobo, chip and ram config too.
Very strange....
Could somehow enabling "auto lip sync" in my amp helped with this?
Old 15th April 2020, 15:27   #59122  |  Link
Well, after playing around with this in mpv.net, it turned out that the above statement is only true when the default "fbo-format=rgba16hf" is used. In this case the performance of:
- FSRCNNX-8-0-4-1: is between NGU Sharp Low and Med !
- FSRCNNX-16-0-4-1: is slightly slower than NGU Sharp High
But when "fbo-format=rgba32f" is set (similar to madVR's internal 32bit processing), then even the fastest FSRCNNX-8-0-4-1 version becomes slower then NGU Sharp High! (A bit faster than FSRCNNX-16-0-4-1 with "fbo-format=rgba16hf")
Cheers, I'll be interested in the results. Do you have an ETA?
And it would be nice to also include NGU Sharp Low/Med/High.
as far as i know madVR store results in 16 bit and 32 bit but math is 32 bit (FP16 is only something new GPU are good at) and it needs directx 11 or other newer APIs.
with close PSNR and other matrics the psnr is not that important but how the human eye perceives it. so it's as always not surefull to judge quality.
so when testing FSRCNNX in the past it wasn't massive worse or something it was just massively slower.
BTW there is also a tensorflow version this version could be up to 8 times faster. if that'S the case it a good reason to add it to madVR.
there is also a FP16 math version of RAVU which at least according to the creator is barely faster but it was complicated to create.
this sounds something totally worth testing.
Old 15th April 2020, 15:56   #59123  |  Link
QBhd
QB the Slayer
QBhd's Avatar
Very strange....
Maybe... I just did a test with an HDR 4k Remux… I get a frame repeat every 18 minutes when I use Direct Sound.
But when I switch to WASAPI the "clock deviation" in the OSD either reports 0% or is not even reported since it's not measurable. When it reports 0% the repeats go to about 3-4 hours... although most of the time there is no value for clock deviation or drops/repeats.
This is the reason why I stopped chasing the "timing" dragon. Plus getting 23, 24, 25, 29, 30, 50, 59, and 60 timings to all work with custom resolutions is a huge chore. CRU will let you change 23 and 29, but not 24 and 30. The only way I found to set custom resolutions for everything was to delete those "standard" timings in the EDID and then set up all 8 in the AMD custom resolutions. Then madVR can do it's optimize thing, and the time involved with it all is just not worth it anymore...
QB
QBhd is offline   Reply With Quote
Old 15th April 2020, 16:08   #59124  |  Link
oldpainlesskodi
Crazy stuff. Like I said, I use no custom timings for 23p, and with AMD I get no repeat or dropped frames on my set up.
Anyways, when is Madshi back? anyone?...asking for a friend.
Old 15th April 2020, 16:15   #59125  |  Link
mclingo
mine seems to be locked at 20+ mins regardless of what I do with CRU, I think my card is shafted as with indentical settings, when i put my 1080p AMD card back in I was all back to normal, hours, days in between drops.
When you say you are using WASAPI, where are you setting this exactly?
Old 15th April 2020, 16:16   #59126  |  Link
QBhd
QB the Slayer
QBhd's Avatar
@oldpainlesskodi
I just did another test... I get the same results as you now... Your "amp" comment made me realize that you are probably using HDMI audio. So I enabled it on mine (yes I have it disabled) and set my player to use that (god my TV's speakers are terrible compared to my ancient Logitech's, even though they are actually decent TV speakers, LOL)…. anyway, I then got -0.00036% clock deviation and "no frame drops/repeats expected". At least that answers that.
QB
Old 15th April 2020, 16:19   #59127  |  Link
there seems to be some "issues"
could be windows could be audio related
the deviations takes "forever" to claim down.
Old 15th April 2020, 16:21   #59128  |  Link
QBhd
QB the Slayer
QBhd's Avatar
I use PotPlayer, it is in the Audio Settings and is the Audio Renderer
As for your card, it is working just fine. You just need to go through hoops to get custom resolutions to work. Or use HDMI audio.
QB
Old 15th April 2020, 16:31   #59129  |  Link
oldpainlesskodi
@QBhd - cool. well, at least it's starting to narrow the potential problems down.
Old 15th April 2020, 16:41   #59130  |  Link
mclingo
I'm using hdmi audio, I never use onboard sound. Any other ideas, must be something you guys have set that I don't.
Old 15th April 2020, 16:46   #59131  |  Link
oldpainlesskodi
What are your Lav audio settings? That's about the only other thing I can think of.
Old 15th April 2020, 16:49   #59132  |  Link
QBhd
QB the Slayer
QBhd's Avatar
I know what his problem is... he just isn't doing what I say to fix it. I have the exact same problem.
Remove all custom resolutions
Reset CRU
Reboot
Open CRU and remove standard timings
Reboot
Open madVR and delete any greyed out "identifications" (this might not be needed, but it doesn't hurt)
create new custom resolutions in AMD you can use these as a starting point AMD Custom Resolutions
Reboot (just to be sure)
Play video and optimize as needed in madVR
QB
Old 15th April 2020, 16:49   #59133  |  Link
mclingo
D3d11 native everything else default, bitsreaning ticked but rest default for audio
Old 15th April 2020, 16:59   #59134  |  Link
mclingo
https://1drv.ms/u/s!AgvFafeelEBikMxJ...Rz_1g?e=sWN5nL
this is the bit I dont understand about mine, look at my current settings here, it clearly states I should be getting a frame drop every 1.4 hours which I could probably live with but i'm still getting20 + mins, its like MADVR is ignoring my current settings and is continuing to just use the measure timings.
In fact it doesnt matter what I chose from there and reboot it makes no difference to the times shown in screen:
https://1drv.ms/u/s!AgvFafeelEBikMxK...8pFyA?e=zsXZdd
if we could explain this we could probably get to the bottom of it.
Old 15th April 2020, 17:03   #59135  |  Link
Klaus1189
How is your HTPC connected to the TV and soundsystem?
This does in fact matter a lot.
Old 15th April 2020, 17:11   #59136  |  Link
mclingo
pretty standard, HDMI ARC, HDMI out of PC to ARC input on reciever, ARC out to HDMI ARC input on TV - I've also tried other cables and another TV, same issue. Nothing has changed in that respect though, its only PC hardware thats changed, if I take my RX 5700 out and put in an old 1080p AMD card all is back to normal, I guess it has to be this RX5700 but OPL is having no issues and i'm confident when I first got the card I didnt have this issue so I cant work out has changed.
I know things can make a difference but we need to explain why I cant move mine off 20 mins regardless of what I do in CRU, are there some details instuctions for using CRU to ensure i'm not missing anything, I've read a couple and it seemed very strasight forward so I dont see how I could.
Old 15th April 2020, 17:22   #59137  |  Link
Klaus1189
Just for testing: Connect the RX 5700 with HDMI direct with the TV and use internal speaker of the TV.
Remember to disable bitstreaming for the test
I don't understand the ARC of your chain. ARC input of AVR is the output to the TV of the AVR, the sound is returning from TV.
For my RX 5700 XT I don't need any custom resolution -> 11,8 hours are good enough for me with WASAPI MPC Audio Renderer of MPC-BE
Old 15th April 2020, 17:22   #59138  |  Link
ARC ? why would you use ARC here.
you have PC -> AVR -> TV why would there be an ARC involved.
Old 15th April 2020, 17:31   #59139  |  Link
mclingo
thats just the port i'm using, I've always used that one, it makes no difference really, i've tried going straight to my PC and bypassed the AVR on another HDMI port, made no difference.
Old 15th April 2020, 17:33   #59140  |  Link
mclingo
what is the most recent NVIDIA GTX 1050 driver with fully working HDR/CRU and 3D?, I might as well drop my 1050 in to see what that does.
