Old 27th November 2012, 16:25   #20441  |  Link
filler56789
SuperVirus
filler56789's Avatar
Correct. However no one needs ACM for playing MP2 or ATRAC3 stored in AVI, right?
Besides, when I said "RealAudio ATRAC3", I didn't mean that low-quality ACM encoder, which cannot go above 132kbps, I was talking about RealProducer 8, which can use up to 352kbps. And even though the encoder doesn't support other sampling frequencies than 44.1kHz, one may apply a couple of workarounds in order to get proper playback @48kHz.
Now, going back to the topic, ...
filler56789 is offline
Old 29th November 2012, 05:01   #20442  |  Link
dansrfe
Bug report:
When entering: 03:08:43.176 into the "Go To..." window it goes to: 00:08:47.159 instead. Also when dragging window to different screen the subtitles become stretched until I resize a little bit to fix the aspect ratio of the subtitles.
dansrfe is offline
Old 29th November 2012, 19:27   #20443  |  Link
Lebowsky
Bug report:
in the last official build, when a video is deoced using DXVA and the Overlay Mixer (I'm on XP), the little [DXVA] text does not appear in the status bar, although DXVA is used (confirmed by looking under Play->Filters->MPC Video Decoder). It appears in the status bar when using a VMR renderer.
Lebowsky is offline
Old 30th November 2012, 07:20   #20444  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
S.Chinese update
http://www.mediafire.com/?c0cwd1u8xlh77aa
betaking is offline
Old 1st December 2012, 08:12   #20445  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Originally Posted by betaking View Post
Thanks. Landed at 2fcb2bbac7
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline
Old 1st December 2012, 12:05   #20446  |  Link
v0lt
Audio switch has a serious bug. It loses part of the data, if data is large. It crash on large data if processing is enabled.
v0lt is offline
Old 1st December 2012, 12:57   #20447  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Fix this
Aleksoid1978 is offline
Old 1st December 2012, 13:47   #20448  |  Link
betaking
betaking's Avatar
S.Chinese update
http://www.mediafire.com/?l39f79wuy625xmv
betaking is offline
Old 1st December 2012, 15:28   #20449  |  Link
v0lt
@Aleksoid1978
Fixed in 6272. Look here.
v0lt is offline
Old 2nd December 2012, 07:24   #20450  |  Link
betaking
betaking's Avatar
a2998fe81e Updated Traditional Chinese translation.
Should be Updated Simplified Chinese translation.
betaking is offline
Old 2nd December 2012, 13:00   #20451  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Yeah, silly mistake at commit log only :P
Sorry about that.
vBm is offline
Old 2nd December 2012, 19:28   #20452  |  Link
Reino
Reino's Avatar
Is there any way to lock the position (aspect ratio) of PGS subtitles in MPC-HC?
The subtitle's position while playing a 1280x720 video at 100% is perfectly fine, but the moment you go full-screen, the subtitle layer gets stretched over the entire desktop. And in my case the stretching is especially noticeable, because I'm using a 4:3 monitor.
My hobby website
Reino is offline
Old 3rd December 2012, 21:26   #20453  |  Link
Joniii
Is there anything that can be done about the REW/FWD? On fastest (4x) it's really slow, or is there some limitation on why it is left like that?
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline
Old 3rd December 2012, 21:45   #20454  |  Link
dansrfe
Is there a way to override PGS subtitle positioning? The subs go over the video portion when the aspect of the file is 2:35:1 and I would like it to go on top of the black bars or if the file has been cropped and encoded then it should position relative to the frame and be positioned inside the black bars when the video goes fullscreen.
dansrfe is offline
Old 3rd December 2012, 23:45   #20455  |  Link
Joniii
Wouldn't this be possible to do and quite easy to code.
Option to automatically change display refresh rate to match content when MPC-HC goes full screen, and back to normal when it exits full screen?
Atleast it's easy to write an app to check current refresh rate, supported refresh rates and make it switch when you want but is there some limitation why this is not on MPC-HC yet? I think it would be an awesome feature to watch Blu-rays at 24p.
Yamaha RX-V685
Joniii is offline
Old 4th December 2012, 09:19   #20456  |  Link
Joniii
Is MPC-HC still actively developed or just bugfixes?
Yamaha RX-V685
Joniii is offline
Old 4th December 2012, 11:13   #20457  |  Link
Still actively developed but it is mostly bug fixes and minor changes at the moment.
ryrynz is offline
Old 4th December 2012, 11:30   #20458  |  Link
judelaw
judelaw is offline
Old 4th December 2012, 14:11   #20459  |  Link
Joniii
Originally Posted by judelaw View Post
Wow, I've been using MPC for years and never noticed that before. Thanks for the info.
Btw, it has the same problem as madVR. If I have another application on background (WMC) that goes automatically full screen when mpc exits from full screen @24p, the display refresh rate is not restored. As if mpc and madvr would still think that mpc is fullscreen and running.
Yamaha RX-V685
Joniii is offline
Old 4th December 2012, 19:48   #20460  |  Link
Skibicki
Skibicki's Avatar
updates in Catalyst 12.11 beta 11
http://support.amd.com/us/kbarticles...etadriver.aspx
-Resolves no video issue found in Media Player Classic Home Cinema when using full or half floating point processing
-Resolve missing fonts issue in XBMC
-Resolves a sporadic system hang encountered with a single AMD Radeon HD 7000 Series GPU seen on X58 and X79 chipsets.
Win 8.1 -- Core 2 Duo E7300 & Intel Q43 GMA 4500
Skibicki is offline
dxva, h264, home cinema, media player classic, mpc-hc
