Old 7th December 2013, 17:19   #81  |  Link
martin53
Originally Posted by Gavino View Post
Variables don't have types, only values do.
You are absolutely right. I meant it that way but I did not use the right words. I wanted to say 'after assigning a literal numeric expression without decimal point to a variable, I can use the variable where an integer is required' (the variable can hold different types later or before).
martin53 is offline   Reply With Quote
Old 7th December 2013, 17:32   #82  |  Link
Gavino
Avisynth language lover
The reason I mentioned it is this line in your code:
     iMinLuma = max( RT_VarExist("fgY_yMax") ? fGY_yMax : 18, iMinLuma)
If fgY_yMax holds a float value, then iMinLuma will be assigned a float, and can't be used as an index in RT_ArraySet(). Is that possibly the source of the error?
GScript and GRunT - complex Avisynth scripting made easier
Gavino is offline   Reply With Quote
Old 7th December 2013, 22:22   #83  |  Link
martin53
That line was one suspect for me, too. The name of the variable suggests it. But it comes from RT_YStats(), which allows a prefix to write several statistics variables in one pass; and the suffix yMax is for YPlaneMax() - nothing with a fractional part.
Old 8th December 2013, 04:23   #84  |  Link
StainlessS
StainlessS's Avatar
I've just taken a look at source and think not possible that RT_YStats returns anything other than Int for yMax, flags really should be checked for valid return results, I dont like the checking for VarExist instead. Perhaps fGY_yMax is assigned float elsewhere in script.
EDIT: Suggest removal of 'round()' temp fixes, as they will hide cause of error, better to find than hide.
Also suggest m53 uses same version AWB as users to avoid confusion with line numbers.
I sometimes post sober.
Old 8th December 2013, 12:36   #85  |  Link
martin53
I share the opinion about round().
Also agree to change to flags check. Please review if this is OK, 'cause I currently have little time to test the script, can only edit and believe.
flags = RT_YStats(cU,   mask=cGamutMask, delta=delta, threshold=MINMAX_THRESH, flgs=$17, prefix="fGU_", MaskMin=18, MaskMax=255)
iMinLuma = max( BitAnd(flags, 2)>0 ? fGY_yMax : 18, iMinLuma)
Was my fault to use my proceeding script instead of published version for checks. I promise amendment
Old 8th December 2013, 13:21   #86  |  Link
StainlessS
StainlessS's Avatar
Should be BitAnd(flags, 1)>0 or RT_BitTST(flags,1) (returns bool)
EDIT: ABOVE is RUBBISH, you were correct with
BitAnd(flags, 2)>0 (or RT_BitTST(flags,1) OK)
I must have a brain tumor (or a hangover)
  Flgs_Bit_Number   Add_To_Flgs     Equivalent_Function             Local_Var_Set_Excluding_Prefix
     0                 1($01)        RT_YPlaneMin()                     "yMin"        (0->255)
     1                 2($02)        RT_YPlaneMax()                     "yMax"        (0->255)
     2                 4($04)        RT_YPlaneMinMaxDifference()        "yMinMaxDiff" (0->255)
     3                 8($08)        RT_YPlaneMedian()                  "yMed"        (0->255)
     4                16($10)        RT_AverageLuma()                   "yAve"        (0.0->255.0)
     5                32($20)        RT_YPlaneStdev()                   "yStdev"      (0.0->255.0)
     6                64($40)        RT_YInRange()                      "yInRng"      (0.0->1.0)
     7               128($80)        RT_YPNorm()                        "yPNorm"      (0.0->??? depends upon d and u)
Flags arg $17 is yMin, yMax, yMinMaxDiff, yAve. yMax is bit 1.
maybe easier:
iMinLuma = max( flags !=0 ? fGY_yMax : 18, iMinLuma)
so long as the flags arg bit is set for returning fGY_yMax, the version you gave is more rigidly correct, but compare non zero can be
same for whatever (valid) var you are interested in.
Assuming all flags arg bits valid, and pixels found in mask within maskmin, maskmax, then will return same as flags arg.
Old 8th December 2013, 14:19   #87  |  Link
martin53
If the symbol fGY_yMax does not exist in AviSynth's variables stomach - is the code safe then?
You know, I'm talking about the classical problem
if(var_does_not_exist || var>0) {
which is only safe because there's the agreement that the evaluation is immediately stopped after the result is final (which is true for one true term in an or clause).
In some languages, one must code
if (var_does_not_exist)
else
  if (var>0)
  endif
endif
Old 8th December 2013, 14:52   #88  |  Link
StainlessS
StainlessS's Avatar
If flags arg had bit 1 set and returned flags is non zero then the yMax variable (with whatever correct prefix) has been set and DOES exist.
However if returned flags is zero then you cannot assume anything about the ymax variable (it may or may not exist, it was not created nor changed).
Presume you mean this
Yes, above is safe.
Ternary/Conditional Operator, [ (condition) ? result1 : result2 ] evaluates one or other result, not both.
You did at one point ask if anyone objected to "%%%" sequence, I meant to answer but forgot. "%%" is used as escaped "%"
in RT_DebugF() and RT_String() to embed a percent symbol into string without being interpreted as a variable insertion point.
Using "%%%" might at some point in future be a problem (although perhaps unlikely). Suggest maybe change to eg "@@@"
or similar (not backslash '\\\').
EDIT:
this
if(var_does_not_exist || var>0) {  ... }
about same as this
if(flags==0 || var>0) {  ... } # failed
although it dont seem to make sense that non existent var judged same as var>0.
this makes more sense
if(flags==0 || var<=0) {  ... } # failed
2nd part only evaluated if first part false.
or
if(flags!=0 && var>0) {  ... } # passed, var exists and is greater than zero
2nd part only evaluated if first part true.
EDIT: You use eg this
dPurple = Round(Default(dPurple, 3)) #where dPurple is function arg type Int
It is not necessary to use Round() on Int function args, they are guaranteed to be type Int (or perhaps Undefined if optional).
It would only be necessary if you coded something like this
dPurple = Round(Default(dPurple, 3.0))
eg
amount = Float(Default(amount, 1.0)) #where amount is function arg type Float
is a good idea to avoid Integer math as client supplied Int arg would be accepted as valid Float (but actually be type Int),
[as Gavino said, IsFloat() really means IsNumeric()].
In an earlier post you put results of IsInt() and IsFloat() on frame, you would want to check IsInt() first and only after failure
test for IsFloat().
An Int is a Float, but a Float is NOT an Int (or rather, an Int is accepted as a Float).
Old 5th January 2014, 01:21   #89  |  Link
alexx7777
AWB будет работать с setmtmode (x) - . То, что x-это лучше?
Setmtmode(5)
DirectShowSource("video")
Setmtmode(x)
SeparateFields()
AWB()
Weave()
alexx7777 is offline   Reply With Quote
Old 9th March 2014, 12:29   #90  |  Link
Bernardd
Hello,
I try AWB function, but il get error "invalide arguments to function MT_expand"
I have load this plugins
mt_masktools-26.dll
CallCmd.dll
dither-1.25.1\win32\dither.dll
GRunT101\GRunT.dll
GScript_11\GScript.dll
RT_Stats_25&26_dll_v1.30_20131219\Avisynth26\RT_Stats26.dll
and import this scrip
dither-1.25.1\dither.avsi
I tried this poor script
LoadPlugin("C:\masktools-v2.0a48\mt_masktools-26.dll")
AVISource("C:\my video.avi")
mt_expand(chroma="process")
The MT_expand's arguments are good
I do not find where is the problem in AWB script script version 1st December. Thanks for help.
Bernardd is offline   Reply With Quote
Old 12th March 2014, 18:22   #91  |  Link
yup
Hi Bernardd!
Avisynth version?
mt_maaktools-26 version?
Date dll.
Some time ago I am using AWB and all was O'k.
yup.
yup is offline   Reply With Quote
Old 15th March 2014, 01:01   #92  |  Link
Bernardd
Thanks yup,
but i think is not problem with avisynth and plugin version. The AWB script line is mt_expand(chroma="process"). This call is ok with my poor script and not inside AWB script. Why ?
Bernard
Old 15th March 2014, 06:04   #93  |  Link
yup
Hi Bernardd!
I also have problem with AWB script, but last version work for me.
You can also can try
http://forum.doom9.org/showthread.ph...98#post1622598
It is work better than built-in ColorYUV.
yup.
Old 23rd March 2014, 18:23   #94  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, get a error:
I use this script:
A=Import("E:\Dragon Ball\DB_1\001\1. Deinterlacing.avs").\
subtitle(string("Original")).Crop(0,0,-360,0)
B=Import("E:\Dragon Ball\DB_1\001\1. Deinterlacing with AutoWhite.avs").\
subtitle(string("Modificado"),align=9).Crop(362,0,0,0).AddBorders(2, 0, 0, 0,$00FFFF00)
Stackhorizontal(A,B)
1. Deinterlacing.avs is:
DGDecode_mpeg2source("E:\Dragon Ball\DB_1\001\VideoFile.d2v", info=3)
ColorMatrix(hints=true, threads=0,interlaced=true)
assumebff()
tfm(order=0,pp=6,mode=4).tdecimate(mode=1)
1. Deinterlacing with AutoWhite.avs is:
assumebff()
AWB(amount=1.0,dither=true,ThSc=20,show=1).tweak(bright=0,cont=1.1)
This error merge when I set show=1.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 25th March 2014, 23:49   #95  |  Link
martin53
Thanks to other members who help - I am on a far east trip with no spare time. Will try to help after return.
Old 26th March 2014, 22:45   #96  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
cPre can be replaced by cRGB in the avsi.
Old 1st December 2014, 04:48   #97  |  Link
goorawin
Unsupported colorspace
I have been trying to load AWB into avisynth 2.6 without success.
I'm think everything has been loaded as it should be.
The error that occurs is: MT Expand : Unsupported colorspace, masktools only supports planar YUV colospaces. Regardless of the conversions I apply (YV12,YV16,YV24 or any other) the same error occurs.
Anyone have a solution?
I have installed the latest masktools v2.0a48
goorawin is offline   Reply With Quote
Old 1st December 2014, 14:29   #98  |  Link
Reel.Deel
The reason you get that error is that either you installed mt_masktools-25.dll which is for AviSynth 2.5 (should work with YV12), that's not the case so more than likely you installed mt_masktools-26.dll which is no longer compatible with the latest AviSynth 2.6 Alpha 4/5.
So what should I do? Download and install MaskTools v2.0b1, make sure to download masktools2-x86.zip.
Reel.Deel is offline   Reply With Quote
Old 1st December 2014, 21:57   #99  |  Link
goorawin
Awb
Thanks for that information. The new masktools version solved the error.
awb, color, colorbalance
