13th June 2020, 05:48 | #7461 | Link | |
Use installer.
13th June 2020, 06:25 | #7462 | Link |
Thank you for the link. I installed it, but unfortunately it didn't work, even after I rebooted the PC. I still get a copy of the Options window when I click on the Modify associations button and therefore I cannot change the .avi option.
Please note that I also tried resetting the options on the installation dialog. |
13th June 2020, 06:52 | #7463 | Link | |
13th June 2020, 06:53 | #7464 | Link | |
Win8.1x64, GTX 950, MPC VR 0.4.6.1337, MPC-BE 1.5.5.5330.
13th June 2020, 06:56 | #7465 | Link | |
EDIT: I notice that right clicking a .avi file doesn't open it if the file association is for MPC-BE, but as I wrote before it does open with the Open With context menu. EDIT 2: I don't know if it helps, but the same problem exists with .mkv files. Also the Options dialog has a number of file associations ticked in grey and others in black (that's the dialog that opens after I click on the Modify button. Last edited by Zinglar; 13th June 2020 at 07:49. |
13th June 2020, 07:26 | #7466 | Link | |
Another difference is I was using Intel's integrated video card for playing back. |
13th June 2020, 10:00 | #7468 | Link |
Not currently planned.
13th June 2020, 10:02 | #7469 | Link | |
I have never encountered such problems. Also - in explorer in context menu, open with - select mpc-be and all
13th June 2020, 10:14 | #7470 | Link |
Hmm... I tried everything you suggest, but with no luck. The odd thing is that the file icon changes to that of MPC-BE, but the file doesn't play with the Open command. Only with Open With.
Additionally, VLC does work as would be expected even though I use a standard user account. MPC-BE works as expected only if I use an administrator account! |
13th June 2020, 11:11 | #7471 | Link | |
13th June 2020, 18:54 | #7476 | Link | |
16th June 2020, 05:34 | #7479 | Link |
MPC Script Source 0.1.0.76
DirectShow source filter for AviSynth and VapourSynth scripts. |
18th June 2020, 18:30 | #7480 | Link |
I have encountered a strange sync issue. I use latest compiled 1.5.5.5337 nightly build and latest MPC VR nightly build and encountered an audio offset, but only when using MPC Audio Renderer. If I choose Directsound and watch the same video it is fine. Using madvr in MPC-BE does not change anything.
Also in Firefox on youtube it is in sync, I think it also uses directsound. I downoaded this video https://www.youtube.com/watch?v=JNH__YaZC0U -> Especially at the end you can clearly see the sync issue watching the bow and hearing the differing audio. Setting it up to about -120 ms solves it also, but is only a workaround. EDIT: just upgraded to 5339, same. Last edited by Klaus1189; 18th June 2020 at 19:52. |
