5th October 2009, 03:32 | #5461 | Link |
in my experience, ive rebuild alot of movies that had audio sync issues, i found out that it was the rip, when i looked at the properties of all the movies i did with audi sync issues they were ripped on the same day and i remember ripping with my laptop onto an external hdd with external BD burner, then i just re ripped it with the burner in my pc connected via sata and the rebuild came out fine. Off topic question: jdobbs, are you able to rebuild every BD movie with your PC?
5th October 2009, 03:42 | #5462 | Link | |
i have tryed re ripping and had no luck. it still came out the same. |
5th October 2009, 07:04 | #5463 | Link |
Resume in the second pass is stopped
For the first time this has happened to me, resumming in the second pass is stopped.That does not happen without resuming.
This is the result 07:49:35] BD Rebuilder v0.30.02 (beta) - Source: THE.WARRIORS - Input BD size: 20,92 GB - Approximate total content: [02:42:08.351] - Target BD size: 7,96 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [07:49:36] PHASE ONE, Encoding - [07:49:36] Reencoding: VID_00003 (13 of 13) - [07:49:36] Collecting video information - Video: 1920x1080, 23,976fps, 135.216 frames - Bitrate: 8.589 Kbs - [07:49:36] Reencoding: VID_00003, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [07:49:39] - Failed video encode, aborted this is the ini [Options] RESIZE=0 MODE=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=8152 TARGET_SIZE=8152 ONEPASS_ENCODING=0 ENCODE_QUALITY=2 VERBOSE_STATUS=1 |
5th October 2009, 11:12 | #5464 | Link | |
BD-RB did for some reason include the studio intro logo as video BUT did not add the soundstream of that logo. Instead the audio from the main title started with the intro and so the entire film was completely out of sync. |
5th October 2009, 15:08 | #5465 | Link | |
Quite strange, first time it's ever happened. Not at home so can't post log or last cmd. cwh |
5th October 2009, 16:13 | #5466 | Link | |
5th October 2009, 16:30 | #5467 | Link | |
I do not have any extra settings, just using whatever BDRB comes with when loading up. Only thing I do is select the output BD25 a working directory and let it go. cwh |
5th October 2009, 16:58 | #5468 | Link |
If you experience an undersize -- please send or post in a zip:
1. The .INF and .INI file. 2. The log file (complete). 3. The .stats file of the main movie. 4. Any special settings of "unusual" processing. Otherwise I can't help, and it's a waste of a post to report it. Thanks. Hundreds of encodes... and not a single undersize from my end... what are you doing differently? Last edited by jdobbs; 5th October 2009 at 20:45. |
5th October 2009, 17:14 | #5469 | Link | |
5th October 2009, 17:26 | #5470 | Link | |
I am out of town right now, if someone hasn't posted this information before my return later this week, I will send something. I too have done, many, maybe not hundreds, and this is the first time I have ever experiened a problem. I don't have anything special added into the .INF file, just installed 03002 and tried Fast Furious, set the output to 25g. By the way, BDRBv is a great little program. I've used DVDRebuilder for years. One of the best software programs I've ever purchased. cwh |
5th October 2009, 22:26 | #5471 | Link | |
6th October 2009, 00:33 | #5472 | Link |
Possible sync error in X-files 2
Using BD-RB v0.30.02 and trying to do The X-Files I Want to believe region B (Full Movie), but got the following error:
OS: Windows Vista 64 bit FFDSHOW rev. 2661 (7 feb. 2009) Haali: 1.9.42.1 Code:
[01:12:15] BD Rebuilder v0.30.02 (beta) - Source: THE.X-FILES.I.WANT.TO.BELIEVE.GER.DC.BLU-RAY.1080P.AVC.DTS-HD.5.1 - Input BD size: 42,52 GB - Approximate total content: [04:30:26.751] - Target BD size: 22,46 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [01:12:16] PHASE ONE, Encoding - [01:12:16] Extracting A/V streams [VID_00001] - [01:13:03] Reencoding: VID_00001 (1 of 35) - [01:13:03] Reencoding secondary video [TRK_02] - [01:20:39] Extracting A/V streams [VID_00002] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\THE.X-FILES.I.WANT.TO.BELIEVE.GER.DC.BLU-RAY.1080P.AVC.DTS-HD.5.1\BDMV\STREAM\00002.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\THE.X-FILES.I.WANT.TO.BELIEVE.GER.DC.BLU-RAY.1080P.AVC.DTS-HD.5.1\BDMV\STREAM\00002.m2ts [01:20:50] - Failed to retrieve audio, aborted Code:
[Status] LABEL=THE.X-FILES.I.WANT.TO.BELIEVE.GER.DC.BLU-RAY.1080P.AVC.DTS-HD.5.1 VERSION=v0.30.02 (beta) SOURCE_SIZE=45654543097 SOURCE_VIDEO_SIZE=39120009216 TARGET_SIZE=24117248000 REDUCTION=.449455776503465 RESIZE_1080=0 AUDIO_TO_KEEP=dan;eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 [00001] AUDIO=1001110 PGS=11111111111111111 M2TS_TARGET=267118428 RATE=4811 NSIZE=256536576 FLINK=-1 MLINK=0 [00002] AUDIO=0000000 PGS=
Good Luck JJ |
6th October 2009, 00:49 | #5473 | Link |
Can someone please tell me how seamless branching disks (like WALL-E) are done correctly with BD Rebuilder?
When choosing "Movie-Only" mode BD Rebuilder shows lots of different videostreams which can not be unchecked or deleted before starting the process. Even after choosing another main title in the Alternate Playlist menu the other videostreams are still present and cannot be deleted.. Is this some kind of playlist parsing bug? |
6th October 2009, 00:54 | #5474 | Link | |
6th October 2009, 02:24 | #5476 | Link |
Problem with WALL-E
I've successfully ripped (movie only) quite a few of my blu-rays. So far, the only one that has prevented me from being able to rip it has been WALL-E.
[21:19:18] BD Rebuilder v0.30.02 (beta) - Source: WALL-E - Input BD size: 22.84 GB - Approximate total content: [01:38:11.927] - Target BD size: 7.72 GB - Windows Version: 6.0 [6002] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [21:19:18] PHASE ONE, Encoding - [21:19:18] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - Can't create output file D:\00000+00024+00001+00025+00002+00026+00003+00027+00004+00028+00005+00029+00006+00093+ 00007+00031+00008+00032+00009+00033+00010+00034+00011+00035+00012+00036+00013+00037+00014+00038+00015+00039+ 00016+00040+00017+00041+00018+00042+00019+00043+00020+00044+00021+00097+00022+00094.track_4352.dts [21:19:19] - Failed to retrieve audio, aborted That path name for that output file is just way too long. I've done quite a few searches, and while I've found maybe 2 or 3 posts with similar issues... I haven't seen a workaround yet. Is there anything I can do to get around this? It looks to me like that is a temporary file so the actual file name probably doesn't matter. Last edited by Wolffe; 6th October 2009 at 02:25. Reason: Inserted <BR> into long path name to prevent scrolling. |
6th October 2009, 02:47 | #5477 | Link |
A movie only copy of WALL-E should be a piece of cake... I've copied this movie as movie only, countless times with various versions of BD Rebuilder. Try it with Strict AVCHD checked, AC3 audio at default, and uncheck the subtitles... unless you need them. My copy is from a Region 1 disc.
This movie was problematic for the first few versions, but it wan't too far into the process before it started copying. |
6th October 2009, 09:57 | #5478 | Link |
OK, thanks for your answers.
I've tried starting the job with the correct playlist (00081 I hope) and *lots* of videofiles in the stream window. But now I have exactly the same problem like Wolffe two postings up: [10:52:51] BD Rebuilder v0.30.02 (beta) - Source: MOVIE - Input BD size: 24.16 GB - Approximate total content: [01:38:11.927] - Target BD size: 8.11 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [10:52:52] PHASE ONE, Encoding - [10:52:52] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - Can't create output file D:\WORKFILES\00000+00024+00001+00025+00002+00026+00003+00027+00004+00028+00005+00029+00006+ 00030+00007+00031+00008+00032+00009+00033+00010+00034+00011+00035+00012+00036+00013+00037+00014+00038+00015+00039+ 00016+00040+00017+00041+00018+00042+00019+00043+00020+00044+00021+00045+50202+00023.track_4352.dts [10:52:53] - Failed to retrieve audio, aborted Last edited by samtroy; 6th October 2009 at 10:01. |
6th October 2009, 13:58 | #5479 | Link | |
6th October 2009, 14:06 | #5480 | Link | |
