14th January 2010, 05:17 | #6561 | Link | |
JMHO |
14th January 2010, 15:25 | #6562 | Link | |
My point was just scripting the play list so you do not have to join all the m2ts files together in the end... |
14th January 2010, 18:27 | #6563 | Link |
Slayer : Well unfortunatly it send back to my last post where keeping multiple m2ts files give some freeze at m2ts transition playback. What about my reflection about the secondary DTS Express audio management in my last post? And to finish, I have some ugly 'lines in the image' result by using deinterlace option (or leaving default in interlaced footages). And when I look to the LASTCMD I see the flag --interlaced while there is FieldDeinterlace() in the AVS. And when I read the resulted m2ts, I see MBAFF flag in the scan type property. Shouldn't it be set as 'progressive' (like the movie), as it supposed to be an interlaced footage converted to progessive? If I understand the problem in the process, first, interlaced footage is well deinterlaced by AVISYNTH but after, x264 receive the --interlaced flag and process it as an interlaced footage. That's would cause these resulting strange 'lines in the image'.
14th January 2010, 18:43 | #6564 | Link | |
Not sure what to tell ya.. I usually only do Movie Only Rips, to DVD-9. Maybe Jobbs knows... Could be an issue to what BD rebuilder thinks is main movie or not.. If it thinks that a interlaced source is progressive you might have a problem.. I only do full backup when I am dealing with Multi title episodes such as IE band of brothers ect... |
15th January 2010, 00:38 | #6567 | Link | |
Hi. Did that, XP Pro SP3, ran ffdshow set VC-1 to disabled and got an error message saying it needs setting to WM9, tried that and got the recode error. WMP11 would run but not decode VC-1 video files |
15th January 2010, 02:26 | #6569 | Link |
help
[12:00:49] BD Rebuilder v0.31.06 (beta) - Source: THE_FINAL_DESTINATION_2D_2D - Input BD size: 31.85 GB - Approximate total content: [03:44:43.803] - Target BD size: 22.46 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:00:52] PHASE ONE, Encoding - [12:00:52] Extracting A/V streams [VID_00036] - [12:00:52] Reencoding: VID_00036 (1 of 34) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3200) [12:00:55] - Failed video encode, aborted ffdshow version r3200 install x264 Encoder version r1391 install windows 7 b4 bit |
15th January 2010, 03:04 | #6570 | Link | |
Please don't shoot yourself and then ask me why you are bleeding... |
15th January 2010, 03:15 | #6571 | Link | |
with the default version that comes out the same error X264, ffdshow version r3200, today install new version X264 same error |
15th January 2010, 03:23 | #6572 | Link |
My first backup (Star Trek) went beautifully! I am extremely impressed with the quality.
Playing back with Windows Media Player I have no chapters (backed up in Movie-Only mode). I checked settings and re-encoded just to be sure. What am I missing? I searched but did not find an answer. Thanks! Last edited by indecision; 15th January 2010 at 04:00. |
15th January 2010, 04:31 | #6573 | Link | |
Try opening the .MPLS file found in the Playlist folder within the BDMV folder of your backup with tsMuxeR GUI, then click on the BluRay tab at the top, and see if you have a custom chapters list. |
15th January 2010, 12:12 | #6576 | Link |
Sorry,
[06:47:59] BD Rebuilder v0.31.06 (beta) - Source: THE_FINAL_DESTINATION_2D_2D - Input BD size: 31.85 GB - Approximate total content: [03:44:43.803] - Target BD size: 22.46 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [06:48:04] PHASE ONE, Encoding - [06:48:04] Extracting A/V streams [VID_00036] - [06:48:04] Reencoding: VID_00036 (1 of 34) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) [06:48:06] - Failed video encode, aborted ffdshow 3133 install ffdshow |
15th January 2010, 14:21 | #6577 | Link | |
15th January 2010, 20:20 | #6578 | Link |
My English is not very good i post me Message in Germany sorry
Bei den meisten Filmen wo ne HD Spur dabei ist macht mir BD Rebuilder ne AC3Tonspur draus , obwohl ich ihm die Hacken gesetzt habe das er es nicht machen soll habe einen Hacken gesetzt bei Keep HD Audio do not konvert dts to AC3 do not reencoded..... Ich nehme an das das die richtigen sind, bekomme aber trotzdem ne AC3 Spur Spur gemacht!!! Muss man da noch irgendetwas umstellen das einen die HD Spur bleibt???? |
15th January 2010, 20:51 | #6579 | Link | |
Programmer (or just 教务长)
It is probably because you're using BD Rebuilder in Movie-only/AVCHD mode. Options to keep HD audio are for Mode/Full-backup - Blu-ray (BD-25) only (I guess).
