2nd March 2018, 10:58 | #342 | Link |
When I can. Rig is going full bore on a batch job atm. A bit about the source. it's an anime from the 90's on BD it's from film stock not sure what kind can't find a description of the type film used. At any rate, hoping to cut out SMDegrain as it's bogging things down, it's also not completely able to get rid of the grain on it's own. In order to get any results with SMDegrain I had to use the thSCD1 parameter at 2400 then add in the settings from my next best setup. When I thought to add in your filter (at default settings mind you) it fixed all the remaining imperfections, well the ones that can be fixed without destroying details. Though there are some super fine details the script can't help but do something to
SMDegrain(tr = 12, thSAD = 800, thSADC = 400, contrasharp = false, refinemotion = false, interlaced = false, pel = 1, subpixel = 3, prefilter = 0, blksize = 16, search = 5, Truemotion = false, thSCD1 = 2400, lsb = false) mClean() Here's a before and after shot with the current settings on one of my test frames. The grain is quite dancy and changes pretty much every frame, the script works it just has a lot of overhead from running two filters that I'd like to cut out by cutting SMDegrain out. http://screenshotcomparison.com/comparison/133368 Edit: Also, updated to your latest version and am getting an error through MVtools (clip and super clip have different bit depths) no idea why. Last edited by phazer11; 3rd March 2018 at 03:11. |
3rd March 2018, 22:15 | #343 | Link |
burfadel Is it possible to add a multiplier or passes. For example, with ultra high compression (periscope streams), have to apply mClean twice, which worsens the speed.
Example ccd(20,1) #Camcorder color denoise mClean(deband=0,rn=0) mClean(rn=0) aWarpSharp2(100) two adjacent frames before and after (apng) http://images2.imagebam.com/76/ec/3d...7769202563.png UPD: After my requests,the author (Sergey 1400) of plugin "Camcorder color denoise" updated and made a 64-bit version. http://acobw.narod.ru I Propose to add/replace chroma denoise to him in your script mClean. Last edited by zub35; 4th March 2018 at 20:14. |
6th March 2018, 11:35 | #346 | Link | |
Just look at the first page of this thread ! It's not a plugin, it's a script! Just copy and paste the content of the code to a new avsi. Make clear you name this script mClean.avsi and you should be done..... |
2nd May 2018, 16:08 | #350 | Link | |
Also, this 32-bit one reports that it doesn't have an argument called presets. Edit: A 64-bit one with a preset argument is available here: https://1drv.ms/u/s!AmGuHbW3zvrBmb4tmBP2-KUToKUpVQ Last edited by Stereodude; 2nd May 2018 at 16:12. |
2nd May 2018, 22:09 | #352 | Link | |
Based on what I've seen it might be better suited for animation, but that's just a guess. Edit: In motion it's ugly. MCTD clobbers it. Last edited by Stereodude; 3rd May 2018 at 01:30. |
9th May 2018, 06:29 | #353 | Link |
Out of curiosity, and a test of my tenacity to get something to function, I grabbed the latest scripts for MCTD. Not to get off topic on this forum, can anyone report on it working properly with sharp=true? I believe this is the default and MCTD scripts I found all crash with sharp=true but will function with sharp=false. There is something about the parameters to mt_clamp being incorrect.
I bring it up here since MCTD is being compared to MClean. I don't believe the comparison is accurate or valid if the script is crippled. I will try to post something on a forum for MCTD to see if anyone there has any suggestions. I really would like to give it a test. I have some really REALLY noisy sources that thrive on these filters. |
9th May 2018, 17:03 | #354 | Link | |
https://forum.doom9.org/showthread.p...22#post1559222 For the requirement filters you'll need to find them elsewhere as the download link was outdated. |
10th May 2018, 05:25 | #355 | Link |
Hi lansing, I tried the version of the script you showed and I also found one slightly newer version dated back to 2013. The plug-in for mt_clamp is in masktools2 and the version I used for testing is 2.2.14, dated February 2018. I tried both versions of the X86 plug-in, but not the XP version since I am not using XP. Keep in mind that up until now, none of the other scripts I use have had or have any trouble with this version of masktools2, and even the previous version. I even went so far as moving the masktools2.dll to a different folder just to be sure there wasn't one somewhere else, and that caused a slew of other errors, so I am sure the version of masktools2 is not some older version that sneaked in somewhere else.
I get nowhere with this filter if sharpening is used. Set sharp=false and it works. In looking at the code, sharpening seems to be the only section that uses the mt_clamp function. The error remains the same, no matter what version of masktools2, incorrect arguments to mt_clamp. I'm dead in the water as for comparing this to MClean until I can get past this error. And since the last update was back in 2013 I wonder if the author is available, or even if there is anyone else that can understand the script or help me diagnose why it fails on my system. I did as much debugging as I am able to but I am not clear on what argument or arguments are wrong. I admit I am bummed about this. Anytime I can add another tool, it's a good thing. And being able to compare tools is also a good thing. Neither is happening for me right now. |
10th May 2018, 22:12 | #356 | Link | |
11th May 2018, 07:14 | #357 | Link |
The error is invalid arguments to mt_clamp. I tried another script/filter that uses mt_clamp and the filter functions, no errors. From that I conclude that masktools2 is good. Today I tried updating to the latest AviSynth+, and that had no effect on this. Tried masktools2 2.2.13 and 2.2.14, and the one listed in comments of the script, version 2.0a48. Same error message. Other scripts working fine, including MClean.
My system has an I7-6850K, Windows 10 64 bit 64GB RAM. It is possible I am hitting something that is CPU dependent. What confuses me is that others are using the script without errors. I don't know how to diagnose or debug this. There is a thread on this on the Doom9 MCTD forum. I am not sure the moderator wants discussion about this error on this forum. It doesn't matter to me where I get help on this. I am stuck as it stands and I would really like to have another tool and be able to compare it against MClean. |
11th May 2018, 07:53 | #358 | Link | |
11th May 2018, 09:43 | #359 | Link |
I went through all the plugins and installed a 32 bit version to be sure I didn't make that error, and still get the same error. Remember that if I set sharp to false, the script operates properly. Also, I tried a different script that uses the mt_clamp function and that script runs correctly. Whatever this is, it is isolated to the MCTD script and only the section that invokes the mt_clamp function.
Just as a test, I slipped in a 64 bit dll in place of a 32 bit dll and AvsPmod immediately detected the error and will not process the script. I am now sure that all plugins are indeed 32 bit. And I only testing 32 bit at this point. Once I had that working I planned to move to 64 bit. I have always been under the impression that 32 bit was more stable than 64 bit. That may not be true anymore, and once I get sleep I will try this using 64 bit plugins. The struggle continues. |
11th May 2018, 09:58 | #360 | Link |
Easiest way to check for plugin problems is avsmeter: https://forum.doom9.org/showthread.php?t=174797
AVSMeter(64).exe -avsinfo
cleaning, denoise, denoiser, mclean |
