Old 11th June 2017, 16:13   #201  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Thanks again
Old 13th June 2017, 22:25   #202  |  Link
SquallMX
Special SeeD
New version 1.2.4
Changelog
- v1.2.4 2017-06-10 Video recode: x265 support using avs4x26x.exe
Audio recode: Decode to W64 (always ffmpeg) or WAV.
Encode to EAC3 (ffmpeg), bitrate with prefix 'E'
Merge mono-channels WAV with sufix L,R,C,LFE,...
Detected as virus by Windows 10
SquallMX is offline   Reply With Quote
Old 14th June 2017, 09:45   #203  |  Link
SeeMoreDigital
I've just run the newest build through Windows Defender and it's reported this: -
Old 14th June 2017, 11:46   #204  |  Link
tebasuna51
tebasuna51's Avatar
@SquallMX
@SeeMoreDigital
Thanks for your reports.
I have here W 7 and Windows Defender without problems.
Please check if that exe run without problems: https://www.sendspace.com/file/t75su0
If not, you can try compile yourself the source (.au3) using the free tool Autoit3 from here (recommended Download Zip without install): https://www.autoitscript.com/site/autoit/downloads/
Like you can see Autoit3 seems stop their development in September 2015 and don't mention W 10 like OS supported.
- The source is free of trojan/virus like you can see.
- The Autoit3 compiler seems also free of trojan/virus (I don't see any report about that since 2015)
- My machine seems also free of trojan/virus (I hope, but if your compile work please report me!)
After that only rest a false positive or a W 10 issue.
Old 14th June 2017, 15:52   #205  |  Link
SeeMoreDigital
@SquallMX @SeeMoreDigital
Hi @tebasuna51,
I've just run your new compile through Windows Defender and "all is well"
Cheers
Old 14th June 2017, 20:45   #206  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, I was using a previous version to compile, with the last AutoIt v3.3.14.2 seems there are some changes to avoid malware false positives.
@SquallMX
Work for you?
Old 15th June 2017, 03:02   #207  |  Link
tebasuna51
tebasuna51's Avatar
New version 1.2.5
Changelog
- v1.2.5 2017-06-15 Audio recode: decoder admit parameters change (for ffmpeg).
INF: ffmpeg report of tracks in any container.
Can extract audio tracks.
I hope than this new version don't have malware false positives.
Old 15th June 2017, 05:18   #208  |  Link
SquallMX
Special SeeD
@SquallMX
Work for you?
Everything working fine, thank you!
Old 19th June 2017, 14:23   #209  |  Link
tebasuna51
tebasuna51's Avatar
New version v1.2.6
- v1.2.6 2017-06-19 Bug fix: Autoit v3.3.14.2 write files by default like UTF-8
Before are writed like ANSI. Corrected.
Filenames with spanish characters (ñ's, accents, etc.) are accepted now.
Also affect to modified srt's.
Old 19th June 2017, 15:18   #210  |  Link
SeeMoreDigital
Hi tebasuna51,
Windows defender is reporting a malware issue with this new version
Old 20th June 2017, 03:39   #211  |  Link
tebasuna51
tebasuna51's Avatar
I used the same compiler than 1.2.5 changing only the mode to write files to ANSI.
Old 11th July 2017, 20:17   #212  |  Link
sk2316
Hi tebasuna51,
I try to add core ac3 to thd but error
what wrong?
sk2316 is offline   Reply With Quote
Old 11th July 2017, 22:09   #213  |  Link
tebasuna51
tebasuna51's Avatar
Maybe is the samplerate (192 KHz).
I don't have a sample like this to test.
But work fine with a:
TrueHD, 7.1 channels, 96kHz
AC3 encoding doesn't support back channels. Will mix them into the surround.
AC3 encoding doesn't support this samplerate. Will resample to 48kHz.
Decoding with libav/ffmpeg...
Resampling to 48kHz...
Mixing surround channels...
Remapping channels...
Encoding AC3 <640kbps> with libAften...
Creating file "D:\tmp\test_96.thd_.thd+ac3"...
Try adding -resampleTo48000
EDIT: I deleted your post in eac3to thread, please remember the forum rule :
8) No cross posting. Post your message once, to the appropriate forum and nowhere else or it will be locked or deleted without warning.
Old 12th October 2017, 13:28   #214  |  Link
tebasuna51
tebasuna51's Avatar
New version v1.2.7 to support eac3to v3.32
Changelog
- v1.2.7 2017-10-12
Support eac3to v3.32 (UHD BD's y HEVC)
Force ANSI to read text files.
TwoLame replaced by ffmpeg to encode MP2.
Old 12th October 2017, 14:06   #215  |  Link
SeeMoreDigital
Old 12th October 2017, 15:17   #216  |  Link
Taurus
Taurus's Avatar
Old 16th October 2017, 11:58   #217  |  Link
tebasuna51
tebasuna51's Avatar
New version 1.2.8 to support MkvToolnix v17.0.0
Changelog
- v1.2.8 2017-10-16 Support MkvToolNix v17.0.0. New MkvExtractGUI.
Don't work with previous MkvToolNix versions because the mkvextract.exe have different syntax, before:
mkvextract {mode} {source-filename} options extraction-spec
Now:
mkvextract {source-filename} {mode1} options extraction-spec1 mode2 options extraction-spec2 …
With mode: tracks, timestamps_v2, chapters, attachments
Now we can use a unique job for all modes.
Old 30th October 2017, 20:30   #218  |  Link
SeeMoreDigital
Is it just me or is there an issue opening .mp4 contained files?
Cheers
Old 30th October 2017, 23:41   #219  |  Link
tebasuna51
tebasuna51's Avatar
eac3to don't support mp4 container.
You can try 'MkvExtract/INF' to extract tracks with ffmpeg or 'A/V Recode' to decode/recode audio.
Old 31st October 2017, 09:54   #220  |  Link
SeeMoreDigital
eac3to don't support mp4 container...
Well that explains it then...
I could have swore I've used it before to de-mux streams out of the .mp4 container....
Alzheimer's
