Old 19th November 2017, 19:28   #221  |  Link
staygroovy
Just wanted to say thank you to tebasuna for this GUI, I just started using it and it makes things much simpler compared to having to enter everything on the command line.
staygroovy is offline   Reply With Quote
Old 19th November 2017, 19:31   #222  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Agreed... I love it
SeeMoreDigital is online now   Reply With Quote
Old 3rd December 2017, 22:04   #223  |  Link
ripoyet
Thanks tebasuna. I hope that it runs with the last update of eac3to. Thanks for all.
ripoyet is offline   Reply With Quote
Old 4th December 2017, 02:02   #224  |  Link
tebasuna51
tebasuna51's Avatar
Yes, and with MkvToolNix v17 or greater.
tebasuna51 is online now   Reply With Quote
Old 3rd February 2018, 20:59   #225  |  Link
fAy01
Thank you!
fAy01 is offline   Reply With Quote
Old 5th February 2018, 20:47   #226  |  Link
deltec
Thank for this easy to use gui I use it to change an RF64 24/192khz file to w64 but at the end I have an RF64 file, and I can see it on prompt windows when program start to demux, why?
deltec is offline   Reply With Quote
Old 5th February 2018, 22:47   #227  |  Link
tebasuna51
tebasuna51's Avatar
I can't reproduce your problem:
eac3to v3.34
command line: "D:\Programa\eac3to\eac3to.exe" "D:\Test\test.rf64" "D:\Test\test.rf64_.w64"
RF64, 5.1 channels, 0:00:20, 24 bits, 27648kbps, 192kHz
Reading RF64...
Writing W64...
Creating file "D:\Test\test.rf64_.w64"...
The original audio track has a constant bit depth of 24 bits.
eac3to processing took 1 second.
Done.
command line: "D:\Programa\eac3to\eac3to.exe" "D:\Test\test.rf64_.w64"
W64, 5.1 channels, 0:00:20, 24 bits, 27648kbps, 192kHz
Put your log file.
Old 12th June 2018, 01:37   #228  |  Link
tebasuna51
tebasuna51's Avatar
New versión 1.2.9
Some bug corrected and improved 'A/V Recode' to make easy filter and recode audio with ffmpeg.
Some samples of audio filters:
Downmix:  -af "pan=stereo|FL<FC+0.70*FL+0.30*SL|FR<FC+0.70*FR+0.30*SR"  [or other]
Resample: -af aresample=48000
Speedup:  -af atempo=1.042708   [23.976->25], 1.041667 [24->25], 1.001 [23.976->24]
Slowdown: -af atempo=0.959041   [25->23.976], 0.96 [25->24], 0.999001 [24->23.976]
Delay:    -af adelay=1500|0|500|0|500|500     [one delay for each channel]
Trim:     -filter_complex "[0]atrim=2:8[a];[0]atrim=12:18[b];[a][b]concat=n=2:v=0:a=1"
And a sample of use in the image:
1) Load a mp4 in UsEac3to, ignore the non supported message.
2) Click at 'MkvExtract/INF' and ffmpeg inform:
3) The mp4 tracklist. We need recode the aac 44.1 KHz to 48 KHz and half volume.
4) We can extract the aac track, but is not necesary and close the dialog.
5) We put the ffmpeg filter: -af "volume=0.5, aresample=48000"
6) Click at 'A/V Recode' to open the dialog.
7) Select track 1 in 'map:X' or other like we see in 3)
8) Select 'Add to DEC' to add the filter.
9) Select ENCODER and quality.
10) 'Run' or 'EnQueue'
Old 12th June 2018, 09:08   #229  |  Link
SeeMoreDigital
Thank-you very much indeed
Old 12th June 2018, 11:33   #230  |  Link
Taurus
Taurus's Avatar
Thanks a lot dear tebasuna51.
Old 23rd July 2018, 19:41   #231  |  Link
szabi
Hi
I tried to encode 8ch audio to E-AC3 format: CLICK
It was almost two years ago.
Since that some version update occured I did try it again.
UsEac3To (v1.2.9)
eac3to (v3.34)
ffmpeg (ffmpeg-20180723-d134b8d-win64-static)
Command line parameter:
stdout.w64 | ffmpeg -i - -c:a eac3 -b:a 1120k %_.eac3
Encoder
Input #0, w64, from 'pipe:':
  Duration: N/A, bitrate: 9216 kb/s
    Stream #0:0: Audio: pcm_s24le ([1][0][0][0] / 0x0001), 48000 Hz, 7.1, s32 (24 bit), 9216 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (pcm_s24le (native) -> eac3 (native))
Output #0, eac3, to 'E:\my audio.eac3':
  Metadata:
    encoder         : Lavf58.17.101
    Stream #0:0: Audio: eac3, 48000 Hz, 5.1(side), fltp (24 bit), 1120 kb/s
    Metadata:
      encoder         : Lavc58.21.106 eac3
I still get 5.1 output, loosing extra channels.
What am I doing wrong?
bye
szabi is offline   Reply With Quote
Old 23rd July 2018, 20:01   #232  |  Link
sneaker_ger
ffmpeg simply doesn't support encoding >6 channels eac3.
https://trac.ffmpeg.org/ticket/3595
Old 23rd July 2018, 20:07   #233  |  Link
szabi
Linked topic almost 1 year old.
Seems no improvement since.
Old 23rd July 2018, 20:40   #234  |  Link
SeeMoreDigital
As far as I know, nobody has been able to create a 'freeware' E-AC3 encoder yet.
Old 25th July 2018, 10:01   #235  |  Link
szabi
I did not know that.
Old 11th November 2018, 15:53   #236  |  Link
gonca
Sorry to open an old thread
If I use a playlist from a BD (say 800.mpls) as input and then demux the streams, their names all start as 800xxx.avc, etc
Is there a way to have the names be that of the parent folder, I guess I need to somehow edit the cmd line that USeac3to creates for eac3to
Old 11th November 2018, 18:20   #237  |  Link
tebasuna51
tebasuna51's Avatar
I'm not sure what do you want. Maybe...
When you put in COMMAND LINE PARAMETERS:
%_BDNAME.*
and click in 'RUN CL' button you obtain:
eac3to v3.34
command line: "D:\Programa\eac3to\eac3to.exe" "D:\Temp\bd_name\BDMV\PLAYLIST\00011.mpls" 1) "D:\tmp\00011.mpls_BDNAME.*" -progressnumbers -log="D:\Programa\eac3to\UsEac3to\UsEac3To.log"
M2TS, 1 video track, 1 audio track, 0:00:26, 24p /1.001
1: h264/AVC, 1080p24 /1.001 (16:9)
2: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[v01] Creating file "D:\tmp\00011.mpls_BDNAME - 1 - h264, 1080p24.h264"...
[a02] Creating file "D:\tmp\00011.mpls_BDNAME - 2 - AC3, English, 5.1 channels, 640kbps, 48kHz.ac3"...
Video track 1 contains 616 frames.
Done.
Old 11th November 2018, 18:25   #238  |  Link
gonca
make it read
Creating file "D:\tmp\BDNAME - 1 - h264, 1080p24.h264"...
but your example might work well, thank you
Old 11th November 2018, 19:10   #239  |  Link
richardpl
I can, but not for free.
richardpl is offline   Reply With Quote
Old 14th November 2018, 22:10   #240  |  Link
SquallMX
Special SeeD
Any workaround for removing diagnorm on EAC3 files?
SquallMX is offline   Reply With Quote
