Old 20th March 2011, 05:15   #11581  |  Link
MickJT
@jdobbs
Don't know why I didn't remember this before! I initially downloaded Win7DSFilterTweaker because BD-Rebuilder wasn't able to set the preferred filters. However I did install a TMPGEnc Authoring Works trial, but can't remember at what point, before or after BD-Rebuilder. So I will need to do another test.
When I have some free time, maybe even tonight, i'll install Win 7 64bit in VirtualBox, and try again. If it really does have an issue on a 100% clean system with absolutely nothing else installed but what is on the first page, then it'll be worth looking at. At least a VirtualBox setup is going to be the same between all systems, and replicable. I'll update you ASAP.
BTW, thanks for all the hard work. I don't use BD-Rebuilder that often, but it certainly comes in handy. Can't imagine how many hours of work has been put into it.
Edit: Well, I don't think my BIOS allows 64bit Virtualization. I'll install the 32bit edition and test with that.
Edit2: Fresh Win 7 32bit in VirtualBox. ffdshow, AviSynth, Haali. Let BD-RB set up prefs. No issues.
Edit3: Filter tweaker causes same issue here (checked only for curiousity). Will try to find out what it was I must have done prior to that.
Edit4: No luck. Oh well, will have to remain a mystery for now.
Old 20th March 2011, 17:39   #11582  |  Link
laserfan
Aging Video Hobbyist
Originally Posted by laserfan View Post
...used it today w/latest 37.06 to make a DVD (Alternate Output) from a tsMuxeR'ed BDMV set I'd made from an HD TV recording...Guess I'm gonna hafta get in line with my donation shortly!
I could have bought a DVD of that program for $25 bucks, but it feels better to make a $20 PayPal donation to DVD-RB@jdobbs.net, which I just did (and saved myself $5 in the process).
Again, I know I used BD-RB in a way not intended, but am really grateful that it worked so well for this purpose. Thank you Mr. Dobbs.
Old 20th March 2011, 19:26   #11583  |  Link
Old 20th March 2011, 22:20   #11584  |  Link
MdMaynard
MdMaynard's Avatar
Yes, I do realize that this is a "Bug" thread, though I believe it is an important matter to address & hope it encourages others as it did me.
--I've been using this amazing program since V.2202. One glance at the threads & its obvious how much time you put into this, consistantly. I donated once before, happily & thankfuly considering how much I use BDR. Though I didn't know, & now makes sense, was the fact that in your responses to "Bugs" your putting out money to purchase the BD's etc. I didn't realize that it wasn't just your time & efforts (which in itself is exhaustingly extensive).
--& for the person who wanted something "special" for his donation (the "Pro version"), well, brains are not a criteria for life it seems. For such an amazing program, which you continually put effort into making it the best, & for all the use I've got out of it (& money it's saved me) I'm pleased to donate when I can..
Thank you for all you have, & are, doing
MdMaynard is offline   Reply With Quote
Old 21st March 2011, 16:09   #11585  |  Link
Warbucks81
Donation sent. I've been a long time user of DVD-RB Pro and BD-RB. Thanks for all the hard work!
Warbucks81 is offline   Reply With Quote
Old 21st March 2011, 18:04   #11586  |  Link
auzorann
an error has been popping up lately. it says wavi.exe has stopped working. if i close the error bd-rb continues working but the disk doesn't seem to work.
auzorann is offline   Reply With Quote
Old 21st March 2011, 20:08   #11587  |  Link
ken7795
Help, please!
I am trying to encode the Blu-ray for "Cars" for a BD-25 with utter failure each time no matter if I use the Automatic setting, "High Quality" or even "High-Speed Option". This is the message that I keep getting:
Error in attempt to multiplex: MUX_00060.meta
- Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
[14:37:01] - Failed to build structure, aborted
I figured that perhaps I had the wrong codecs installed, so I uninstalled and reinstalled FFDSHOW, Haali and AVISynth with the versions recommended on the first page of this post. Nonetheless, I still got the same error. I hope that someone could help me and explain what I'm doing wrong because this is the only Blu-ray disc that has posed any problems for me.
Thank you in advance for any help!
ken7795 is offline   Reply With Quote
Old 21st March 2011, 20:49   #11588  |  Link
It's very probably a bad rip. A PES packet that large means the source is almost assuredly corrupted. By the way -- I've done "Cars" with no issues.
Old 21st March 2011, 20:54   #11589  |  Link
ken7795
Damn. I used the latest version (actually 2 versions ago, at this point) of AnyDVD HD. Is there anything that I can do to salvage this? Or, should I cut my losses and either download the movie again?
Old 21st March 2011, 21:04   #11590  |  Link
Now I'm not so sure... I just noticed that the error was in the mulitplexing (not the demultiplexing)...
Can you post the log for this job?
Old 21st March 2011, 21:13   #11591  |  Link
ken7795
Cars failed encode log
Thank you once again for all of your help!
Old 21st March 2011, 21:16   #11592  |  Link
SpazzHH
SpazzHH's Avatar
Download the movie again? Out of curiosity, what is your source?
I'll learn this stuff yet, and when I do, Look Out !!!
SpazzHH is offline   Reply With Quote
Old 21st March 2011, 22:28   #11593  |  Link
had-z
Is that picture from a movie-only backup? If so, just select a different playlist...
I don't know why when i select movie only backup the program displays a error window with this: header: "illegal source" message: "selected source is not BD format" and when i select full backup, the program displays the stream list but without the main movie, only the extras. (the png atached in my other post,pending of aproval)
had-z is offline   Reply With Quote
Old 22nd March 2011, 01:18   #11594  |  Link
ken7795
I shouldn't have wrote "download again." I was typing fast and not actually thinking. My source was the original Blu-ray disc - I used AnyDVD HD to rip it. I meant that I should download the movie rather than attempting to rip it again. . . . it certainly helps to think before actually typing (a little self-deprecating humor to try to stomach the annoying process of figuring this damn thing out!)
Old 23rd March 2011, 04:18   #11595  |  Link
sonate
JD, I have a sound delay problem of about 2 seconds doing a full disk backup of "Amarcord"
INF:
[Status]
LABEL=AMARCORD
VERSION=v0.37.06 (beta)
SOURCE_SIZE=45289906883
SOURCE_VIDEO_SIZE=44650407936
TARGET_SIZE=24641536000
REDUCTION=.537554709184371
RESIZE_1080=0
AUDIO_TO_KEEP=eng;ita;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=1
ENCODE_STEP=0
COMPLETED=9
REBUILD_COMPLETE=1
[00312]
AUDIO=1
PGS=
M2TS_TARGET=112316148
NSTART=27000000
NEND=33937920
NSIZE=104835072
FLINK=0
MLINK=0
[00316]
AUDIO=1
PGS=
M2TS_TARGET=197668758
NSTART=27000000
NEND=35288640
NSIZE=274624512
FLINK=0
MLINK=0
[00318]
AUDIO=1
PGS=
M2TS_TARGET=245901916
NSTART=27000000
NEND=37316160
NSIZE=310056960
FLINK=0
MLINK=0
[00317]
AUDIO=1
PGS=
M2TS_TARGET=332899289
NSTART=27000000
NEND=40965120
NSIZE=404563968
FLINK=0
MLINK=0
[00310]
AUDIO=1
PGS=1
M2TS_TARGET=1006911770
NSTART=27000000
NEND=69072480
NSIZE=1543643136
FLINK=0
MLINK=0
[00307]
AUDIO=1
PGS=1
M2TS_TARGET=1849132604
NSTART=27000000
NEND=109883520
NSIZE=1017636864
FLINK=0
MLINK=0
[00311]
AUDIO=1
PGS=1
M2TS_TARGET=2877502645
RATE=7774
NSTART=27000000
NEND=146640960
NSIZE=2815346688
FLINK=0
MLINK=0
[00309]
AUDIO=1
PGS=1
M2TS_TARGET=3390122735
RATE=6837
NSTART=27000000
NEND=186465600
NSIZE=3324715008
FLINK=0
MLINK=0
[00274]
AUDIO=111
PGS=1
M2TS_TARGET=14206614845
RATE=12506
NSTART=27000000
NEND=361505925
NSIZE=14938859520
FLINK=0
MLINK=0
and Log file:
[07:49:29] BD Rebuilder v0.37.06 (beta)
  - Source:  AMARCORD
  - Input BD size: 42.18 GB
  - Approximate total content: [04:53:23.302]
  - Target BD size: 22.95 GB
  - Windows Version: 5.1 [2600]
  - Auto Quality: Good (Very Fast), Two Pass
[07:49:29] PHASE ONE, Encoding
 - [07:49:29] Extracting A/V streams [VID_00312]
 - [07:49:40] Reencoding: VID_00312 (1 of 9)
 - [07:54:47] Extracting A/V streams [VID_00316]
 - [07:55:05] Reencoding: VID_00316 (2 of 9)
[08:24:24] BD Rebuilder v0.37.06 (beta)
  - Source:  AMARCORD
- Resuming from previously started job.
[08:24:28] PHASE ONE, Encoding
 - [08:24:28] Reencoding: VID_00316 (2 of 9)
 - [08:38:40] Extracting A/V streams [VID_00318]
 - [08:39:07] Reencoding: VID_00318 (3 of 9)
 - [08:53:43] Extracting A/V streams [VID_00317]
 - [08:54:25] Reencoding: VID_00317 (4 of 9)
 - [09:12:45] Extracting A/V streams [VID_00310]
 - [09:14:07] Reencoding: VID_00310 (5 of 9)
 - [10:18:44] Extracting A/V streams [VID_00307]
 - [10:21:32] Reencoding: VID_00307 (6 of 9)
 - [11:47:42] Extracting A/V streams [VID_00311]
 - [11:53:14] Reencoding: VID_00311 (7 of 9)
 - [19:35:26] Extracting A/V streams [VID_00309]
 - [19:39:50] Reencoding: VID_00309 (8 of 9)
 - [02:13:43] Extracting A/V streams [VID_00274]
 - [02:31:11] Reencoding: VID_00274 (9 of 9)
[21:20:24]PHASE ONE complete
[21:20:24]PHASE TWO - Rebuild Started
 - [21:20:24] Rebuilding BD file Structure
[21:20:59] - Encode and Rebuild complete
[21:20:59] Writing BD structure to ISO file
 - ImgBurn completed successfully
[21:43:43]JOB: AMARCORD finished.
sonate is offline   Reply With Quote
Old 23rd March 2011, 16:27   #11596  |  Link
ken7795
Great idea!
I don't run one on my video machine either, but I have one on my "browsing and working" computer. I also turn off disc indexing, as that speeds thing up.
I was just browsing for info on the different encoding option and had a slap-my-forehead moment when I read this post. Thanks for the info regarding disc indexing.
Old 24th March 2011, 06:51   #11597  |  Link
dfsooner
BD_Rebuilder was changed recently to disable sleep mode while it was running. I believe it remains disabled even after the rebuild(s) is/are complete. Is it possible to re-enable it afterward?
dfsooner is offline   Reply With Quote
Old 24th March 2011, 10:16   #11598  |  Link
colinhunt
0.37.06 appears to de-interlace European Blu-ray 1080i50 sources to 1080p25 if the "Use Decomb" box is ticked (if one is to believe MediaInfo). If we stick to standards, this should not happen as 1080p25 is not in the BD standard.
Old 24th March 2011, 14:34   #11599  |  Link
thegame
thegame's Avatar
I just bought a BD from Germany that was suppose to be region free, well I get it and it won't play, it is 1080i @ 25fps, if I do a backup on this(full) can BD-RB change this to 1080p @ 23.976 fps?
thegame is offline   Reply With Quote
Old 24th March 2011, 14:38   #11600  |  Link
Not currently.
