10th April 2011, 18:27 | #11741 | Link | |
I will try stepping back a version of X264. I have a power supply tester will check it out. I have been stable up till now. Last edited by 1Bullet; 10th April 2011 at 18:32. Reason: add more info |
10th April 2011, 18:39 | #11742 | Link | |
System issues are much more likely to be the problem than X264. Lots of other people are running the latest versions of BD-RB and X264 without issues. I start hearing these kinds of reports every year when spring/summer comes around (most from overclocked systems). You'll see another one a little way back in this thread (but he refused to consider that his system might be at fault). Normally when X264 encounters an error, BD-RB will catch it by examining the O/S's returned error code. But when it is related to system instability it is unlikely that an error code will be returned. When that happens, all you end up with is a partial video encode that gets multiplexed into the output stream. Last edited by jdobbs; 12th April 2011 at 15:54. |
10th April 2011, 19:15 | #11743 | Link | |
10th April 2011, 19:32 | #11745 | Link |
I have the DVD resizing working and it will be in the next release. There are some limits, though, when converting from a format that allows 256 colors to one that uses 4. But based on my testing it is still pretty good.
10th April 2011, 20:40 | #11746 | Link | |
10th April 2011, 21:27 | #11747 | Link |
All my problems was solved with clearing the register of the ffdshow!! now i can backup without the fear of bad frames or macroblocks...
If i can help to solve the problem with black hawk down uploading a file (clpi or mpls) i will be even more happy! I'm very curious to see how will look a MPEG2-source encoded with the superior x264. (BHD is the only BD i have with the main movie encoded in MPEG-2) Thanks Again Jdobbs. Last edited by had-z; 10th April 2011 at 21:35. |
11th April 2011, 02:19 | #11749 | Link |
That's good news. I do resizing quite often and have noticed the "english subs for non-english parts" didn't show up in the rebuilt version. This will be a great improvement to an already excellent program. Thanks.
11th April 2011, 23:26 | #11753 | Link |
Senior Member
Does anyone experience chapter points that are off by about 0.5 seconds?
The original discs navigate chapter to chapter perfect. But when I play a backup and skip chapter to chapter I get the last couple frames of the previous chapter. It happens with every movie I do and all of them are movie only, no re-encode backups. (PowerDVD & Sony S370) I examined the BD-RB output using Don Graft's tool to identify the IDR frame numbers and compared that to the chapter time codes displayed in BDEdit. I found that the BD-RB output is correct. The IDR frames match up exact with the chapter time codes. Does this happen to anyone else? I can't figure out what could be causing this. Last edited by Video Dude; 11th April 2011 at 23:32. |
11th April 2011, 23:44 | #11754 | Link | |
BD-RB is able to work with original Blu-ray rips, not individual files. You could use tsMuxeR to create a Blu-ray with your mpeg2 file if it is compliant, then use BD-RB on that output. |
11th April 2011, 23:54 | #11755 | Link | |
12th April 2011, 00:30 | #11756 | Link |
Senior Member
I went back and checked the last backup I did since I still have the files on my hard drive (Fantasia 2000, movie only, no re-encode).
I extracted the chapters using both tsmuxer and BDedit. Playlist 00800 (I double checked it was the playlist BD-RB used). I noticed that there is a slight difference that could explain why my backups show the last few frames of the previous chapter when I skip chapters. Code:
BDedit (frame number format) Original Backup 0 0 1833 1809 5958 5934 8070 8046 22785 22761 24120 24096 42163 42139 43989 43965 54763 54739 55804 55780 58548 58524 60816 60791 74627 74603 76046 76022 85089 85065 85660 85636 98928 98904 107232 107207 BDedit (PTS format) Original Backup 0 0 3397143 3397140 11139253 11139210 15103213 15103169 42721428 42721425 45225180 45225180 79091512 79091505 82518686 82518660 102740137 102740130 104693964 104693940 109844109 109844100 114098985 114098940 140022382 140022360 142685668 142685640 159658248 159658245 160729944 160729920 185630445 185630445 201216015 201215970 Code:
tsMuxer Original Backup 00:00:00.000 00:00:00.000 00:01:16.493 00:01:15.492 00:04:08.539 00:04:07.538 00:05:36.627 00:05:35.625 00:15:50.366 00:15:49.365 00:16:46.004 00:16:45.004 00:29:18.590 00:29:17.588 00:30:34.749 00:30:33.748 00:38:04.115 00:38:03.114 00:38:47.533 00:38:46.532 00:40:41.981 00:40:40.980 00:42:16.534 00:42:15.532 00:51:52.609 00:51:51.608 00:52:51.793 00:52:50.791 00:59:08.962 00:59:07.960 00:59:32.777 00:59:31.775 01:08:46.122 01:08:45.121 01:14:32.467 01:14:31.466 Log: Code:
----------------------- [21:10:27] BD Rebuilder v0.37.05 (beta) - Source: FANTASIA_2000 - Input BD size: 21.12 GB - Approximate total content: [01:14:32.718] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Audio [1] set to default. [21:10:27] PHASE ONE, Encoding - [21:10:27] Extracting A/V streams [VID_00800] - [21:21:57] Reencoding: VID_00800 (1 of 1) - [21:21:57] Collecting video information - [21:21:57] Keeping original video (no reencode) - [21:21:57] Reencoding audio tracks (if req'd) - [21:21:57] Multiplexing M2TS [21:29:49]PHASE ONE complete [21:29:49]PHASE TWO - Rebuild Started - [21:29:49] Rebuilding BD file Structure [21:40:23] - Encode and Rebuild complete [21:40:23]JOB: FANTASIA_2000 finished. Code:
[Status] LABEL=FANTASIA_2000 VERSION=v0.37.05 (beta) SOURCE_SIZE=22681344000 SOURCE_VIDEO_SIZE=22681344000 TARGET_SIZE=24641536000 REDUCTION=1.08642309732615 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00800] USE_ORIGINAL=1 AUDIO=10000 PGS=1000000000 M2TS_TARGET=24641536000 NSTART=27000000 NEND=228272160 NSIZE=17532819456 FLINK=0 MLINK=0 Last edited by Video Dude; 12th April 2011 at 01:48. |
12th April 2011, 13:49 | #11757 | Link | |
12th April 2011, 15:25 | #11758 | Link | |
[Edit] Ok. It's on its way. It was only $10 at Amazon. I should get it Thursday. Last edited by jdobbs; 12th April 2011 at 16:05. |
12th April 2011, 17:32 | #11759 | Link |
Backing up the extras on Batman Darknight (alternate movie only selection) to a BD5.
I don't know what the error message means. I looked in the workfiles folder, and the m2ts was playable, but no audio. Thanks. ----------------------- [12:32:21] BD Rebuilder v0.37.06 (beta) - Source: BATMAN_THEDARKKNIGHT_BD - Input BD size: 5.28 GB - Approximate total content: [01:04:10.880] - Target BD size: 4.36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [12:32:21] PHASE ONE, Encoding - [12:32:21] Extracting A/V streams [VID_00009] - [12:36:48] Reencoding: VID_00009 (1 of 1) - [12:36:48] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 115,411 frames - Convert: 1280x720, 59.940fps, 230,822 frames - Bitrate: 8,752 Kbs - [12:36:48] Reencoding: VID_00009, Pass 1 of 2 - [13:40:13] Reencoding: VID_00009, Pass 2 of 2 - [15:45:40] Video Encode complete - [15:45:40] Reencoding audio tracks (if req'd) - [15:46:00] Multiplexing M2TS [15:48:17]PHASE ONE complete [15:48:17]PHASE TWO - Rebuild Started - [15:48:17] Rebuilding AVCHD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Non standart fps value do not supported for PGS streams [15:48:18] - Failed to REBUILD [Status] LABEL=BATMAN_THEDARKKNIGHT_BD VERSION=v0.37.06 (beta) SOURCE_SIZE=5673154560 SOURCE_VIDEO_SIZE=5673154560 TARGET_SIZE=4686086144 REDUCTION=.826010660284214 RESIZE_1080=-1 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=0 [00009] AUDIO=1 PGS=01000000000000 M2TS_TARGET=4686086144 RATE=8752 NSTART=27000000 NEND=200288862 NSIZE=4435556352 FLINK=0 MLINK=0 |
12th April 2011, 17:48 | #11760 | Link |
@KillingTime
Are you working from an original disc? I tried both of the Region 1 "Dark Knight" discs and there is no playlist that contains only 00009.m2ts. I did, however find one on Disc 1 that is 0008.m2ts and is the exact same length as yours. I'm running it now. |
