Old 23rd March 2014, 21:13   #19621  |  Link
rusty666
it let me input peabody in bdrebuilder. im did try iso 3d pacific rim twice to see if was anything to do with my system but still out of sync when played the output file
rusty666 is offline   Reply With Quote
Old 23rd March 2014, 21:57   #19622  |  Link
Capsbackup
Originally Posted by Ch3vr0n View Post
that and afaik bdrb can't handle Xvid's
Actually, BD-RB does accept import of Xvid!
Old 23rd March 2014, 21:57   #19623  |  Link
@Rusty666
To clarify rule 6 material here, I asked where you got your source material Peabody. Will you answer it?
Old 23rd March 2014, 22:34   #19624  |  Link
rusty666
it was only the ts of peabody wat is floating about
Old 23rd March 2014, 23:13   #19625  |  Link
I see, thank you. Please follow our forum rules, especially rule 6.
Old 24th March 2014, 02:01   #19626  |  Link
Imperial Zeppelin
I'll have to test "The Hobbit, Pt 1" -- I haven't gotten that one yet, but I probably will soon. Unfortunately with the lack of donations in the last month I'm not planning to pick up any discs that aren't for my personal use. "Frozen" falls out of that category. It's one thing to work for nothing, it's another to pay for the privilege.
I have full 3D backups working -- but there is an picture-sync issue with multipart sources that I'm working. I'm hoping to get a special test version out in the next week or so.
Turns out Frozen was just a matter of too many updates without a purge, nuked my BD Rebuilder folder and reinstalled everything including support programs.
However, did tweak me to send in a donation. I always said I'd send something in when it went from Beta, but I'm thinking that's no longer the strategy. Keep up the appreciated work!!
Phenom II 940
GA-MA790FS-DS5 plus ATI 480
4 x 2 GB Mushkin
Windows 7 64-bit
3.5 Terabytes Mass Storage
2 BD Burners, 2 DVD burners
Lots of other "Stuff"
Imperial Zeppelin is offline   Reply With Quote
Old 24th March 2014, 12:14   #19627  |  Link
colinhunt
jdobbs, I found an earlier post where you mentioned that Quality setting is applied to FRIMencoder. Have you mapped "ENCODE_QUALITY=4" to FRIMencoder quality setting, or is "ENCODE_QUALITY=3" the highest setting that affects FRIMencoder?
Old 24th March 2014, 14:01   #19628  |  Link
It's been in beta for over 5 years. I am continually making large changes, which keep it in beta (e.g. I'm working on full 3D backups right now that make numerous modifications to the code and a few subroutine rewrites).
Old 24th March 2014, 15:05   #19629  |  Link
soneca
jdobbs, could add a hidden option to change the font size of the subtitles (.srt) in import mode?
It would be great because the subtitles are a bit large and occasionally exceed the limits of the screen.
Old 24th March 2014, 19:21   #19630  |  Link
rusty666
does that mean full backup with menu even on the 3d iso converted to sbs?
Old 24th March 2014, 19:51   #19631  |  Link
Right now it means a full backup of a standard 3D-BD format to a standard 3DBD format. But, a 3D SBS backup can already be backed up... because it is simply a 2D disc that has SBS implemented.
Old 24th March 2014, 21:58   #19632  |  Link
raul124
raul124's Avatar
I have the latest FFDSHOW from the 1st page, what's the correct setting to make FFDSHOW work together with BD-Rebuilder? What do I need to tweak to make it right, because when I play the stream from the back up before I burn it to a BD-5 or BD-9, I hear a pitch sound coming from the play back stream. any advice would be appreciate it, thank you
raul124 is offline   Reply With Quote
Old 24th March 2014, 22:14   #19633  |  Link
You're probably keeping an HD audio stream that isn't supported in FFDSHOW. I'm guessing that the original does the same thing, right?
Old 24th March 2014, 22:56   #19634  |  Link
Frozen driving anyone else nuts. I tried multiple boots, etc....
If I try Full Backup either from a AnyDVD ISO RIP, ISOBURN RIP or right from the disc, all mediated by AnyDVD of course:
[03/22/14] BD Rebuilder v0.46.14 (beta)
[08:11:22] Source: FROZEN
- Input BD size: 40.16 GB
- Approximate total content: [02:59:12.532]
- Target BD size: 21.92 GB
- Windows Version: 6.1 [7601]
[08:11:24] PHASE ONE, Encoding
- [08:11:24] Processing: VID_00800 (1 of 44)
- [08:11:24] Extracting A/V streams [VID_00800]
- [08:11:30] Reencoding video [VID_00800]
- Rate/Length: 23.976fps, 800 frames
- Bitrate: 16,620 Kbs
- [08:11:30] Reencoding: VID_00800, Pass 1 of 1
- [08:11:58] Video Encode complete
- [08:11:58] Processing audio tracks
- [08:12:00] Multiplexing M2TS
- [08:12:05] Processing: VID_00879 (2 of 44)
- [08:12:05] Extracting A/V streams [VID_00879]
- [08:12:11] Reencoding video [VID_00879]
- Rate/Length: 23.976fps, 1,372 frames
- Bitrate: 16,370 Kbs
- [08:12:11] Reencoding: VID_00879, Pass 1 of 1
- [08:12:48] Video Encode complete
- [08:12:48] Processing audio tracks
- ERROR preparing intermediate audio.
[08:12:49] - Failed to reencode audio, aborted
I got a couple donations, so I picked up a copy of "Frozen". I had no issues at all with a full-backup. I have to believe that you either have a bad rip, or something is wrong with your setup. Here's where it gets past the point your log stops:
[03/24/14] BD Rebuilder v0.47.01 (beta)
[15:52:02] Source:  FROZEN
  - Input BD size: 40.15 GB
  - Target BD size: 22.95 GB
  - Quality: Good (Very Fast), ABR
  - Decoding/Frame serving: DGDecNV [3-way]
[15:52:04] PHASE ONE, Encoding
 - [15:52:04] Processing: VID_00800 (1 of 44)
 - [15:52:04] Extracting A/V streams [VID_00800]
 - [15:52:12] Reencoding video [VID_00800]
   - Bitrate: 17,468 Kbs
 - [15:52:12] Reencoding: VID_00800, Pass 1 of 1
 - [15:52:19] Video Encode complete
 - [15:52:19] Processing audio tracks
 - [15:52:23] Multiplexing M2TS
 - [15:52:27] Processing: VID_00879 (2 of 44)
 - [15:52:27] Extracting A/V streams [VID_00879]
 - [15:52:34] Reencoding video [VID_00879]
   - Bitrate: 17,207 Kbs
 - [15:52:34] Reencoding: VID_00879, Pass 1 of 1
 - [15:52:47] Video Encode complete
 - [15:52:47] Processing audio tracks
 - [15:52:53] Multiplexing M2TS
 - [15:52:57] Processing: VID_00880 (3 of 44)
Old 24th March 2014, 22:57   #19635  |  Link
rusty666
thanx ill try converting a 3d iso to 3dbr sbs with menu
Old 24th March 2014, 23:02   #19636  |  Link
Why not just wait a day or two and you will be able to do the backup without needing SBS. I'm almost done with the 3D full backups. All that's left is some additional testing.
Old 24th March 2014, 23:13   #19637  |  Link
Sharc
Any chance that the Quick-Play reauthoring issue will be fixed with the next release as well?
Old 24th March 2014, 23:17   #19638  |  Link
rusty666
its only because my dads mate only has a blu ray not a 3d blu ray player. up to know tho it dont say converting to side by side in 3d mode like it does when i do movie only . is that right?
Old 24th March 2014, 23:25   #19639  |  Link
wakko709
- FFDSHOW: [4504], Ok
- AnyDVD settings check: Ok.
- BD-RB v0.46.0.14, not current
not current? huh?
wakko709 is offline   Reply With Quote
Old 24th March 2014, 23:31   #19640  |  Link
mparade
For me this means that a tiny bit of donation should be done urgently.
